STD Tuning Engine 6mm elements for m-pump
awk
10-30-2012, 07:45 AM #1
Hey !
I have om617 and i want to swap elements for 6mm from om606. As far as i know the code of element is 1 418 305 535. The question is where i can get them?(Europe) Local diesel shop sells them for 70 euro each (Thats big price for me) Any suggestions?
P.S madeinchina and chinahanji dont have them in stock.
awk
Hey !
dieselmeken
10-30-2012, 10:45 AM #2
(10-30-2012, 07:45 AM)awk Hey !
How many do you want, and is it a M-serie in the 617?
dieselmeken
awk
10-30-2012, 10:49 AM #3
yes m serie from om617 i need 5 elements
awk
awk
11-02-2012, 05:49 AM #4
more suggestions?=)
awk
more suggestions?=)
aaa
11-02-2012, 07:52 AM #5
Get them from a 605 pump.
aaa
11-02-2012, 10:41 AM #6
This has been posted a few times for M-pump 7mm.
http://www.dieselkontor.de/product_info....ts_id=3271
awk
11-03-2012, 05:03 AM #7
Om 605 has also 6mm?
awk
aaa
11-03-2012, 07:39 AM #8
The turbo models do.
aaa
Falkrum
11-06-2012, 02:53 AM #9
(11-03-2012, 07:39 AM)aaa The turbo models do.
all N/A IP has 5.5mm elements (om605-606 - w124, w202, w210)? is it correct?
So 6 mm elements were only in turbos models of om605-606?
I also need 5 units of 6mm elements. Maybe someone has a correct Part number?
Falkrum
dcm
11-06-2012, 10:17 AM #10
Yes non turbo 605/606 engines have 5.5mm elements.
605/606 Turbo models have 6mm elements.
The cheapest option would probably be to find a second hand pump with 6mm elements, any pump with PES5M60CXXXRSXXX will have 6mm elements.
dcm
awk
11-15-2012, 03:39 PM #11
Falkrum element number is 1 418 305 535
awk
Falkrum
11-19-2012, 01:34 PM #12
(11-15-2012, 03:39 PM)awk Falkrum element number is 1 418 305 535
I dont think so. You can find same partnumber in 603 turbo fuel pump... this is what i checked. So this is 5.5 mm elements.
Same as Mercedes A 001 074 29 22.
I also have 1 418 305 540 and this is 5.5 mm elements too.
This post was last modified: 11-19-2012, 01:35 PM by Falkrum.
Falkrum
