4 speed auto manual swap problems
So to make a long story short. I have a 79 300D that im stuffing a turbo 617 with a manual 4 speed ( full aluminum housing) in. I read around that I would need a 240D auto crossmember which I got from flebay. Today I go to mount the trans and I discover that all crossmembers (300D auto, 240D auto, 240D manual) dont fit and sit way to far back.
300D auto crossmember
240D autocrossmember(supposedly)
I will have a full conversion build thread later on when Im closer to completion.
Alohas and thanks for your help
Gill P
P.S. hopefully the pics load.
Also as you can see that the tunnel gets wider the closer I get to the front of the car. The crossmembers are to short to reach the holes if I go any farther forward. Moving the anchor clips wont solve the problem but I know I will have to if I find the right crossmember.
Alohas
Gill P
Can you chop things up and reweld?
If I where to do that I would make a custom mount and not chop up any mounts. I will have to find the proper offset of the mount and then weld up something.
I was under the impression from reading numerous 4 speed swap threads that I would need a 240D auto crossmember but that didnt work out so well as you can see in the pics. Unless someone sold me the wrong mount.
Alohas
Gill P
That mount you stated that's a 240d auto mount in the second picture doesn't look like a 240d auto mount. The first pic kind of looks like it.
I found this picture comparing the mounts. The 300 auto mount has a bar attached to it for use on the 4 speed manual.
Btw- I can grab an 240d auto mount at my local yard if your interested. Pm me.
Anybody know where I can get a Auto 240D crossmember. Delivery valve was the man and agreed to hook me up then he found out that the cars he had in mind were crushed . Thanks again for your effort DeliveryValve!!! Much appreciated.
Also Im still in need of a 4 speed shifter as well anybody know how to source one or know anybody with one
Alohas
Gill P
(11-15-2012, 02:12 PM)gill4321 Anybody know where I can get a Auto 240D crossmember. Delivery valve was the man and agreed to hook me up then he found out that the cars he had in mind were crushed. Thanks again for your effort DeliveryValve!!! Much appreciated.
Alohas
Gill P
Alohas
Gill P
Well I ordered a mount from www.mercedespartscenter.com and they where really helpful. You usually need a VIN number for your orders but they let me slide.
So today I got my mount from Germany from the Manufacturer. Cost me only $109 wish shipping. I know its a little steep but you cant beat brand new.
Part number is 123 242 07 01 just in case the picture is crap.
Alohas everyone and I will make a new thread with the whole swap once its done. SOOOON i Hope
Alohas
Gill P
Hey that is great. Good to know you can still order it new. Thanks for posting the part #
