STD Tuning Engine racing camshafts for om606
m2rkz
11-28-2012, 02:30 PM #1
Where do buy racing camshafts for om606 with good price?
m2rkz
EDH_Performance
11-28-2012, 02:47 PM #2
(11-28-2012, 02:30 PM)m2rkz Where do buy racing camshafts for om606 with good price?
kmcams.com regrinds to your spesificationsWink
EDH_Performance
artuur
11-28-2012, 02:58 PM #3
(11-28-2012, 02:47 PM)EDH_Performance
I asked from kmcams.com
hopefully we get asnswer tomorrow.
Artur
artuur
Artur
EDH_Performance
11-28-2012, 03:01 PM #4
(11-28-2012, 02:58 PM)artuur
Artur
They are a really good and serious company! Have bought many camshafts from them, and they are gonna make me some racing camshafts for my engineWink They also sells bolt on valvesprings that can handle up to 8000rpm! I have the springs in my engineWink
EDH_Performance
Artur
artuur
11-28-2012, 03:11 PM #5
(11-28-2012, 03:01 PM)EDH_Performance
(11-28-2012, 02:47 PM)EDH_Performance kmcams.com regrinds to your spesificationsWink
Artur
ok
question about the valve spring shims ?
the original ones dont fit with new springs ? what needs do be done with new shims?
The valves will be ordered next week Smile
artuur
Artur
ok
EDH_Performance
11-28-2012, 03:23 PM #6
As you now, the stock springs is wider in the botom than the top...
the race springs is not so wide in the botom as the stock ones, so the spring won`t fit on the stock bottom shims!
So you need to make a flat shims, as thin as you can find! I used some washer, for bolts/nuts (local hardwear store). I used some washer that was about 1.5mm thick, and abit bigger diameter than the springs...I had to drill the senter hole a bit bigger to go over the valvestem sealWink Easy fix!
Look at the pictures in my project threadWink
EDH_Performance
mantahead
11-28-2012, 07:37 PM #7
hi,
anyone worked out how much more lift is needed when getting om606 cams reprofiled for more rpm?
Edh Performance, is the n/a intake cam no good for high rpm?
mantahead
hi,
EDH_Performance
11-29-2012, 07:00 AM #8
(11-28-2012, 07:37 PM)mantahead
hi,
I dont know, mine revs to 6100rpm...N/A shafts works good, but for extreme power you need to look at some performance shaftsBig Grin
EDH_Performance
hi,
