STD Tuning Engine A few mechanical problems
Insane190d
12-01-2012, 05:49 PM #1
First off my RPM tac doesnt work....how do i fix
Second, when i park up a slight hill with a quarter tank or less for a while it doesnt start, must be air getting in fuel whats causing that??
Third, while gear changing the car hops alot more than should, i noticed the carrier bearing in center of drive shaft is bad.....Would this be the problem?? What else to look for that may cause that?
Thanks Matt
Insane190d
Thanks Matt
aaa
12-01-2012, 07:34 PM #2
Well... assuming this is a 190d.
1 - check your OVP relay
2 - check your delivery valve o-rings (are they leaking fuel)
3 - check your vacuum system, sticking a gauge on it should yield 14 psi
aaa
Insane190d
12-01-2012, 08:23 PM #3
(12-01-2012, 07:34 PM)aaa Ok ill check all that, it is a 190d and the D/V's do leak a little fuel.
The tack does bounce around every now and then
This post was last modified: 12-01-2012, 08:24 PM by Insane190d.
Insane190d
aaa
12-01-2012, 10:06 PM #4
Well see if it bounces when you poke at the ovp relay. Sometimes the contacts are corroded, or sometimes the relay itself is bad.
aaa
