STD Other Open New years resolutions/project plans?
12-31-2012, 01:11 PM #1
So another year has gone. Now it's time to reflect on what went right and what went wrong.
12-31-2012, 02:28 PM #2
I resolve to cook and make more fries. I got this fry cutter thing for xmas and it is badass!
12-31-2012, 02:30 PM #3
I resolve to give no fucks
01-03-2013, 07:03 PM #4
I resolve to get a hx30 or he221 for the benz, fix the head gasket, and get my PC's worked over.
Also i am going to get my N90 injectors in my 3-71 detriot pulling tractor, and get my Bosch VE pump on my other pulling tractor.
Thats just a start Smile
01-03-2013, 08:15 PM #5
I resolve to NOT turbo the DD even though there's a turbo manifold on CL for $10
01-04-2013, 12:48 PM #6
I am resolved in selling off 4 cars and completing the 2 MB car projects I got cooking, then resolved to clear out the garage of about 1,000 pounds of parts and car items! So my wife says to the forgoing ... LOL
01-04-2013, 03:13 PM #7
I am going to fix this heater core this year. I just swapped out the radiator because it was leaking. I wonder what can be causing all the fuss in the cooling circuit?
One time about 2 yrs ago this one hose to the heater core blew out. I wonder if that's when all the trouble started?
Also I see that one of the transmission fluid cooling hard lines seems to be leaking. This leaking ass bitch drives me nuts Wink
Maybe the heater core is fine? Just a hose could have come loose. That would be ideal.
This post was last modified: 01-04-2013, 03:20 PM by larsalan.
01-04-2013, 03:58 PM #8
(01-04-2013, 03:13 PM)larsalan I am going to fix this heater core this year. I just swapped out the radiator because it was leaking. I wonder what can be causing all the fuss in the cooling circuit?
God luck man. Sounds like a corrosion issue-are you using DI water with your coolant?
Swap to manual and you won't have any more transmission cooler leaks Smile
01-04-2013, 04:30 PM #9
nah, it is just tap water. And I am always seeing rust in the bottom of the radiator. I plan to get into the dash tomorrow.
01-08-2013, 10:47 AM #10
I am right there with you, my car leaks like a damn two stroke Detroit, possibly more! haha
