STD Tuning Engine OM606 with OM603 pump
TheDon
606 Power!!
247
01-08-2013, 08:44 PM #1
I noticed the original 606 spin on fuel filter housing uses different hose connectors than the 603 filter housing. Is my thinking correct that I need to get a fuel filter housing from a 60/1/2/3 ?
thanks
TheDon
thanks
Alastair E
Moderator?--Nah...
266
01-09-2013, 06:15 PM #2
Be the best option to dump the hideous plug-in fuel lines of the 606 anyway, including those on the fuel-filter...
They are a common cause of air ingress issues so best removed and conventional fittings/pipes used....
[Image: 300TDnoplate.jpg]
Alastair E
TheDon
606 Power!!
247
01-09-2013, 09:07 PM #3
Now to find said filter housing!
TheDon
Bangaway
606 Turbo > Porsche Turbo
129
01-09-2013, 11:14 PM #4
Where'd you find the pump? Are going with the 603 oil pan and pump or the 400E sway bar? I think I'm going with the sway bar?
Bangaway
TheDon
606 Power!!
247
01-10-2013, 07:28 AM #5
I haven't gotten the 400e sway bar since I haven't verified if it will fi the oil pan and original sway bar issue
TheDon
TheDon
606 Power!!
247
01-10-2013, 05:46 PM #6
I just checked the inventory of the junk yard and the 400E is no longer listed. Damn it all
TheDon
