STD Tuning Drivetrain W210 E300 (606) auto to manual?
Palmer
02-03-2013, 07:53 AM #1
What options are out their for an e300 manual conversion? Presuming no straight drop in etc
Palmer
THE DIGGER
02-03-2013, 08:16 AM #2
(02-03-2013, 07:53 AM)Palmer What options are out their for an e300 manual conversion? Presuming no straight drop in etc
Is it a td or na 606? I've only ever seen a manual e class with a non turbo 606 (other than petrol) so there is straight swap....getting the engine to run without the autobox will be the issue!
THE DIGGER
Palmer
02-03-2013, 08:17 AM #3
(02-03-2013, 08:16 AM)THE DIGGER
TD.
Ive seen some YT vids of people using the E320 CDI 6 speed box?
Palmer
TD.
aaa
02-03-2013, 09:49 AM #4
Here's someone who did it on his 96 e300:
http://www.peachparts.com/shopforum/2629580-post12.html
aaa
THE DIGGER
02-03-2013, 07:09 PM #5
(02-03-2013, 09:49 AM)aaa Here's someone who did it on his 96 e300:
Not sure about that.....a w210 chassis wont start with the gearbox "unplugged".
THE DIGGER
Palmer
02-05-2013, 10:39 AM #6
5 Spd from a C250? In essence the same engine with a cylinder knocked off.....?
Palmer
Palmer
02-12-2013, 10:50 AM #7
Bumpety bump bump Wink
Palmer
Magnus
02-13-2013, 10:03 AM #8
Hi
I'm not entirely sure about the 300TD, but I have just unplugged the connection directly to the gearbox, dismantled the gearshifter box and soldered over the connection that tells the electronics that it is in "park" on my w210.
I have changed the pump to an older Bosch pump (no electronics) and the starter still automaticly cuts out when the engine starts, even the rev counter still worksSmile
Only problem is of course no cruisecontrol and the ECU lamp in the instrument cluster is on.
Takes you about 15 min. to check if your car will still start etc. with the automatic disconnected.
Magnus
Magnus
Hi
Magnus
Matej
02-06-2015, 05:29 PM #9
Sorry for bringing this discussion back from the dead, but has anyone successfully performed the manual transmission swap in a W210 since the thread was created?
I have an opportunity to procure an otherwise nice W210 diesel specimen with a bad transmission, which would be a prime candidate for a manual swap.
(In all honesty, I would want to perform the conversion even if the car had a good transmission. Smile)
Irony.cc
Matej
Irony.cc
tjts1
02-07-2015, 02:24 AM #10
Yes its been done.
http://www.peachparts.com/shopforum/dies...cture.html
[Image: 208104.png]
Matej
02-07-2015, 03:04 PM #11
Great information, thank you.
I wonder if the tabs on the flywheel would still be necessary if the engine is converted to a manual injection pump.
This post was last modified: 02-07-2015, 03:04 PM by Matej.
Irony.cc
Matej
Irony.cc
benzguy
02-11-2015, 12:28 AM #12
(02-07-2015, 03:04 PM)Matej Great information, thank you.
I don't think so but I could be wrong
benzguy
