STD Tuning Engine how much boost on om617 with 6mm pump?
awk
02-14-2013, 03:55 AM #1
Hey i got an om605 6mm elements and going to swap them on my m pump for om617. Hopefully will get 100-115cc. How much boost shoud i run on this one? (I think max 1bar) and 38mm external wastegate will be enough? with a spring adjusted on 0.7 bar
awk
EDH_Performance
02-14-2013, 01:28 PM #2
(02-14-2013, 03:55 AM)awk Hey i got an om605 6mm elements and going to swap them on my m pump for om617. Hopefully will get 100-115cc. How much boost shoud i run on this one? (I think max 1bar) and 38mm external wastegate will be enough? with a spring adjusted on 0.7 bar
You will ned a good flowing turbo and boost it until it get smokelessWink
I dont think you can get i smoke free on only 1 bar!
EDH_Performance
RedDiesel
02-16-2013, 10:01 AM #3
(02-14-2013, 01:28 PM)EDH_Performance I dont think you can get i smoke free on only 1 bar!
He didn't say anything about what turbo is used or if there is any intercooler.
With an intercooler 1 bar would be plenty, without you would need over 1.5bar to consume the same weight of air.
This post was last modified: 02-16-2013, 10:02 AM by RedDiesel.
RedDiesel
