STD Tuning Engine OM617a flow rate ?
OM617a flow rate ?
OM617a flow rate ?
kmaser
Turbocharged G-Wagen
125
03-07-2013, 10:40 PM #1
I thought I could remember a discussion on the Om617a flow rate but could not find it. I want to check the flow rate against the R444-2 turbo map and see if I am overspeeding the turbo. Can anybody tell me the OM617a flow rate or point me in the direction of a calculator and the specs from the OM617a that I would need to determine it?
thanks
kmaser
thanks
03-08-2013, 02:58 AM #2
http://www.not2fast.com/turbo/glossary/t...utyCycle=0
03-08-2013, 08:39 AM #3
That's a cool page.
What you need to know is the Volumetric Efficiency of the engine or, even better, the volumetric efficiency curve. I bet it gets pretty bad past 3500 RPM.
That's a cool page.
