STD Tuning Drivetrain w126 300se om606 24v conversion help????
brianmccourt
03-15-2013, 08:32 PM #1
hi lads i just got a nice w126 saloon 3l petrol 6cyl i have a e300 tdi engine will this bolt in ? is it hard change it to manual?? help pls thank you
brianmccourt
aaa
03-15-2013, 10:56 PM #2
You can get om603 mount arms for w126.
aaa
Druk
03-16-2013, 02:50 AM #3
E300tdi Do you mean 300TD? the one from a W210?
It will bolt directly to a manual box but there are many other considerations.
Druk
brianmccourt
03-16-2013, 05:23 AM #4
(03-16-2013, 02:50 AM)Druk E300tdi Do you mean 300TD? the one from a W210?
thanks for reply sorry yes i meant td ...if i got a c250 td gearbox and flywheel ect will it work ok?
(03-15-2013, 10:56 PM)aaa You can get om603 mount arms for w126.
but can i use them mount arms with a 0m606 in a w126?
This post was last modified: 03-16-2013, 05:25 AM by brianmccourt.
brianmccourt
brianmccourt
03-16-2013, 06:41 PM #5
bump help pls
brianmccourt
bump help pls
Druk
03-17-2013, 04:05 AM #6
(03-16-2013, 06:41 PM)brianmccourt bump help pls
250TD gearbox and flywheel will bolt straight up to the 606 however...
Your thoughts on injection pump control? As standard the 606.962 TD engine has an electronic pump and wont work without the donor canbus circuit and all it's associated gubbins, (which in turn wont appreciate not having the .6 gearbox ECU to 'talk' to). So, you will need a manual pump from a W124 300D with a 6mm element swap and the stand-alone ALDA from Dieselmeken.
This post was last modified: 03-17-2013, 04:11 AM by Druk.
Druk
brianmccourt
03-17-2013, 06:40 AM #7
(03-17-2013, 04:05 AM)Druk
thats my plan a manual pump big turbo tooBig Grin but i need to know will a 606 engine bolt in to the w124 what engine mounts ect do i need?? its a straight 6 engine in the car now so cant be too different?
brianmccourt
03-17-2013, 08:48 AM #8
Your W124 mounts should swap.
The engine supports, or motor mount arms used in the 603 equipped 126's is PT# 6032230604 and 6032230704. The 603 equipped w124's do not share the same part # for the motor mount arms.
brianmccourt
03-17-2013, 12:14 PM #9
(03-17-2013, 08:48 AM)raysorenson Your W124 mounts should swap.
SO IF I USE THE MOTOR MOUNTS FROM THE M103 3L PETROL ENGINE ON THE DIESEL 606 ENGINE THIS SHOULD WORK?
brianmccourt
03-17-2013, 01:51 PM #10
No, sorry I got a bit confused. W124 motor mounts are not the same as W126 mounts.
Go here for your parts research http://www.neoriginal.ru/cat/mb/
brianmccourt
03-17-2013, 05:36 PM #11
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WHAT DO I NEED TO SIT A 606 ENGINE IN TO A W126????????????
WILL I BE ABLE TO PUT A MANUAL GEARBOX FROM A C250TD IN TO A W126
I KNOW A C250 GEARBOX WILL FIT A OM606 ENGINE BUT WHAT MOUNTS DO I NEED TO SIT A OM606 IN TO A W126??????????????
I PLAN TO PUT A MECHANICAL PUMP ON TO THE ENGINE SO WIREING IS NOT REALLY MY PROBLEM MAKEING SURE I CAN GET A OM606 ENGINE TO SIT IN TO A W126 IS MY PROBLEM BEFORE I PULL A NICE CAR APART
brianmccourt
aaa
03-17-2013, 10:08 PM #12
I would try the petrol m103 arms first, from the 300se. If those don't work then find om603 w126 arms from a 300sdl. Also there should be two extra boltholes in the block for 126 mount arms, might need to run a tap thru them since crud gets in with them being unused in the w124.
aaa
Druk
03-18-2013, 04:51 AM #13
Putting things up in uppercase followed by !!!!!!!! isn't going to get you an answer any quicker. Please don't 'shout'. Confused
If there are standard Merc arms that will suit the only ones are likely to be the ones from a W124 300D which shares the same angled block to your engine. This hinges on the crossmembers and engine rubber mounts of a 124 and 126 being the same. The diesel engines that were (only) fitted to the US spec 126 all have upright blocks (afaik) so it's unlikely the arms from them would work.
I have a 606 fitted in a 107 and there is no way any standard Merc arm would fit simply because the 107 crossmember is so different. I wedged the engine into it's final resting place and made my own arms from mild steel. Not too difficult if you have a welder.
[Image: enginemountings004.jpg]
[Image: enginemountings006.jpg]
[Image: enginemountings010.jpg]
[Image: feet003.jpg]
This post was last modified: 03-18-2013, 04:59 AM by Druk.
Druk
brianmccourt
03-18-2013, 05:04 AM #14
(03-18-2013, 04:51 AM)Druk Putting things up in uppercase followed by !!!!!!!! isn't going to get you an answer any quicker. Please don't 'shout'. Confused
THATS A NICE JOB
brianmccourt
THATS A NICE JOB
aaa
03-18-2013, 09:09 AM #15
(03-18-2013, 04:51 AM)Druk The diesel engines that were (only) fitted to the US spec 126 all have upright blocks (afaik) so it's unlikely the arms from them would work.
Both the m103 and om603 were angled engines fitted to the w126. The om617 was the upright one.
aaa
Druk
03-18-2013, 09:21 AM #16
(03-18-2013, 09:09 AM)aaa Both the m103 and om603 were angled engines fitted to the w126. The om617 was the upright one.
Ah, Ok ta. We dont have diesel 126's in the UK so these are all new to me. Blush
However, are you certain about the M103 being angled? Not in a Euro 107, 124 or 126 it's not.
This post was last modified: 03-18-2013, 09:22 AM by Druk.
Druk
03-18-2013, 09:49 AM #17
Get some one in the states to send you a pair of 300sdl or 350sdl w126 om603 motor mount arms they should be a direct bolt on it's a 3L inline six turbo diesel and shares the same block as the 0m606
I am currently putting an om606 in to a 1987 w126 300sdl
But try the 300se motor mount arms first they might work!
This post was last modified: 03-18-2013, 09:51 AM by willbhere4u.
hannes_s
03-18-2013, 02:02 PM #18
Your current W126 has M103 engine?
On W124 both M103 and OM603 and OM606 (N/A)- all R6 engines have same engin mount arms. So if your W126 has M103 on it than you have to use your own car´s engine mount arms.
On W201 and W124 all R4 and R5 engines also have same engin mount arms. Yes some of them have special connections for special things like fuil heat exchanger attachement (OM601 and OM602).
hannes_s
