STD Tuning Engine Big Garrett Turbo
Big Garrett Turbo
Big Garrett Turbo
TheDon
606 Power!!
247
03-16-2013, 10:51 AM #1
So I had to leave the junkyard with this today
[Image: 205259_10151277634696534_81385152_n.jpg]
It's probably too big for my 606 even if I went full on superturbo
It has no shaft play and spins freely plus it has a factory rebuilt plate on it.
I think I need to pull the housings and measure the compressor wheel and turbine and see what I have. I probably is waaaaay to big for my 606, the thing came off of a Detroit Diesel cylinder
This post was last modified: 03-16-2013, 10:56 AM by TheDon.
TheDon
TheDon
606 Power!!
247
03-18-2013, 06:28 AM #2
So I believe this is some form of GT4202R and I found a compressor map
[img]http://www.himni-racing.com/index.php?main_page=popup_image&pID=1859&zenid=k3j1s6fdd5nd0tou9sckc5ioo0[\img]
I really do wonder if this thing is useable if I go full on super turbo. Forged rods, massive inter cooler, etc
TheDon
EDH_Performance
03-18-2013, 06:47 AM #3
Take off the cover and measure the in/exducerWink It looks like a very good suited superturbo, but spool depends on how big the exhaust housing isWink
EDH_Performance
TheDon
606 Power!!
247
03-18-2013, 10:08 AM #4
The exhaust housing is large. It's off of a Semi truck engine. Plus it has no waste gate.
http://www.full-race.com/store/turbos/ga...turbo.html
[Image: garrett-gt4202r-twinscroll-turbo-content-1.jpg]
I do not think the OM606 can pump this thing up, I think.
I swear I've seen a build here where the person used a Scania turbocharger
The inducer is : 65mm
Exducer is: 90mm
This post was last modified: 03-18-2013, 12:04 PM by TheDon.
TheDon
Exducer is: 90mm
03-18-2013, 11:37 AM #5
Maybe a twin 606 car?
w123love
Stockish
354
03-18-2013, 12:05 PM #6
(03-18-2013, 10:08 AM)TheDon I swear I've seen a build here where the person used a Scania turbocharger
BSR originally used a Scania turbine
The VEGEWGN
w123love
The VEGEWGN
led-panzer
03-19-2013, 02:18 PM #7
If the exducer is 90mm it's not a 4202 (102mm compressor wheel)
1985 300D 280,000 miles RIP
led-panzer
TheDon
606 Power!!
247
03-19-2013, 04:52 PM #8
Then what is it then, any idea?
TheDon
EDH_Performance
03-26-2013, 11:04 AM #9
(03-19-2013, 04:52 PM)TheDon Then what is it then, any idea?
Gt4088 or similar maybe...
This post was last modified: 03-26-2013, 11:05 AM by EDH_Performance.
EDH_Performance
03-26-2013, 11:43 AM #10
TV4502 actually
Compressor wheel 64/92
Turbine wheel 82mm (all the way)
If the big sloppy exhaust housing was swapped for a smaller t4 .9 or something it would be a good atmospheric charger in a compound setup
TV4502 actually
dieselboy
Rotatin 5500 times a minute
680
03-26-2013, 05:39 PM #11
I have a gt4082klnv that's looking for a home.
[Image: 2B651AD1-6585-4EDF-A237-73A14C384690-123...e84a55.jpg]
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
TheDon
606 Power!!
247
03-26-2013, 07:00 PM #12
nah, I kind of wish I didn't buy the stupid thing now.
TheDon
03-26-2013, 09:59 PM #13
(03-26-2013, 05:39 PM)dieselboy I have a gt4082klnv that's looking for a home.
Been sucking in some soot?
Compressor looks a lil black
HaavardPYA
03-27-2013, 09:15 AM #14
My GT42 got "GT42" stamped on the number plate that sits just besides the oil feed line hole. Its from a Volvo truck.
HaavardPYA
dieselboy
680
03-27-2013, 12:19 PM #15
(03-26-2013, 09:59 PM)MFSuper90
[IMG]http://i1225.photobucket.com/albums/ee390/dieselboy73/2B651AD1-6585-4EDF-A237-73A14C384690-12393-00000DDA20888776_zps0be84a5
I pulled it from a ud (Nissan) truck. 2007 7.2l I6 The motor in the vnt controller died and they don't sell it separately.
The compressor has oil film from the crank case vent system. They don't do road draft tubes anymore.
[Image: E024AC4C-F069-4631-9783-DCC3C74C1768-123...2b5275.jpg]
This post was last modified: 03-27-2013, 12:19 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
03-27-2013, 01:57 PM #16
So the only thing wrong is the controller?
Do you know specs on that turbo? I can't seem to find them.
HaavardPYA
05-24-2013, 05:21 PM #17
Would this gt42 be a good turbo in an compound setup with an hx35?
HaavardPYA
05-29-2013, 06:20 AM #18
Hi,
If the gt4082klnv is catchable in god price I would built on an 6 cylinder engine! Smile
Offoraddieselhu
offroaddieselhu
Hi,
Offoraddieselhu
majesty78
05-29-2013, 10:32 AM #19
With a little playing around you can make it a mechanical VNT turbo, using a conventional push type wastegate actuator.
Or convert it to vacuum pull type VNT actuator for EDC application....
If it wouldn't be located in US, I would buy it ^^
majesty78
05-29-2013, 02:40 PM #20
it is the soul of VGT turbo https://www.youtube.com/watch?v=u74Ofbgjaoc
offroaddieselhu
swecias
HX40Super
40
05-30-2013, 10:52 AM #21
(05-24-2013, 05:21 PM)HaavardPYA Would this gt42 be a good turbo in an compound setup with an hx35?
that will be good setup for high power Smile
This post was last modified: 05-30-2013, 10:52 AM by swecias.
swecias
