STD Tuning Engine 84 and 85 turbo compatibility
cho
03-20-2013, 04:27 AM #1
hi guys
I'm considering import of used turbo for my 84 300sd
been offered turbo from 85 w123 wagon..
those two look different so I would like to know more
about compatibility issues I might come across during swap..
thank you
cho
hi guys
thank you
03-20-2013, 06:20 AM #2
That hunk on the 85 is some kind of emissions control device. There is a vacuum line coming off of it that you can plug up. I should think it will be quite compatible and an easy swap in. Just make sure to check if it spins and that the fins aren't all banged up with a wobbly shaft.
03-20-2013, 05:04 PM #3
Might try checking the turbo thread at the top of the engine sub-forum, it should show if there are any major differences
03-20-2013, 11:54 PM #4
The second pic looks like a california setup. It's just mounted in a different position though.
cho
03-21-2013, 07:50 AM #5
(03-20-2013, 05:04 PM)sassparilla_kid Might try checking the turbo thread at the top of the engine sub-forum, it should show if there are any major differences
I did. No swap data tho...
cho
Hercules
03-21-2013, 05:15 PM #6
Both will work,air valve limits turbo boost,so turbo comes on smoother.Use earlier version if possible.
Hercules
cho
03-22-2013, 05:50 AM #7
(03-21-2013, 05:15 PM)Hercules Both will work,air valve limits turbo boost,so turbo comes on smoother.Use earlier version if possible.
now I got a full picture. thanks Hercules!
cho
