STD Tuning Engine w123 om602, what pumpelements
swampmonkey
hx40 super
280
03-22-2013, 11:08 AM #1
Hey there!
got a w123 with om602turbo engine, fivespeed of modell 717430 and stock clutch, so no strong gearbox that will withstand loads of torque, and also planing to keep stock turbo.
the plan is to use it as a daily driver, and the pump is today so badly tuned due to previous owner, no idle when cold, and it sticks in high rpms when there is nothing that brings it back down, to use the engine to slow down the speed is just to forget, kinda anoying.
i want a tad more power than the stock 125 without the need to change turbo and other, how much can i get out of the engine as it is? would be very happy with about 180-190hp.
turbo now gives 1.6bar of pressure at the inlet, it has an intercooler.
talked to Göran at Dieselmeken about him moving the 6mm elements i got in a om606pump to the om602 pump, his price was 7000sek (1080dollars)
a bit to high price for me to just move from 5.5 to 6mm elements, when its about the same price people pay to get 7-8mm elements in their pumps.
my question, could i get 7.5 or 7mm elements in the pump, dial it down, and make it work with the engine? i dont want excessive amount of black smoke, regular smooth idle and so on, whats my best option?
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
Hey there!
daily driver
+ a few more.
mbturbo.com
pmj4147
T04R + TD06
42
03-26-2013, 02:59 PM #2
stock tranny, clutch, turbo
means under 7mm
5.5, 6, 6.5 could be....
i'm using 6mm but i have intermittent clutch slip issue.
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
means under 7mm
aaa
03-27-2013, 02:23 AM #3
I would get 7mm or 7.5mm. They can be dialed down easily, probably with an adjustable external rack stop.
aaa
THE DIGGER
03-27-2013, 04:40 AM #4
This guy swapped my 5.5mm elements out of my 606 n/a pump with the ones from my 606 turbo pump.
http://dieselfuelinjection.simi.ie/Contact+Us.html
He's one of the main Bosch pump agents here and does pumps for the tractor pulling guys in ireland.
I was charged 200 euro.
THE DIGGER
swampmonkey
hx40 super
280
03-29-2013, 08:15 AM #5
yeah, my plan is to go for the 7.5 or 7mm element, and dial it down, have other engines that might get a bigger turbo and better tranny in the future,
no point in paying loads of money for something that is mediocre, il get bigger elements and have the pumped turned down instead.
better for the future, same for today.
just got to find a good place to do it.
mynä, dieselmeken or someother place here in sweden, thanks guys!
daily driver
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
Kenny1813
03-23-2015, 05:03 PM #6
(03-29-2013, 08:15 AM)swampmonkey yeah, my plan is to go for the 7.5 or 7mm element, and dial it down, have other engines that might get a bigger turbo and better tranny in the future,
I'm about to buy an OM602 engine for my w201 and I live in Canada. What do you suggest doing to upgrade the pump? I have a relatively good budget, any tips?
- 1992 W201 black/grey soon with Turbo OM602        -
- 1983 Porsche 944 n/a                                            -
- 2001 Toyota Echo, my daily and tough 350 000km    -
Kenny1813
03-25-2015, 09:23 AM #7
hello,
 i can help u with that 6/7mm issue, for a lot less than 1000USD.
give me a PM.
regards.
hello,
give me a PM.
regards.
Kenny1813
03-25-2015, 09:31 AM #8
If I'm not mistaken the higher elements you have from stock parts is 6mm from a om606 pump, otherwise there is pretty much only dieselmeken that modifies elements. I tried to buy elements somewhere on the web amd didn't found some:/
Kenny1813
Kenny1813
03-25-2015, 09:33 AM #9
Ohh sorry I didn't read correctly what you wrote. You have access to 7mm element for cheaper than dieselmeken? That sounds intresting:p
Kenny1813
03-25-2015, 06:09 PM #10
well kind of everybody has access to 7mm elements , they are sold by bosch, Big Grin, they weren´t made for MB engines but they do work out.
regards...
regards...
CMP
03-28-2015, 06:52 AM #11
Hello.
Can you extend this information?
A part number would be fine and would help many people, I guess.
Thank you very much and greetings.
CMP
Hello.
Kenny1813
03-28-2015, 10:28 AM #13
After putting new elements does the pump need further ajustement? I would be suprised if its plug & play :p
Kenny1813
Petar
7.5mm M pump
459
03-28-2015, 01:34 PM #14
No, your pump MUST be recalibrated on a bench, otherwise you will never get cylinder fueling balanced.
Petar
Booster
03-28-2015, 02:38 PM #15
I never said you didn't have to, but someone asked where to buy the Bosch elements and I showed one place.
There are a few people around who will fit and balance them.
If you want the complete Proven package then go to one of the big boys manya - ppd - dieselmeken etc
Booster
CMP
03-28-2015, 05:49 PM #16
Thanks Booster.
Are these the elements that you call old ford transit type?
They are cheap, can you tell me what is the handicap?
What are the problems at idle?
Sorry if the questions bother, I read a lot in the forum and I'm not clear.
Greetings and thanks.
CMP
Thanks Booster.
04-01-2015, 10:45 AM #17
dieselkontour elements worth shit matter of speaking Smile we cal it china stuff,
ford transit are not the ones sold by dieselkontour, ford transit are made by bosch. and since there are many aplications of the bosch M series pump, in generators tractors etc, just ask a bosch dealer for them.
theorethically , any kind of M type elements will be able to work, be sinchronizable and LAST, something that dieselkontour can´t offer.
CMP
04-01-2015, 07:07 PM #18
Thanks for the explanation, barrote.
It`s a pleasure to learn with you.
Greetings!
CMP
Greetings!
