STD Other Projects OM 602 G Mercedes build for off-road racing
Pages (2): 1 2 Next
05-01-2013, 03:35 AM #1
OM 602 rebuild for off-road with GTB 22/60 VZK. (and wastegate)
This post was last modified: 05-02-2013, 06:52 AM by offroaddieselhu.
offroaddieselhu
05-01-2013, 06:19 AM #2
Turbo assembling
offroaddieselhu
Turbo assembling
05-01-2013, 09:20 AM #3
Please report back on how the cast welding/brazing goes, and what your process/materials are. I'm planning on modifying a cast manifold one day and any advice would be great.
05-01-2013, 10:05 AM #4
First we tried with TIG (AWI). But the final solution was the hot metallisation welding (maybe it is not real english expression, but i tried to translate)
This is the metallisation hot welding on an other exhaust.
This post was last modified: 05-01-2013, 10:38 AM by offroaddieselhu.
offroaddieselhu
05-01-2013, 03:18 PM #5
That's weird as hell, but looks like it did the job!
Do you have any more photos of the assembly?
Is this the method:
http://www.youtube.com/watch?v=9mCfchnJ724
http://www.aws.org/wj/nov02/feature.html
http://reneuxit-thermal-spray.com/Therma...Weld_.html
This post was last modified: 05-01-2013, 03:24 PM by Simpler=Better.
Is this the method:
05-01-2013, 04:38 PM #6
new oil pump 320 CDI
old oil pump
(05-01-2013, 03:18 PM)Simpler=Better That's weird as hell, but looks like it did the job!
Is this the method:
(05-01-2013, 04:38 PM)offroaddieselhu new oil pump 320 CDI
old oil pump
Is this the method:
Is this the method:
This post was last modified: 05-01-2013, 05:14 PM by offroaddieselhu.
offroaddieselhu
old oil pump
Is this the method:
old oil pump
Is this the method:
Is this the method:
05-01-2013, 08:42 PM #7
Beautiful!
Beautiful!
tjts1
05-01-2013, 10:34 PM #8
That looks amazing but is it going to be able to support the weight of the turbo?
tjts1
05-02-2013, 03:25 AM #9
(05-01-2013, 10:34 PM)tjts1 That looks amazing but is it going to be able to support the weight of the turbo?
I think it is easier than with iron fitting/adapter and screws. And the turbo will reach earlier the operating tempriture.
offroaddieselhu
05-02-2013, 06:47 AM #10
BOSCH VE pump
offroaddieselhu
BOSCH VE pump
05-02-2013, 02:17 PM #11
the sump
offroaddieselhu
the sump
05-03-2013, 05:10 AM #12
G off-road racing
offroaddieselhu
G off-road racing
05-03-2013, 08:10 AM #13
intake Manifold
offroaddieselhu
intake Manifold
05-05-2013, 02:22 PM #14
I'm looking for a place
(05-05-2013, 02:22 PM)offroaddieselhu I'm looking for a place
This post was last modified: 05-05-2013, 03:03 PM by offroaddieselhu.
offroaddieselhu
05-05-2013, 03:32 PM #15
Previous OM602 series nozzle http://www.youtube.com/watch?v=VvfGjbNZgLM
offroaddieselhu
05-06-2013, 05:36 AM #16
(05-05-2013, 03:32 PM)offroaddieselhu Previous OM602 series nozzle http://www.youtube.com/watch?v=VvfGjbNZgLM
http://www.youtube.com/watch?v=6WrhcuctF_Q
591 RACE
This post was last modified: 05-06-2013, 05:59 AM by offroaddieselhu.
offroaddieselhu
591 RACE
05-06-2013, 09:29 AM #17
OM602 GTB 2260+wastegate
(05-06-2013, 09:29 AM)offroaddieselhu OM602 GTB 2260+wastegate
This post was last modified: 05-06-2013, 09:30 AM by offroaddieselhu.
offroaddieselhu
05-06-2013, 04:08 PM #18
It's so purdy!!!
It's so purdy!!!
05-06-2013, 04:26 PM #19
so you can be the easiest to solve
offroaddieselhu
05-08-2013, 06:01 PM #20
an older OM602 turbo piping to error control http://www.youtube.com/watch?v=sn7jLQLrAsk
offroaddieselhu
Duncansport
05-09-2013, 08:13 AM #21
(05-06-2013, 05:36 AM)offroaddieselhu
591 RACE
Nice work your doing there, whats the scoop with the nozzles though? I wasn't aware there were different options for the 602, or what improvements they offer..
This post was last modified: 05-09-2013, 08:48 AM by Duncansport.
Duncansport
591 RACE
05-09-2013, 11:33 AM #22
(05-09-2013, 08:13 AM)Duncansport
591 RACE
Sorry, but what is your question with nozzles? ( I don't understand the english so well) Basically it has bigger hole.
This post was last modified: 05-09-2013, 12:13 PM by offroaddieselhu.
offroaddieselhu
591 RACE
05-09-2013, 01:09 PM #23
What is the effect of using these nozzles?
Will they affect timing? Quantity of fuel injected?
What do they do, how did you decide to use them, anything like that so we can learn from your parts
591 RACE
591 RACE
05-09-2013, 01:29 PM #24
(05-09-2013, 01:09 PM)Simpler=Better What is the effect of using these nozzles?
591 RACE
do not want to get into a much more accurate fuel injection
offroaddieselhu
591 RACE
05-09-2013, 03:18 PM #25
(05-09-2013, 01:29 PM)offroaddieselhu
(05-06-2013, 05:36 AM)offroaddieselhu http://www.youtube.com/watch?v=6WrhcuctF_Q
591 RACE
VE want to lower loads operated pump. higher speed perfomance expect growth
offroaddieselhu
591 RACE
05-09-2013, 03:42 PM #26
What is your power goal with that turbo?
Are you utilizing the VGT part or just using the wastegate?
At what RPM's does it start to make boost?
I think this turbo would make a good street turbo but I've heard others say it's too small for a high-revving Mercedes diesel.
05-09-2013, 03:59 PM #27
(05-09-2013, 03:42 PM)raysorenson What is your power goal with that turbo?
I know that this turbo is small for this car. But for off-road it's starts to work at critic RPM. (aprox. 1500-1600) I think to use bigger turbo is not possible. I experienced that these engines with this options are not useble in cars (only in off-road or 4x4).
offroaddieselhu
CRD4x4
CompoundSuperTurboDiesel4x4!
399
05-09-2013, 06:47 PM #28
This is some beautiful work! I'm jealous, so keep it up!
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
05-09-2013, 08:56 PM #29
(05-09-2013, 03:59 PM)offroaddieselhu I know that this turbo is small for this car. But for off-road it's starts to work at critic RPM. (aprox. 1500-1600) I think to use bigger turbo is not possible. I experienced that these engines with this options are not useble in cars (only in off-road or 4x4).
Hmmm.... I'm still not convinced it's too small for street. It makes 240hp on a low-rpm diesel with emission controls. If I could get 220hp out of a 603 and get good boost at 1500 rpm, my car would be very fun to drive with this turbo. I'm also considering using this turbo on a OM617 Toyota FJ40 with a 58.2:1 crawl ratio. If it makes any boost below 1500rpm with a 3.0L 617 it will be a great rock crawling turbo too.
05-10-2013, 02:54 AM #30
(05-09-2013, 08:56 PM)raysorenson
It could work well in OM 603, if the geometric options is good. I'm not specialist of pump (MW).
I work with VE pumps. It is possibly that with closed geometry it's blast the gear. Smile
If a rock crawling car would have place, I would put OM613 or in case of small place OM624, with any kind of geometric turbo.
This post was last modified: 05-10-2013, 02:55 AM by offroaddieselhu.
offroaddieselhu
05-10-2013, 04:01 PM #31
old oil pump
Is this the method:
old oil pump
Is this the method:
Is this the method:
scarcity of space
offroaddieselhu
old oil pump
Is this the method:
old oil pump
Is this the method:
Is this the method:
scarcity of space
05-14-2013, 05:58 PM #32
build
offroaddieselhu
build
05-15-2013, 06:15 AM #33
VGT build
offroaddieselhu
VGT build
05-15-2013, 08:10 AM #34
(05-15-2013, 06:15 AM)offroaddieselhu VGT build
offroaddieselhu
05-15-2013, 02:54 PM #36
very nice
very nice
05-15-2013, 03:53 PM #37
(05-15-2013, 02:54 PM)larsalan very nice
Smile
offroaddieselhu
Smile
Ksteen2
05-16-2013, 03:33 AM #38
looking good Wink
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
looking good Wink
1#
Originaly a d24tic
6speed cdi box
05-16-2013, 06:08 AM #39
ready for 1st start
offroaddieselhu
ready for 1st start
05-20-2013, 06:43 AM #40
https://fbcdn-sphotos-h-a.akamaihd.net/h...5316_n.jpg
(05-16-2013, 06:08 AM)offroaddieselhu ready for 1st start
(05-20-2013, 06:43 AM)offroaddieselhu https://fbcdn-sphotos-h-a.akamaihd.net/h...5316_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/h...2426_n.jpg
This post was last modified: 05-20-2013, 06:45 AM by offroaddieselhu.
offroaddieselhu
05-20-2013, 08:01 AM #41
It's aliiiiiiive!!!
It's aliiiiiiive!!!
05-20-2013, 09:31 AM #42
Big Grin
I think the setting are not so god. With big nozle too small the turbine. I have to optimalizate.
(05-20-2013, 08:01 AM)Simpler=Better It's aliiiiiiive!!!
This post was last modified: 05-20-2013, 09:33 AM by offroaddieselhu.
offroaddieselhu
Big Grin
06-02-2013, 04:33 PM #43
first test
offroaddieselhu
first test
06-03-2013, 04:29 PM #44
(06-02-2013, 04:33 PM)offroaddieselhu first test
offroaddieselhu
06-04-2013, 09:06 AM #45
As we say in 'murica, YEEEEEEHAAAAAAAAAAWWWWW!
06-04-2013, 09:36 AM #46
(06-04-2013, 09:06 AM)Simpler=Better As we say in 'murica, YEEEEEEHAAAAAAAAAAWWWWW!
It is far from the good! I haven't got any perfect turbo! It is too small!
Up to now it was small in low rpm, but recently it is small for hight rpm too.
offroaddieselhu
offroaddieselhu
offroaddieselhu
06-26-2013, 04:35 AM #47
(05-01-2013, 03:35 AM)offroaddieselhu OM 602 rebuild for off-road with GTB 22/60 VZK. (and wastegate);
and an other version OM602 engine with standard turbo and with UAZ body
[quote='offroaddieselhu' pid='52940' dateline='1372239345']
[quote='offroaddieselhu' pid='51237' dateline='1367397314']
This post was last modified: 06-26-2013, 05:11 AM by offroaddieselhu.
offroaddieselhu
06-29-2013, 12:16 PM #48
Mercedes G with UAZ body
This post was last modified: 06-29-2013, 12:18 PM by offroaddieselhu.
offroaddieselhu
07-02-2013, 12:35 PM #49
UAZ OM602 I don't like this car with original wastegate turbo
https://www.youtube.com/watch?v=6dQbo7nh...h8itXs2hZQ
offroaddieselhu
mbz123
07-07-2013, 01:35 AM #50
(05-20-2013, 09:31 AM)offroaddieselhu I have to optimalizate.
Yes, I must do this too! Looking good on the build and following closely for the turbo infos.
THX
MBZ123
mbz123
THX
MBZ123
Pages (2): 1 2 Next
