STD Tuning Engine Questions about an om617 project
Njdub
05-06-2013, 08:48 PM #1
I'm currently working on an om617 superturbo project and have been reading up a lot about pumps and turbos and want to clarify some stuff. Pretty sure I've ready sourced an 'm' pump and going to have it sent to dieselmeken. Now I need a bigger turbo and intercooler.
It looks like people are using the hx35s? The om617 is a t3 flange so this would bolt up if it is a t3 flange correct?
Also what types of intercoolers are everyone using?
Any other modifications that I might be missing?
My goal is around 200hp and it will be bolted up to an ax-15 transmission and put in a 92 isuzu pickup.
Njdub
Grecy
05-07-2013, 06:50 PM #2
What engine->trans adapter will you be using?
-Dan
Grecy
-Dan
Njdub
05-07-2013, 09:59 PM #3
(05-07-2013, 06:50 PM)Grecy What engine->trans adapter will you be using?
-Dan
I'm going to be ordering the adapter from mercedesdiesel4x4.com
Njdub
-Dan
SurfRodder
Jackass Extraordinaire
611
05-08-2013, 09:43 AM #4
(05-06-2013, 08:48 PM)Njdub bolted up to an ax-15 transmission
I would consider a different transmission for offroading...that AX-15 is not too strong and depending on the offroading you do, not as much fun to use... The AW-4 is the same bolt pattern and a good offroad trans as long as you keep it cool. The wiring for the pre-96 ones are easy as well, just grab the module under the pass. side dash and the wiring to the trans... likely a swap kit out there as well...
Anyway, an HX-35 would be a nice match, but with a modified pump you would probably want more along the lines of an HX-40.
A liquid to air intercooler would likely be easiest to route and fit under the hood, but a little more complex.
This post was last modified: 05-08-2013, 09:55 AM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
Njdub
05-08-2013, 01:23 PM #5
Thanks for the advice surfrodder but I should have mentioned this isn't a wheeler or going off road.
This truck is lowered a lot and I'm planning on air ride soon but want to put the om617 first.
Ill check out the hx40 though. I don't know much of anything about turbos so any info is welcomed.
Njdub
05-08-2013, 02:02 PM #6
HX35 turbos are crazy cheap coming off cummins, so if $$ is an issue that's always an option. Make sure you're got pyrometer and exhaust pressure gauges installed pre turbo.
This post was last modified: 05-08-2013, 02:02 PM by Simpler=Better.
Njdub
05-08-2013, 04:27 PM #7
(05-08-2013, 02:02 PM)Simpler=Better HX35 turbos are crazy cheap coming off cummins, so if $$ is an issue that's always an option. Make sure you're got pyrometer and exhaust pressure gauges installed pre turbo.
Yeah thats what i plan on doing. Just to make sure the hx35 with a t3 flange is what i want correct?
Njdub
SurfRodder
611
05-09-2013, 01:13 AM #8
(05-08-2013, 01:23 PM)Njdub Thanks for the advice surfrodder but I should have mentioned this isn't a wheeler or going off road.
That changes everything then... I hate automatics on the road, but appreciate them in the mud and sand...
OBK# 62
SurfRodder
OBK# 62
05-09-2013, 07:08 AM #9
SurfRodder, don't you think he would be better off with a hy35 because of the tighter housing?
Should Help with lowend, but the wastegate should allow plenty of topend flow also.
Just my thoughts Big Grin
yankneck696
395
05-09-2013, 08:15 AM #10
The HY would get you off the line better. Just have Goran set the pump for the turbo. Soon, I'll be replacing my HY with an HX on my 01 Cummins. It'll need a rebuild (simple) $150 shipped if you want it.
Ed
yankneck696
Ed
Njdub
05-10-2013, 10:38 PM #11
I've found a few hx35s on ebay for a fair price and am thinking about pulling the trigger. I just need to tell goran which turbo I plan on using?
Njdub
05-11-2013, 08:30 AM #12
(05-10-2013, 10:38 PM)Njdub I've found a few hx35s on ebay for a fair price and am thinking about pulling the trigger. I just need to tell goran which turbo I plan on using?
Yup, and how you plan to drive it (drag race, daily, offroad,etc)
SurfRodder
611
05-13-2013, 10:12 AM #13
(05-09-2013, 07:08 AM)MFSuper90 SurfRodder, don't you think he would be better off with a hy35 because of the tighter housing?
you're correct...generally a smaller exhaust housing is better on smaller engines like ours, I didnt even think about it as he was asking if the hx would work with a modified pump.
(05-08-2013, 04:27 PM)Njdub Just to make sure the hx35 with a t3 flange is what i want correct?
Since I havent seen this addressed yet (maybe Im just being blind, tho):
Yes, both the HY and HX should have a T3 flange.
This post was last modified: 05-13-2013, 10:15 AM by SurfRodder.
OBK# 62
SurfRodder
OBK# 62
Njdub
05-14-2013, 07:32 PM #14
(05-13-2013, 10:12 AM)SurfRodder
Thank you for all the info surfrodder!
Njdub
snowbrd84
05-16-2013, 03:48 PM #15
So an hy35 will bolt up to the OM617??
I put an OM617.951 in my Jeep with a 3 speed auto. My off the line acceleration sucks until it gets a little boost. Would the hy35 spool up faster and be a better turbo ??
snowbrd84
05-16-2013, 03:51 PM #16
(05-16-2013, 03:48 PM)snowbrd84 So an hy35 will bolt up to the OM617??
I don't think so, but I'm not 100%. If you want faster boost a VNT will deliver.
05-16-2013, 09:28 PM #17
faster than the stock garrett or kkk? No.
The hy35 has a much larger intake and turbine wheel than our stock turbos. (40mm I think, vs. 56mm inducer) Takes alot more exhaust gas to turn the bigger wheels even though it has a small exhaust housing. Faster than an hx? for sure.
dieselboy
Rotatin 5500 times a minute
680
05-17-2013, 01:03 PM #18
This is a hy35 on a om617
http://youtu.be/QrNzlMRq7XU
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
