STD Other Projects w201 steering rack conversion
HughF_UK
05-09-2013, 11:43 AM #1
As many of you know, my 606 201 project has stalled a bit because I couldn't fit the downpipe past the steering box. Here are some pics of where we are at with the rack conversion:
Steering rack album
HughF_UK
Steering rack album
Druk
05-10-2013, 09:01 AM #2
That's pretty cool... but how are you going to get that past an MOT inspection which now requires there to be no modifications to original chassis/steering/or suspension components?
This post was last modified: 05-10-2013, 09:01 AM by Druk.
Druk
05-10-2013, 09:05 AM #3
I'm sure if its done tidy nobody would ever notice.
HughF_UK
05-10-2013, 10:40 AM #4
(05-10-2013, 09:01 AM)Druk That's pretty cool... but how are you going to get that past an MOT inspection which now requires there to be no modifications to original chassis/steering/or suspension components?
I'm planning on having to BIVA it Sad
HughF_UK
Druk
05-10-2013, 10:56 AM #5
(05-10-2013, 10:40 AM)HughF_UK
What's involved with a BIVA and is that a one-of process and a standard MOT thereafter...or what?
Druk
HughF_UK
05-10-2013, 11:19 AM #6
I won't go into the nitty gritty but basically:
Make *any* change to the monocoque and you immediately get called for a BIVA. This is like and SVA test, but different.
If you are not changing the monocoque, just things like engine, gearbox, suspension etc, then at the time you submit the amended V5 to the DVLA, they will schedule an appointment for the car to be inspected and assessed on a points system. You start with so many points and loose a certain number for each thing you have changed. If you have less than a certain amount at the end of the inspection, then the car is technically no longer original so will end up on a Q plate.
If you want more info, there is bucket loads on google. I'm basically expecting the following to happen:
1. Submit V5 with new engine number, fuel type and CC - Done a few weeks back
2. Get letter from DVLA requesting inspection
3. Rock up to inspection, they notice monocoque choppy choppy and immediately say it is time for a BIVA
4. Submit to BIVA - pass, hopefully, as the car has already got German type approval (this is a bit of wishful thinking on my part)...
The reason for the wishful thinking is thus: PPC did a roof chop on their 2003 Bentley, it had to go for a BIVA and failed as loads of stuff like interior switches didn't meet type approval standards, despite the fact that the car clearly had European type approval as it was manufactured after 1998.
HughF_UK
hooblah
05-15-2013, 04:28 PM #7
Hugh how is the rack conversion progressing? I cant make out a lot from the pics! In depth details would be nice Wink
hooblah
