STD Tuning Drivetrain Trans Upgrades for an 85 300d?
85-300D
05-24-2013, 10:55 AM #1
Just wondering what auto trans upgrades are available for my 85 300d. Are there many options. I am thinking of trying to make some power with it, but am unfamiliar with this trans and what can be done with it. Thanks.
Mike
85-300D
Mike
SurfRodder
Jackass Extraordinaire
611
05-24-2013, 11:57 AM #2
lots of upgrades... the same basic trans is used in higher HP cars... but you are unlikely to need anything special for a stock OM617 and even a fairly upgraded 617 likley wouldn't overpower a fresh rebuilt trans done by a competent shop...but while theyre in there... I understand the urge to overdo it!
OBK# 62
SurfRodder
OBK# 62
85-300D
05-24-2013, 12:37 PM #3
Thanks for the reply. I am thinking of trying to squeeze some power out of the 617 - just not sure how crazy I want to get yet. The past two diesel trucks I have owned have been 609hp, and 670hp, at the wheels. Where is a good source for the good trans parts?
85-300D
05-24-2013, 01:03 PM #4
You can get a shift kit, there is info over on PP.
For manuals, there is the 240D 4spd, the impossible euro 5spd, or swap in a BMW getrag, toyota supra, gm whatever, etc. box with an adapter plate.
05-24-2013, 01:10 PM #5
The '85 already has a higher stall T.C. than the other w123's. I think the shift kit is called "superior". There are adapter plates out there for the 617 that open up a lot of other options.
85-300D
05-24-2013, 01:59 PM #6
Will the shift kit allow for much more power capacity? What upgrades will hold roughly 250hp at the wheels? I am guessing some sort of performance t.c, clutches, separator plates, shift kit/valve body, ...?
85-300D
05-24-2013, 04:37 PM #7
I think at that point you'll also be talking about converting the driveshaft's flex disks to some beefier metal part or change to a u-joint setup.
Or take your chances. But, we've all seen them rubber discs blow out and a driveshaft whipping up into the chassis.
cue the flex disc upgrade linkz...
85-300D
05-28-2013, 07:39 PM #8
Yeah, flex disc upgrade info would also be helpful. What exact model of trans is this anyway?
85-300D
SurfRodder
611
05-29-2013, 12:53 AM #9
(05-28-2013, 07:39 PM)85-300D What exact model of trans is this anyway?
pretty sure its a 722.3 someone else will either corroborate or correct that...
OBK# 62
SurfRodder
OBK# 62
05-29-2013, 10:35 AM #10
I think the Californica '85 cars had different transmissions than the '85 federal cars.
05-29-2013, 11:50 AM #11
'85 Cali has the 722.416 trans. '85 Feds got the 722.303 for the 300sd and 722.315 for the 300d.
85-300D
05-29-2013, 09:04 PM #12
I did a search for upgrades for the "722.315" and couldn't come up with anything...
85-300D
85-300D
05-31-2013, 09:55 AM #14
Thanks for the link. It looks like that kit corrects some shifting issues with the stock trans. Are there any parts that will allow the transmission to hold additional power?
85-300D
05-31-2013, 01:26 PM #15
I take "firm" shifts to mean more pressure applying the friction bands/clutches, which means more torque capacity, so this will be a performance upgrade. I recommend against doing anything to soften 2nd gear on an '85 trans. MB already fixed the harsh 1-2 shift issues on the '85. If anything, you'll want to firm it up.
SurfRodder
611
06-04-2013, 04:28 PM #16
generally the firmer the shift, the better it is on the trans as well...
OBK# 62
SurfRodder
OBK# 62
06-05-2013, 10:32 AM #17
From what I've read, increase the modulator pressure if you're getting slippage. This is done from outside the transmission with a gauge pretty easily. I don't know what long term impacts this will have, but it should fix slippage.
FWIW I always ran my transmission with 0" vacuum (various reasons). I always just let off as it started to shift. If I kept flooring it i would get the classic bangshift
This post was last modified: 06-05-2013, 10:39 AM by Simpler=Better.
SurfRodder
611
06-05-2013, 10:39 AM #18
Slip = heat and sloppy shifts
Excessive heat = trans damage
OBK# 62
SurfRodder
OBK# 62
