STD Tuning Engine 606 275 HP. possible
zeeman
06-07-2013, 12:54 AM #1
I have a customer that wants to upgrade a 80 300SD to a 606 engine. He wants 250-275 HP. What upgrades are needed to get this HP, can it be done with a bigger turbo and injectors? Or will the injection pump need bigger plungers also. I appreciate any input.
zeeman
swampmonkey
hx40 super
280
06-07-2013, 05:15 AM #2
(06-07-2013, 12:54 AM)zeeman I have a customer that wants to upgrade a 80 300SD to a 606 engine. He wants 250-275 HP. What upgrades are needed to get this HP, can it be done with a bigger turbo and injectors? Or will the injection pump need bigger plungers also. I appreciate any input.
Om606 turbo, mechanical pump with elements changed is a start to achieve 250something.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
Mark_M
06-07-2013, 07:38 AM #3
As above, bigger turbo and either change the elements and get a remap or change to a mechanical pump with bigger elements. Injectors wont need changing.
Mark_M
zeeman
06-07-2013, 08:08 AM #4
(06-07-2013, 07:38 AM)Mark_M As above, bigger turbo and either change the elements and get a remap or change to a mechanical pump with bigger elements. Injectors wont need changing.
What size elements would work, the stock in the mechanical pump are 5.5mm. Are the elements available in the states so they can be installed here. Also what turbo would be adaptable, is the stock exhaust manifold large enough or would a header need to be fabricated? Thanks for all the input.
zeeman
HaavardPYA
06-07-2013, 09:18 AM #5
I think a HY35 would be a good turbo for that power. Early spool also.
I would guess the orginal manifold with new flange will hold to that power, but i dont know that for sureSmile
HaavardPYA
95e300dez
95E300td
89
06-07-2013, 10:49 AM #6
Hey zeeman I have a upgraded pump and a hx35 it is real close to 275 at the rear wheels. I can show it to you some time and if my trans holds up I will give you a ride. The next thing you will need after the engine build will be a better transmission.
95e300dez
zeeman
06-07-2013, 12:57 PM #7
(06-07-2013, 10:49 AM)95e300dez Hey zeeman I have a upgraded pump and a hx35 it is real close to 275 at the rear wheels. I can show it to you some time and if my trans holds up I will give you a ride. The next thing you will need after the engine build will be a better transmission.
I am on the other Northern end of the state in Bayview, who did your pump modification? Did you adapt the turbo to the stock exhaust manifold? I am going to use a GM 4l80E transmission, www.transmissionadapters.com just stated making a GM trans adapter for the 606. I appreciate the info.
This is what I do. www.northwestdieseloffroad.com
zeeman
95e300dez
95E300td
89
06-07-2013, 01:15 PM #8
Dieselmeken did my pump and it is real nice he is a great guy to work with. I made a header for the turbo it is a little crude didn't have the tools I have now but it works. Did you get a price for the adapter I would use the 4l80 if it fits under my car 95 e300.
95e300dez
zeeman
06-07-2013, 01:30 PM #9
(06-07-2013, 01:15 PM)95e300dez Dieselmeken did my pump and it is real nice he is a great guy to work with. I made a header for the turbo it is a little crude didn't have the tools I have now but it works. Did you get a price for the adapter I would use the 4l80 if it fits under my car 95 e300.
Was it a hassel sending the pump to him, what was the cost and the turn around time. I have seen some of his blogs. seems like a great guy to deal with, impressive shop. The adapter is $795.00 which includes the gear drive starter and GM flex plate. The 4l80E is about 2 inches wider then the Merc. trans. Looks like I might have to open the tunnel a little towards the rear of the pan.
This post was last modified: 06-07-2013, 02:01 PM by zeeman.
zeeman
95e300dez
95E300td
89
06-07-2013, 02:02 PM #10
I shipped the pump for 98 to him he got it in 10 days. He moved shops and still had the pump rebuilt and had it to me in just a day over a month. He is all moved into his shop turn around would be at least a week less. It was almost as easy as using a local guy I used skype to call him and he said to call him with and questions or if I need help. That is quite a bit of money for the adapter I could get a 722.6 or nag1 and stand alone controller for just a couple hundred more then that. I was going to use the android controller from olefejer. What controller do you have for the 4l80? Also don't really want to modify the floor to fit.
(06-07-2013, 01:30 PM)zeeman
Was it a hassel sending the pump to him, what was the cost and the turn around time. I have seen some of his blogs. sees like a great guy to deal with, impressive shop. The adapter is $795.00 which includes the gear drive starter and GM flex plate. The 4l80E is about 2 inches wider then the Merc. trans. Looks like I might have to open the tunnel a little towards the rear of the pan.
This post was last modified: 06-07-2013, 02:02 PM by 95e300dez.
95e300dez
zeeman
06-07-2013, 03:01 PM #11
(06-07-2013, 02:02 PM)95e300dez I shipped the pump for 98 to him he got it in 10 days. He moved shops and still had the pump rebuilt and had it to me in just a day over a month. He is all moved into his shop turn around would be at least a week less. It was almost as easy as using a local guy I used skype to call him and he said to call him with and questions or if I need help. That is quite a bit of money for the adapter I could get a 722.6 or nag1 and stand alone controller for just a couple hundred more then that. I was going to use the android controller from olefejer. What controller do you have for the 4l80? Also don't really want to modify the floor to fit.
The 4l80E has an overdrive and a lock up converter as well as a better gearing for the diesel. This would improve fuel economy and drivability. I will use a TCI or PCS controller. When I talked to PCS they said I would need the 722.6 shifter, speed sensor and throttle position switch to make it work. You probably have the later trans in your car already compared to the earlier trans in the 80 SD.
I am still not committed to the 4l80E if the 722.6 would work and hold up to the HP. Is the 722.6 a 4 or 5spd. trans. How well does the android controller work?
What was the price of the I.P. work from him?
This post was last modified: 06-07-2013, 03:40 PM by zeeman.
zeeman
95e300dez
95E300td
89
06-07-2013, 05:28 PM #12
1040 euro that included shipping home that is about 1350$ compete read ready to go at home.
95e300dez
zeeman
06-07-2013, 07:31 PM #13
(06-07-2013, 05:28 PM)95e300dez 1040 euro that included shipping home that is about 1350$ compete read ready to go at home.
Thanks for all the info, is that price fairly current. What is the best way to contact him about shipping a pump?
zeeman
95e300dez
95E300td
89
06-07-2013, 11:25 PM #14
I had my pump done in middle march paid him middle April I haven't checked the exchange rate lately but it shouldn't be that far of from what I paid. I have him liked on Facebook and communicated with him on there. He is also on here send him a pm. He adds a outside alda and tunes sets it to what you ask I am might send him another pump if I do another car or project 300cd like 95 or similar year.
(06-07-2013, 07:31 PM)zeeman
95e300dez
HaavardPYA
06-08-2013, 07:19 AM #15
You can contakt Dieselmeken at facebook or at his website. He is also a member of this forum. Username: dieselmeken.
Wery helpful and good service!
HaavardPYA
