STD Tuning Engine VNT turbo
VNT turbo
VNT turbo
Gforce
06-09-2013, 12:16 PM #1
i bought a used VNT turbo, owner didn't know where it came from but it was cheap so i bought it. it has a 45mm compressor wheel and 65mm turbine wheel, exhaust flange is T3, on the compressor housing is a nr with a mercedes star on so i gues its from mercedes, does anybody know what type and if its good for an om617 in a G for off road?[Image: 406897470.jpg]
[Image: 406897472.jpg]
[Image: 406897473.jpg]
[Image: 406897474.jpg]
[Image: 406897478.jpg]
Gforce
06-09-2013, 07:48 PM #2
45mm inducer, that thing would be super quick spool being a vnt!
Correct me if I am wrong but I believe stock is around 40mm, so that turbo should work nicely in my opinion Smile
Gforce
06-09-2013, 09:53 PM #3
that would be great, should it work with just a boost actuator to control it?
Gforce
aaa
06-10-2013, 12:04 AM #4
Wow a t3 vnt, pretty cool.
Boost actuator would not be ideal, without some sort of throttle input you'd have to avoid fully closing the vanes (which is kinda the point of a vnt). I'd like to throw out the idea of EGP actuating, seems like it might be less likely to bog the engine down while still closing the vanes as much as possible.
aaa
06-10-2013, 10:08 AM #5
A mercedes t3 vnt! Can you type those part numbers in for those of us with old eyes?
majesty78
06-10-2013, 10:30 AM #6
Its a 466520-0001 loooooong, very loooong time out of production.
Actually at this time VNT didn't even officially exist ^^
majesty78
Gforce
06-10-2013, 11:07 AM #7
I already guesed its not the original compressor housing
Gforce
06-10-2013, 11:11 AM #8
If your not very electronically inclined (like me), you could do a spring setup. With a mechanical stop to keep it from closing completely
Gforce
06-10-2013, 11:47 AM #9
But how can i control boost pressure with a spring?
Gforce
06-10-2013, 12:50 PM #10
DIY boost controller:
This post was last modified: 06-10-2013, 12:52 PM by Simpler=Better.
majesty78
06-10-2013, 03:06 PM #11
(06-10-2013, 11:07 AM)Gforce I already guesed its not the original compressor housing
How do you come to this conclusion?
majesty78
Gforce
06-10-2013, 03:32 PM #12
Because i can't find any mercedes turbo's that look like that and the person i bought it from said he bought it from a tuning company
Gforce
06-10-2013, 03:34 PM #13
(06-10-2013, 11:47 AM)Gforce But how can i control boost pressure with a spring?
Having good spool up and being able to control boost with a spring setup is tough.
Most people do it on setups which are meant to make maximium boost the turbo/ fuel setup will allow.
Gforce
06-10-2013, 03:42 PM #14
i think i will make a setup with trottle and boost, when on full trottle vanes are fully closed and then when boost is created the boost acurater will push the vanes open, trottle will be connected with a spring
Gforce
SurfRodder
Jackass Extraordinaire
611
06-11-2013, 08:56 AM #15
I always thought the way Lance did it was intriguing and would likely do something similar if I ever get far enough ahead of the power curve to install mine:
http://www.superturbodiesel.com/std/show...ND+control
he also has some updates/insights posted on whatever forum he was last hanging around at...if he didnt wear out his welcome over there yet...
OBK# 62
SurfRodder
OBK# 62
Gforce
06-18-2013, 02:17 PM #16
i have the vnt mounted on the om617, if the oil lines where a bit longer they would fit straight on. now i need to find a solution to connect it to the intake manifold. I also have a water cooled intercooler lying around but i don't know if it is ok for this engine?I am also gona send my pump to dieselmeken for 7,5mm elements
[Image: 406993778.jpg]
[Image: 406993781.jpg]
this is the car its getting on
[Image: 406993780.jpg]
Gforce
06-18-2013, 04:08 PM #17
(06-09-2013, 12:16 PM)Gforce i bought a used VNT turbo, owner didn't know where it came from but it was cheap so i bought it. it has a 45mm compressor wheel and 65mm turbine wheel, exhaust flange is T3, on the compressor housing is a nr with a mercedes star on so i gues its from mercedes, does anybody know what type and if its good for an om617 in a G for off road?[Image: 406897470.jpg]
it can build a good turbo (need to know the size and geometry of the shaft)
offroaddieselhu
