STD Other Pics and Videos Good Idea? or.... Bad Idea?
SWL300SDL
300SDL Super Turbo / Prius Killer
35
08-12-2013, 11:30 PM #1
So I removed the air box, and I assuming the AFM. I then installed a Specter air filter on the inlet tubing that goes to the turbo. When I am driving there is a little more power, however when I back off the throttle from boost it sounds like a ricer blow off valve. Question is... is this ok to run the car like this or am I a complete idiot and I need to put the air box & afm back in? Still learning here with the diesels & turbos. Here are some pics.
[Image: 20130812_210520_zpsc08abc85.jpg]
[Image: 20130812_210551_zpsae746c76.jpg]
1987 Mercedes 300SDL Super Turbo Restore/Project
SWL300SDL
08-13-2013, 08:15 AM #2
The Spectre/K&N/random eb*y filters aren't that great but they get the job done. As long as it's oiled and you know that it's not the best filter in the world, you're fine.
There are big paper filters that can be easily attached to straight pipes without air boxes.
Isn't the turbo sound fun? Big Grin
bricktron
'77 240D
174
08-13-2013, 10:46 AM #3
what does a ricer blow off valve sound like?
i have the airaid equivalent here and am looking forward to deleting the huge 85 CA filter canister... if i can prove that the small one works well enough. as long as boost reaches the desired level it means there is enough air coming in, right?
bricktron
08-13-2013, 11:27 AM #4
(08-13-2013, 10:46 AM)bricktron what does a ricer blow off valve sound like?
Just get a filter minder, and install it between the filter and turbo. When the filter gets restricted, the filter minder is sucked in and turns red-showing you that the filter is too restricted.
jellydonut
1987 W124 250D
21
08-14-2013, 10:48 PM #5
The sound you hear is turbo surging, and it's the sound ricers wish their cars made. A blow-off valve just sounds like a whistle, air leak, or someone farting. The turbo surging sound is entirely different.
It's perfectly okay to run the car like this, but using an air box or at least some sort of barrier between the filter and the rest of the hot engine bay is better than the filter sucking hot air from around the engine.
This post was last modified: 08-14-2013, 10:49 PM by jellydonut.
jellydonut
SWL300SDL
35
08-15-2013, 02:41 AM #6
I defiantly need to get the filter away from sucking hot air. I just didn't want any permanent modifications until being sure it was ok to run like this. I plan to run a innercooler once I can track down a euro exhaust manifold and HX35.
So another question. What are the things I have circled in red? I am assuming they are some emissions crap. Are they something I can remove? or should I leave them?
[Image: 20130812_2105201111_zps453afb14.jpg]
This post was last modified: 08-15-2013, 02:48 AM by SWL300SDL.
SWL300SDL
Purplecomputer
Slowness 220D
897
08-28-2013, 01:27 PM #7
I used those on a few cars when I didnt know much.
They suck in hot air and will never be as efficient as the stock on. Most of the stock ones are enclosed and have pipes leading to the outside of the car. sucking the cold air.
Purplecomputer
