STD Tuning Engine Mechanical CDI engine
TvaiX
09-03-2013, 03:04 AM #1
Hello,
Wanted to ask, maybe somebody know something about this project:
http://www.ebay.co.uk/itm/321188234230
I didn`t know that its possible to make mechanical common rail engine.
Technically that is good and works. Maybe somebody can comment how it`s done. Pump, injectors...?
At last I bought right mechanical pump from Germany any day to send it to me. Was thinking to send it in winter to Myna for rebuild, but starting to get curious maybe switch better for that money from Om605 to 270CDI or 320CDI, depending weight...
thanks,
Casper
TvaiX
Hello,
thanks,
Casper
Tito
09-03-2013, 06:29 AM #2
I don't think it's that hard to build one. Get a pump and some injectors that fit an your basically done. Set pump timing.
However the modern common rail Diesel engines have a very smooth combustion compared to a mechanical ip. A common rail Diesel engine can have up to 5 injections in a single compression/combustion stroke. For smooth running and regeneration of an partial (?) filter.
So I thing internals are going to take a beat with those hard knocking mechanical injectors.
This post was last modified: 09-03-2013, 06:30 AM by Tito.
Tito
09-03-2013, 06:43 AM #3
HEUI systems were the very beginning of common rail systems, they were mechanical.
I think it could be done mechanically, but not as well as modern day common rails
09-03-2013, 03:11 PM #4
(09-03-2013, 06:43 AM)MFSuper90 HEUI systems were the very beginning of common rail systems, they were mechanical.
hi
simpler and always works
offroaddieselhu
offroaddieselhu
hi
offroaddieselhu
TvaiX
09-03-2013, 03:51 PM #5
(09-03-2013, 06:29 AM)Tito I don't think it's that hard to build one. Get a pump and some injectors that fit an your basically done. Set pump timing.
There is mention of some Bosch E-Pump, don`t know what it is...
Yes, user have pointed to day about common rail diesel smooth combustion and mechanically can damage engine pretty fast maybe...
Also, he thinks that it is possible convert mechanically, but no better than OM606 or OM605... and those can survive more and get more power comparing common rail...
The question is so, what was the point to make mechanical CDI engine?
Was thinking maybe somebody understands here...
Or maybe that's evolution, harder to get old last era engines and now starting to convert mechanically CDI engines... Smile
TvaiX
anjay
1998 E300 Turbodiesel
57
09-03-2013, 09:46 PM #6
Sounds like someone converted CDI engine to mechanical IP. Most likely in order to avoid CAN while doing convertion.
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
1989 300TE - parts
09-04-2013, 06:03 AM #7
Hi,
In the comperison of OM605 and OM606:
The direct diesel engine is much more usable than the OM605 or OM606 for offroad purpos. It's heat harder and much more torque.
I don't think that any damage would be for CDI engine from VE pump.
I think for off-road is only benefits if you have not so much electric parts.
I know the builder of this car.
Offroaddieselhu
offroaddieselhu
Hi,
Offroaddieselhu
09-04-2013, 08:09 AM #8
Mechanical > electrical if you want power without spending $$$,$$$,$$$. This isn't any different than removing the TBI from a v8 and adapting a performance carburetor back in the 80's. One day DIY CDI will be affordable but it really isn't right now.
Mark_M
09-04-2013, 11:27 AM #9
(09-04-2013, 06:03 AM)offroaddieselhu Hi,
Offroaddieselhu
You're right but I think the CDI engines are like that more because of the fuel injection that the mechanical parts.
Personally I think if you converted to mechanical pump you would end up with little more than a 606. Pretty sure it wouldn't give you anything like enough of an advantage to make it worth all the effort. DI engines don't rev so you would be loosing a good chunk or RPM for a start. Far better to keep it common rail and buy an aftermarket ECU. It would probably cost about the same as well.
Mark_M
Offroaddieselhu
09-04-2013, 12:36 PM #10
(09-04-2013, 11:27 AM)Mark_M
Offroaddieselhu
Hi,
I think the cammonrail is not the best choice in 1 m height water.
For me the setting an Ve pump is much more easier than to write a chip by somebody, whom I explain what i would like to reach.
Offroaddieselhu
offroaddieselhu
Offroaddieselhu
Hi,
Offroaddieselhu
TvaiX
09-04-2013, 06:03 PM #11
I`m little curious to try to put common rail in my offroad Gwagen... Smile But I`m concerned about beating internals what Tito mentioned. Also if really torque is bigger, it revs lower, so, maybe not so big advantages in common rail mechanical engines...
That builder published his Dyno, maybe somebody can comment about his power better?
Offcourse for 1m underwater in offroad I want best mechanical engine with less weight and also I converted my car to 24 volt for faster electric winch... No glow plugs for OM605 24volt Sad
Somebody maybe know weight differences for OM606/OM605 and OM647/OM648 ?
Offroaddieselhu if you know that builder, maybe can you ask, does in pictures that is w463 PTO? Smile How I understand Mercedes build it on paper, but not build in real life...
TvaiX
AlanMcR
mind - blown
400
09-06-2013, 02:36 PM #12
(09-04-2013, 06:03 PM)TvaiX I`m little curious to try to put common rail in my offroad Gwagen... Smile But I`m concerned about beating internals what Tito mentioned. Also if really torque is bigger, it revs lower, so, maybe not so big advantages in common rail mechanical engines...
The OM606 G with electronic controls is easily good for 3M of water. The electronics are sealed and mounted pretty high up. You would need to raise the air intake (and not care about stinky carpets).
AlanMcR
majesty78
09-06-2013, 03:17 PM #13
Mercedes released a stripped down G320CDI for such purposes.
All electronics are located in cabin, no carpets and pretty much everything else waterproof.
Not cheap fun though IIRC about €120.000.- as new....
majesty78
TvaiX
09-06-2013, 04:37 PM #14
(09-06-2013, 03:17 PM)majesty78 Mercedes released a stripped down G320CDI for such purposes.
You think MB G EDITION PUR?
I like all mechanical, less to think about, don`t need to ask somebody to write me a map, etc, etc... Smile Don`t have problems when for instance in offroad alternator stops to work, don`t have problems with chip heating... So only mechanical for me.. Smile
My G can now go without electric at all, even stops mechanically...
So thinking about mechanical CDI project possibility...
What injectors to put for mechanical VE pump swap?
TvaiX
EDH_Performance
09-06-2013, 08:08 PM #15
here is one bmw m57d30 commonrail engine with bosch A-pump (now gørans M-pump), and volvo direct injectorsBig Grin
http://www.superturbodiesel.com/std/thread-2973.html
EDH_Performance
09-07-2013, 02:20 AM #16
(09-06-2013, 08:08 PM)EDH_Performance here is one bmw m57d30 commonrail engine with bosch A-pump (now gørans M-pump), and volvo direct injectorsBig Grin
It ís not suitable for every dai use (what is it for?)
offroaddieselhu
offroaddieselhu
offroaddieselhu
EDH_Performance
09-07-2013, 02:17 PM #17
(09-07-2013, 02:20 AM)offroaddieselhu
offroaddieselhu
It is a race car, but more driveable now with gørans bosch m-pumpSmile
EDH_Performance
offroaddieselhu
HaavardPYA
09-07-2013, 04:06 PM #18
Can you mix the a-pump to m-pump, visa versa?
HaavardPYA
09-07-2013, 06:27 PM #19
hy fine people,
the answear for your questions is "caterpillar 3116 engine" common rail first generation, no electrics needed. why dont u consider using one in a g car?? , torque, hum this engine use to move the D6 bulldozer, and many other stuff alike !! the question is have u a strong enough transmission?
regards
hy fine people,
regards
EDH_Performance
09-07-2013, 07:14 PM #20
(09-07-2013, 04:06 PM)HaavardPYA Can you mix the a-pump to m-pump, visa versa?
No, A-pump is big and slow, around 3000rpm!
EDH_Performance
TvaiX
09-08-2013, 01:31 AM #21
(09-07-2013, 06:27 PM)barrote hy fine people,
regards
1. MOT problems Smile My offroad car still street legal...
2. Weight is big importance in offroad. Thats why I even use 5cyl not 6cyl engines...
TvaiX
regards
09-08-2013, 10:38 AM #22
So basically this is not a CDI anymore, but a 3.2l direct injection engine. MB build this themselfes: 602.982 / OM602 DE29LA. Which would be my choice for a transplant...
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
TvaiX
09-08-2013, 03:23 PM #23
(09-08-2013, 10:38 AM)DiseaselWeasel So basically this is not a CDI anymore, but a 3.2l direct injection engine. MB build this themselfes: 602.982 / OM602 DE29LA. Which would be my choice for a transplant...
OM606 is DOHC, OM602 is SOHC, don`t see what is better in your choice only worth...
TvaiX
09-08-2013, 03:58 PM #24
More valves = better? In that case I'm out...
DiseaselWeasel
EDH_Performance
09-08-2013, 04:01 PM #25
605 with 602.968 pistons, remove the prechambers and insert direct injectorsBig Grin ^^
EDH_Performance
09-08-2013, 04:14 PM #26
(09-08-2013, 04:01 PM)EDH_Performance
Huh
offroaddieselhu
Huh
09-08-2013, 10:12 PM #27
(09-07-2013, 07:14 PM)EDH_Performance
Not all of them are! Several guys run a-pumps on their pulling tractors and run 5000+rpm!
09-09-2013, 12:25 PM #28
I won't shoot down any idea-if you can make it happen go for it. As long as you're building it and having fun. No one likes stock engines Big Grin
09-09-2013, 12:46 PM #29
(09-08-2013, 04:01 PM)EDH_Performance 605 with 602.968 pistons, remove the prechambers and insert direct injectorsBig Grin ^^
You could add a cylinder whilst you'r at it ;-) That'll certainly sound like a big rig Big Grin I love the diesel sound of E290: http://www.youtube.com/watch?v=15aNaski_1I
DiseaselWeasel
