STD Other Projects Brainstorming - OM606 Turbo into 2wd Chevy S-10
Jetmugg
09-11-2013, 02:00 PM #1
I've been away from this site for a while, but definitely not away from diesels.
My daily driver is still a '93 W201 Mercedes with an OM602 turbo and 5-speed drivetrain.
About 2 years ago, I started in on a diesel land speed racing project (1.5L VW turbodiesel in a Dodge Rampage truck). I was hoping to be at the Bonneville Salt Flats right now, but we have been rained out until the next meet (World Finals in October).
Anyway, I'm already daydreaming about the next potential project, which I'm envisioning as a '94-up Chevy S10 with an OM606 turbo / Superpump type setup.
Trying to think through the issues I might encounter with a project like that (will the engine physically fit, what type of transmission should be used, etc). In terms of transmissions, I'd consider anything from an MB 5-speed manual, to an MB 4-speed auto, to a GM turbohydro automatic, to whatever!
Just thinking out loud right now, and looking for your thoughts as well.
Steve.
Jetmugg
Steve.
09-11-2013, 02:43 PM #2
The inline engines are tall, so you might have to mess with the front suspension (I'm not familiar with 2WD S10s).
If you want it to be easier, use a GM transmission coupled to HD u-joints. the rubber merc flex joints are a failure point.
The 606 will scream wiht an aftermarket exhaust manifold and larger turbo/ IP. Excellent choice
CRD4x4
CompoundSuperTurboDiesel4x4!
399
09-11-2013, 04:30 PM #3
Yo Jetmugg,
I'm a big fan of this idea! In fact, I've got the perfect truck for it and it happens to be for sale. I'll let it got for thousands under bluebook!
86k mile '03 GMC Sonoma SLS 2.2L auto RWD with extended cab & color matched Leer cap.
1 owner (my dad), no accidents, no rust, clean/clear title.
I've got enough cars/trucks taking up precious room in my driveway. I've gotta get rid of the gassers and make $$ for my 617a/606a projects!!
Damn! I thought I had pix on my phone! PM me if you're serious.
I wanna see this come to fruition!!
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Yo Jetmugg,
Jetmugg
09-11-2013, 04:38 PM #4
I'm quite serious about this project, but need to run what I have already built first.
[Image: DSC_1866_zps9d83deef.jpg]
[Image: DSC_1864_zps1b0e01ea.jpg]
I currently have a 1.5L VW diesel installed in this truck, and would like to build a 1.9L VW to run in the next larger class as well.
The next larger displacement break comes at 3.0L, which is where the OM606 S10 would come in. Coupled with a GM transmission and all the suspension options for this type of vehicle, I think I could build a pretty nice one for less than I have in my Rampage pictured above.
The thing about an S10 that's so attractive is that they are cheap and plentiful. They are also a solid base for building as a performance platform. Searching Craigslist in my area, I can find examples as low as $500 with bad engines.
That makes it tough to justify traveling any significant distance for an S10 that would be serving mainly as a "roller" donor anyway.
Steve.
Jetmugg
Steve.
CRD4x4
399
09-11-2013, 05:02 PM #5
Wow! You sure are serious! That's some nice looking work!
I agree that its a great platform to build from. I also agree that you should find line of those $500 S-10s! Mine is road ready and has a stupid high bluebook value. I don't understand how they hold their value so well.
You don't see a Rampage everyday! Here's one for sale on Baltimore:
http://baltimore.craigslist.org/cto/4031174445.html
Have you considered an early Jeep CJ as a chassis? It's what I'm going to be using. It's already setup for a straight 6 and can be made very lightweight.
(09-11-2013, 04:38 PM)Jetmugg I'm quite serious about this project, but need to run what I have already built first.
Steve.
CRD4x4
Steve.
Jetmugg
09-11-2013, 05:37 PM #6
What I'd like to do is run at Bonneville & Wilmington, OH in the F/DT class, which is F (engine size 2-3 Liters), DT (Diesel Truck). I'm getting ahead of myself, but it doesn't cost anything to daydream.
So, it pretty much needs to be a "letter of the law" truck to meet the rules of the sanctioning bodies. The Rampage is just about the smallest thing that fits the land speed racing definition of a truck.
The downside is that I would not be allowed to convert the Rampage from FWD to RWD to run in the larger engine sizes. I can figure out how to run in the 2 liter class, but just thinking ahead, it would be extremely difficult to get a 3 liter diesel mounted in the Rampage's engine compartment and retain the FWD arrangement.
That's why I'm just brainstorming about the S10 / OM606 combination.
Jetmugg
EmJay
09-11-2013, 06:24 PM #7
The only thing that I worry about with your idea is that the length of the engine. My build, for example, is a OM602 in a Mazda B2000. The size of the engine bay between my Mazda and an S-10 are pretty similar, maybe 3 inches MAXIMUM difference. The I-5 engine fit in my engine bay nice and snug, but I had to push the radiator up INTO the cowl instead of mounted ON the cowl. I am having a hard time seeing the 6 cylinder fitting in there without firewall modifications.
This post was last modified: 09-11-2013, 06:24 PM by EmJay.
EmJay
1911diesel
09-11-2013, 06:28 PM #8
if your looking for something smaller then an s10 but could still take the om606 try an subaru brat. they are about rampage size and RWD. and no one else will say they have seen another one.
sorry turns out its AWD...
This post was last modified: 09-11-2013, 06:29 PM by 1911diesel.
1911diesel
EmJay
09-11-2013, 06:43 PM #9
who cares if a brat is AWD, they can be converted to RWD pretty easily. Just use a GM transmission and diff and boom.
This post was last modified: 09-11-2013, 06:43 PM by EmJay.
EmJay
Jetmugg
09-11-2013, 06:45 PM #10
Firewall mods are allowed. As a matter of fact, there's a team running a 6cyl Cummins in an S10 at Bonneville (larger displacement class, obviously)
Jetmugg
EmJay
09-11-2013, 06:50 PM #11
(09-11-2013, 06:45 PM)Jetmugg Firewall mods are allowed. As a matter of fact, there's a team running a 6cyl Cummins in an S10 at Bonneville (larger displacement class, obviously)
I WANT!!!
EmJay
I WANT!!!
1911diesel
09-11-2013, 06:58 PM #12
well anyways nice work. i had never seen a rampage i liked until i saw yours. i hope you break some records! good luck on all your adventures and with all your projects!
1911diesel
Jetmugg
09-11-2013, 07:20 PM #13
Greenspeed truck - 1200HP 5.9 Cummins in an S10
http://www.youtube.com/watch?v=1-sppj29AzY
Jetmugg
