STD Tuning Engine OM617 STT Slow return to idle after IP adjustments (w460 1986)
znej
10-03-2013, 12:17 PM #1
Hi!
After tuning my M- pump I have a problem with slow returning to idle speed.
I have read that adjusting the "vertical throttle stop", probably would fix my problem.
But I cant really find that screw? Does it exist on the M- pump, or is it only on the MW- pump?
[img][Image: IMG_20131003_182425_zps2eafbe5f.jpg][/img]
[Image: IMG_20131003_182518_zps46dec2eb.jpg]
[Image: IMG_20131003_182439_zps7b40840e.jpg]
Ifound these two screws inside the IP. Some kind of internal throttle stop?
[Image: IMG_20131003_182712_zps806ca1c8.jpg]
[Image: IMG_20131003_182749_zps2ab49200.jpg]
znej
Hi!
OM616
10mm MW
572
10-03-2013, 04:18 PM #2
(10-03-2013, 12:17 PM)znej Hi!
Nothing in the Doc that uses the term "vertical throttle stop" has anything to do with the M pump. That Doc describes only the MW/RW, ( pump/Governor), combination. I know this because I generated the Doc.
I suggest that you stop and find out what to do before you proceed. Essentially, you have more throttle pressure on the governor at the idle setting than you want. I have no idea how to reduce the throttle pressure on the M pump. Sorry
OM616
swampmonkey
hx40 super
280
10-03-2013, 05:51 PM #3
make sure the linkage returns to zero.
other than that, you went to far with the dialing up, go back a bit and it will be better.
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
OM616
10mm MW
572
10-03-2013, 07:25 PM #4
Dieselmeken would be the one to ask.
If the RSF governor is truly limited by it's ability to be adjusted, then put 1 point in the + coulomb for the RW Governor... Plenty of ability for balancing the return to idle after an adjustment... Even really radical ones Smile...
OM616
znej
10-03-2013, 07:28 PM #5
You mean i increased the max- fuel too much? Is it no possibilities to make it return fast to idle without decreasing the max-fuel amount?
Does anyone know what the two internal screws on the pictures are for?
Ops! I didn't read your post OM616. Yes, i have sent a question to Göran. Hoping for a easy solution Wink
This post was last modified: 10-03-2013, 07:32 PM by znej.
znej
