STD Other Projects Tito's w114 with OM606, HX40 and 8mm dieselmeken pump.
  • 2 Vote(s) - 5 Average
Pages (3): 1 2 3 Next
Tito
10-19-2013, 10:28 AM #1
Hi guys, Little introduction, I'm Rico, I'm 23 years old and a expert mechanic. I'm from The Netherlands an live aprox 1km from the german border. I've always been a mercedes freak but somehow i stumbled upon team Black Smoke Racing. After checking engine mod's and other vid's I made the decision to build one. Bought a donor car, And a W123 chassis. Later I bought a W124 chassis again because of the constant changing road tax laws for older car's here.
I've finally finished my project. Have been busy with it for almost 2 years. Almost everything is homemade. De engine is a om603.912. So it's the natural aspired type. The pump is homemade and calibrated by a diesel shop. I've bought the HX35w new for 350 euro, which i think is a bargain. It has a 3.5" exhaust till about the rear axle and then continues 3" with a Simons 3" muffler. I will be upgrading to a 606 engine in the future.
The car has 525.000 km in the speedo.
[Image: null-5.jpg]
[Image: E31A7A5A-1AB2-4967-875F-4448ABF109BC-705...001FB8.jpg]
[Image: IMG_0013.jpg]
It's running 1.4 bar boost. and smokes tires nicely Big Grin
I'm having 2 problems at the moment, One is where the engine doesn't get enough fuel it it's warmed up and second is that the tranny flaires (it's that what you call it?) when shifting to second gear.
This post was last modified: 01-03-2016, 02:02 PM by Tito.
Tito
[Image: null-5.jpg]
10-19-2013, 01:59 PM #2
What type of lift pump are you using to feed your 7mm pump? And at what pressure?
mantahead
10-19-2013, 03:49 PM #3
some guys talk about modifying pressure relief valve spring in gearbox to increase oil pressure. Not sure if this will work so don't quote me on it.Huh
mantahead
10-20-2013, 09:10 AM #4
Yeah, shift flare, or just slipping. Superior trans parts makes a shift kit for the 722. If you're going to stick with the 722, I'd get a trans from a turbo car, build it, install a shift kit and raise line pressure so much that it shifts hard enough to break your neck.
Tito
10-20-2013, 02:15 PM #5
I'm still using the stock lift pump. So that is probably the fuel supply problem. I want to change to a electric feed pump from a ordinary gasoline car. Those are about 3 bar.
I've checked the oil level of the tranny and it was way to low. Filled her up and she shifted nice and solid. But after some time it came back. Haven't checked the oil level though but there's no external oil leak. If I can't fix it I'll swap it for a manual.
Tito
10-20-2013, 09:33 PM #6
Be careful with gas feed pumps, some can't handle the thicker viscosity of diesel and crap out after a short time
Ksteen2
10-21-2013, 02:41 AM #7
good prodject!
I have done the same thing Wink
but with a kkk turbo with the same size.
if you use bosch 044 pump, it can handle the diesel fuel, and it can hold the pressure.
change to a manuell tranny, you loose so much power in the automatic.
good job, keep the good work up and inform us Wink
and maybe a video of it?
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
good prodject!
1#
Originaly a d24tic
6speed cdi box
Tito
10-21-2013, 05:25 AM #8
I think already have a 044 pump laying around here somewhere. Need to search for it.
At first I wanted a automatic transmission but now I'm crying for a manual tranny. If I can't fix it I'll swap an manual tranny. What will be a good clutch-tranny setup? Keeping in mind the future upgrades?
Tito
10-21-2013, 12:37 PM #9
Are you measuring your boost before or after the IC?
Tito
10-21-2013, 01:29 PM #10
After the IC in the collector pipe.
Tito
10-22-2013, 08:36 AM #11
I am Teeing off the ALDA and never see more than 8psi. I do not believe I have any leaks at this point. Sounds like a good opportunity to measure elsewhere. Thanks! I found that bar and plate IC btw.
Tito
10-22-2013, 02:31 PM #12
Nice, but looking true your topic quickly, don't you already have that style intercooler mounted below your license plate? Or am i confused with the meaning of an bar and plate intercooler? Or did you need a narrower one to fit between the headlight unit?
Tito
10-22-2013, 03:31 PM #13
Mine is a delta tube and fin and I suspect that it is the cause of my PSI loss.
Ksteen2
10-23-2013, 03:10 AM #14
the original 300E 240mm clutch can take it, I have a beaten 228mm blutch from a 300D and it only slipps when I try do kick it into a burnout ;p
and i have 1.5 in boost.
so a 300E 240mm will do just fine Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
Tito
10-27-2013, 01:08 PM #15
Tranny is scrap. Shift flare is extreme at the moment. And the last gear starts to flare to. A shame... the tranny was just 124.000km old. Oh well... I guess I can do some burnouts. I love burnouts.
http://www.youtube.com/watch?v=oMKNDXJtlCA
Tito
Ksteen2
10-28-2013, 02:53 AM #16
little offtopic that might help winmutt.
I t'ed off the alda valve myself, and got a masive wrong reading in boost, then I made a hole in the intake and use'd boost from there, then the boost was fine again, mayby you should try that also?
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
EDH_Performance
10-30-2013, 04:34 AM #17
Hi,
just wondering...How did you get all 6 elements tuned equally regarding fuelsupply on low idle?
EDH_Performance
Hi,
Tito
10-30-2013, 06:16 AM #18
I didn't calibrate the pump myself but brought it to a diesel shop. Or am I missing something? Could be that it's not done at all. Runs ok though...
Tito
EDH_Performance
10-30-2013, 06:51 AM #19
(10-30-2013, 06:16 AM)Tito I didn't calibrate the pump myself but brought it to a diesel shop. Or am I missing something? Could be that it's not done at all. Runs ok though...
No, then i think it is okayWink Seems to be a feedsupply problem then!
EDH_Performance
Tito
10-30-2013, 07:00 AM #20
Yeah I bet it is. I got an Bosch 044 pump. Just need a fuel pressure regulator on the outlet side of the pump. That'll fix it.
Also I met a guy with a merc scrapyard. He wants my 2 w123
Petrol and diesel car, looking for a trade for a good manual swap kit.
Tito
Tito
12-17-2013, 01:19 PM #21
Did some fine tuning on the pump which turned out very well. Better spool up and way more hp. I've hit 2.5 bar Big Grin
http://www.youtube.com/watch?v=pdj13aJxSGI
So that killed the tranny completely. And now it has a 717.430 gearbox. I love it Big Grin But clutch can't handle it. (if you can help me out: http://www.superturbodiesel.com/std/Thre...utch-setup )
Going to save up some money for a 606 now.
This post was last modified: 12-17-2013, 01:19 PM by Tito.
Tito
Tito
12-30-2013, 12:27 PM #22
Santa was late this year.. Got myself a 606 today Big Grin It was just 350 euro.
[Image: F655162B-6240-4BBD-9A00-3A4D9B2C9C4C.jpg]
[Image: 0F718769-3D21-440F-A319-6C94F13EDAEC.jpg]
Yeah, manifold is missing. So gonna make me a custom one...
Tito
12-30-2013, 04:11 PM #23
Sigh. I dream of that kind of pricing.
Tito
12-30-2013, 07:09 PM #24
Normally these engines are about a 1000~1200 euro's. I got this one from a guy who offered it to me. This is the first one I've ever seen in my life. They seem quite rare to me over here. I guess I'm a lucky guy. The hx35w was the same price and it was brand new Big Grin how much money do you have to pay for a 606 over there? I don't expect much more?
This post was last modified: 12-30-2013, 07:11 PM by Tito.
Tito
Tito
01-01-2014, 10:22 AM #25
Happy new year everybody! Did some nice burnout's yesterday.
[Image: 130DC77A-AEDB-46C7-858F-6472285A97DF.jpg]
Tito
Tito
02-20-2014, 03:56 PM #26
Hey guys.
I've been gently stripping the engine and I found a n/a intake manifold for a bargain.
Everything seems good so far. I'm still not sure if I should pull the head or not... It looks quite messy down the intake. And the valves do have some pressure loss. I want to start it on his engine mount but will the oil leak out the cooler lines or is there a thermostat between the oil cooler?
And what is this huge gap in the cooling system above the fuel pump?
[Image: FC69BD80-C865-47F6-83BE-2ECAC5F51878.jpg]
Can I just plug it? Can't imagine it being something important
Also still thinking about compound charge. Either by a supercharger or the stock turbo/smaller turbo. Any opinion? I want to build this thing nice and decent and not quickly build like the current engine (engine still runs great! Killed 2 driveshafts). Got a spare pump which I will ship to dieselmeken.
Oh yeah and some exhaust manifold bolts snapped off. Need to fix that....
Tito
Hey guys.
02-20-2014, 04:33 PM #27
I dont think I have ever seen that gap. Whats the last 3 digits of this engine model?
canyondrift
02-21-2014, 01:23 AM #28
The fuel thermostat is placed in the gap actually. I dont know is it only the euro models, but all 606.912-s that I have seen have the fuel thermostat.
You can plug it by making a plate and connecting the fuel line directly to the filter housing. And if you plan to use 603 pump, then the piping would be absolutely different from the 606 original electronic pump. Fuel filter housings are changeable.
Check the fuel lining and you will see what is missing.
canyondrift
Tito
02-21-2014, 06:17 AM #29
You're right! There where some fuel lines running that way.
I'm going to use the pre-pump diesel stuff from the 603, with a 044 pump.
Tito
Tito
03-30-2014, 05:46 AM #30
Check out this extremely redneck throttle setup Big Grin
[Image: 6D63EEC0-046C-46C9-B0F1-B24134DD042B.jpg]
Yeah.... i know..... Blush
i was just wondering if it would be possible... It works okay. The system only works on full throttle. So the rest of the time the pump functions normally. The power is just awesome. 2.5 bar. Engine still hasn't blown up yet. gonna make me a better version today. I didn't think the blow-by would throw out so much oil
Tito
mbz123
03-30-2014, 09:16 PM #31
Could be a bit beefier, but looks fine. And I'm not even a redneck, eh. Thicker/higher strength cable OR better be certain you have enough spare in the trunk.
DAMN that's a leaky basterd! Are you sure that's only blow-by? If so, how is it ending up completely covering IP side of engine??? By the looks of it, you might need a seal or two on that pump or maybe the intake?
Are any of those bolt locations for the side plate non-factory?
MBZ123
mbz123
MBZ123
Tito
03-31-2014, 05:15 AM #32
It looks like a thin cable but it's okay. The stress on the cable isn't that high.
The pump and engine where completely leak free before I made this. In the valve cover there's some kind of tube so keep the oil in the engine. With the plunjers moving at speed they splatter oil everywhere. And since there's a huge gap in the side cover now it just blows it all out.
Side plate bolts are all factory. The cable holder is just screwed on there with some washers underneath it. For some reason there's a pop-rivet in the cover of the pump. Dunno why....
Tito
mbz123
03-31-2014, 05:13 PM #33
Ya, I would get the correct breather tube (at minimum the fitting) connected to your vc. To be thorough, you should check the function of the separator that exists inside top of the vc and confirm everything is ok.
Then get that breather tube routed to afiltered catch can or at least to the ground temporarily. Unless you insist on having that massively messy anti-rust feature!
mbz123
Ksteen2
04-05-2014, 12:06 PM #34
get some burn outs on Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
Tito
04-06-2014, 03:41 AM #35
It needs 4 new tires. But I have some nice rims laying around which I want to refurbish. I'm not going to spend any money on these old dirty rims. But I'm lazy so I'm running spare tires on the back. Which is actually great fun :-D
Tito
Lesorub44
04-06-2014, 04:51 AM #36
Hello.
I am from Russia. Found yours forum, when I find pictures of installations of intercoolers on w124.
Tell me what size of intercooler fits between headlights?
550*230*65 ?
Thank you.
This post was last modified: 04-06-2014, 04:53 AM by Lesorub44.
Lesorub44
Hello.
550*230*65 ?
Thank you.
Tito
04-06-2014, 06:47 AM #37
I will look for you. Going to my garage now where the car is parked.
Tito
Lesorub44
04-06-2014, 08:03 AM #38
Its joke? )))
In Russia all "ill" people hand-made turbo only fo russian cars, and nobody, who make turbo for merc, despite what merc124 is popular car in our contry too.
Whether I should show my project, hot it is in the very early stage?
This post was last modified: 04-06-2014, 08:13 AM by Lesorub44.
Lesorub44
Its joke? )))
Tito
04-06-2014, 02:31 PM #39
No joke from me :-D I had some stuff to do on the car so I was riding my scooter this weekend.
The with of the intercooler is 62cm. It's 28.5mm high and 8cm thick.
So 620*285*80. I did not count the hose connections. Those fit under the headlight
Tito
04-06-2014, 10:03 PM #40
What kinda scooter?
What kinda scooter?
Tito
04-07-2014, 03:06 AM #41
A Gilera Stalker. Some kind of 50cc Italian brand scooter. Bought it once for very cheap and on sunny days I go cruising with it.
This post was last modified: 04-07-2014, 03:06 AM by Tito.
Tito
Lesorub44
04-07-2014, 10:33 AM #42
Thank you, Tito
Lesorub44
Thank you, Tito
Gearbound
In need of a OM606.96x
172
04-08-2014, 02:04 AM #43
350 euro for a 606 lol I wish the states had those for even $1500
Gearbound
Tito
04-09-2014, 12:04 PM #44
Got my dieselmeken pump back today. Looks great!
[Image: 575F1031-B68A-4164-AF78-CBB8F1897B41.jpg]
[Image: 3278E568-FF42-4262-BDCB-BA096D32AB73.jpg]
Took the engine apart, but my cheap 12 pointed torx socket snapped. So the head still needs to come off
Going to give it some new piston rings and just look if everything is fine. Maybe some new rod bearings if they are little worn. The camshaft looks like new after + 250000 km's... Amazing.
When do you need stronger valve springs? + 3bar? And the rods? I know they're though but at which hp is it a wise move to upgrade them? It will be a daily driver.
This post was last modified: 04-09-2014, 12:04 PM by Tito.
Tito
saquzi
04-09-2014, 01:58 PM #45
That pump looks so sweet... :p
Where did you find the 7mm elements on your diy pump? Dieselkontor.de or somewhere else?
saquzi
Tito
04-09-2014, 03:07 PM #46
I was going to order the elements from Dieselkontor.de but got some problems with the bill send over by e-mail. (Later got the same problem with dieselmeken, The problem was that i was using a phone). So i ordered the elements from a dutch diesel tuning shop. I thought it was Dutch Pump Performance (DPP). Costed me twice as much as dieselkontor.de Undecided
This post was last modified: 04-09-2014, 03:09 PM by Tito.
Tito
Ksteen2
04-09-2014, 05:19 PM #47
the rods in the 606 are proven ad benched at 700hp Wink
at least from what the ovner says Wink
the valve springs is not realy a problem if you dont get over the original rpm's Wink
if you get a, say 7000rpm pump, you might need to consider it Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
Tito
04-09-2014, 11:49 PM #48
Thank you Ksteen2. I was thinking of using stronger springs, but i'm not going to push 7000rpm so i'll keep the stock ones.
Tito
shadowmaker
04-11-2014, 01:49 AM #49
EMP (and valve area + weight when something other than OEM is used) is the other significant factor beside rpm when it comes to valve springs.
After 6500rpm there are more severe issues than just valve springs to solve.
shadowmaker
Tito
04-11-2014, 03:18 AM #50
I know. That's why I'm a little scared holding 3 bar of inlet pressure and make sure the valves stay shut. Isn't the intake valves that take the most beating? On the current engine the emp is about 2 bar and my intake 2.5 bar.
Tito
