STD Tuning Engine w202 220cdi swap turbo
turbi
02-12-2014, 04:54 PM #1
Hi people, my name is Freddy and i write from portugal. I have a w202 220cdi with 125 hp and a normal turbo and i am thinking to change it for a vnt turbo because their lag. What i need to change,and how i control the vnt turbo? Then i think do a electronic repro offcourse,but i don't know how i control the vnt. Sorry for my english.
turbi
02-12-2014, 05:57 PM #2
Olefejer's transmission controller can also control a vacuum actuated VNT.
http://www.superturbodiesel.com/std/Thre...22-6-ver-2
turbi
02-13-2014, 02:55 AM #3
Thanks for the response. Thats a good idea... Iam thinking to swap my ecu for a w202 146hp one, but i dont know if it is posible and thats a lot o job i think,because the sensors and ezs unlock.
turbi
F.R.A.S
02-13-2014, 07:07 AM #4
How is the boost controlled on the stock turbo? Should be pulsated vacuum or boost. Either way you can control the VNT with the same technique. If there are no boost control stock on these cars you can do a manual boost control using a Dawes Device and some vacuum hoses.
Swapping the ECU sounds like a bad idea, better then to swap the software for one that's made for your new setup.
A Garrett GTB2556V should be a good upgrade for you.
F.R.A.S
turbi
02-13-2014, 07:50 AM #5
The stock turbo os controled by a vacuum valve. To swap the software what do i do? I have a mpps and winols, but the mpps dont read my ecu, thats return me an invalid key error just at the begining, and i dont know why. My ecu is a edc15c5. I try to build a kwp2000. Thank you very much and sorry for my english.
turbi
bruno_pinho
02-13-2014, 08:10 AM #6
Boas
Eu acho que fazias melhor em anular a valvula de vacuo original do carro e mudavas o turbo que comprasses para trabalhar por pressão...
bruno_pinho
Boas
turbi
02-13-2014, 08:27 AM #7
Yes,but a vnt turbo isnt controled by presion but by vacum or electric.and i search a geometry turbo for the lag..
turbi
F.R.A.S
02-13-2014, 09:00 AM #8
I need to have your ECU in front of me to give you a good answer. But here is the theory Cool
Either you need to put the ECU in boot mode to read it with the MPPS or there is a eeprom chip and not a flash chip in the ECU.
You have OBD2 in the car? The MPPS usually tell you what to do, if you need to put the ECU in boot mode or not.
Safest way is to access the ECU by BDM though.
(02-13-2014, 07:50 AM)turbi The stock turbo os controled by a vacuum valve. To swap the software what do i do? I have a mpps and winols, but the mpps dont read my ecu, thats return me an invalid key error just at the begining, and i dont know why. My ecu is a edc15c5. I try to build a kwp2000. Thank you very much and sorry for my english.
You can control a VNT with the vacuum, that's no problem.
(02-13-2014, 08:27 AM)turbi Yes,but a vnt turbo isnt controled by presion but by vacum or electric.and i search a geometry turbo for the lag..
F.R.A.S
02-13-2014, 02:25 PM #9
Boas camarada turbi,
o meu amigo deixe-se de VNT e coisas afrodisíacas, meta ai um turbo do 300 d e feche a waste gate (sempre fechada), resolve logo o problema do lag.
mas depois disto feito , vai ter de se preocupar com EGT, e pressão na turbina, a pressão n turbina é fácil de fazer barato, uma mola ou duas em função do que pretende. a ideia é ter sempre a waste gate fechada , quando a pressão na turbina (back pressure) subir a mola deixa passar alguns gases e está feito. quanto ao EGT e melhor instalar uma coisa dessas se tem intenção de mexer no combustível de carga. n há milagres o meu 605 estoirou com 5 min a 850 ºC.
boa sorte
FD
boa sorte
FD
turbi
02-13-2014, 03:09 PM #10
I dont have obdII port but a 38 pin, and the mpps tell me where is the port, read the type off ecu but dont read the ecu, give me a invalid key error in the begining.
Barrote, your idea is good, but closing the wastgate we have a high presion and the pistons dont like that, i think the best way is put a bigger turbo and keeping the presion stock or a little more for more volume of air than my stock turbo. I have a renault 5 gt turbo and i know the pistons doesnt like high presions lol and the w202 is now my daily car and to play a little in track day and i need a fast response and a durability car.
turbi
02-13-2014, 03:36 PM #11
buy a 911Wink
buy a 911Wink
turbi
02-13-2014, 03:45 PM #12
Lol that isnt an option lol see the video of smokeracing and tell me then to buy a 911 or tuning my benz lol
turbi
02-14-2014, 06:35 AM #13
black smoke is just unused fuel down the pipe, u can do the same in a gas engine , will be a bit costly but can be done.Wink
turbi
02-16-2014, 09:22 AM #14
Hi, i have read something about dawes device and this is a very simple way to control the vnt turbo. Arduino is another choice and swap my software of the ecu is more complicated i think, because i dont know if my ecu accept this changes and how i do this.. For the moment i will search and dawes device and a turbo to experiment and a hardwar to do a repro for my ecu and a egt sensor to view how is de mixture.
turbi
Punchi
02-19-2014, 06:58 AM #15
What year is your w202, and what number is your ecu?
Do u have a plastic or steel admission?
Cheers,
Punchi
Cheers,
turbi
02-20-2014, 08:59 AM #16
My w202 is to year 2000, the last ones and admision is in steel. Ecu number i dont know. I will try view it this night with the mpps. Cumps
turbi
turbi
02-20-2014, 05:15 PM #17
Hi, i less hear thats mpps gives me:
Hardware id: A0001531379
hardware number: 4298
software number: 1899
is that what you want?
turbi
turbi
05-01-2014, 04:30 PM #18
Well i had read my ecu with kwp2000+. Now i will do a remap with the stock turbo and then with a vnt turbo of a w203 cdi. How many can i upload my turbo pressure for safe?
turbi
turbi
08-16-2014, 03:27 PM #19
Hi, i have done my first remap with the stock turbo...a litle remap lol how is the safe max boost for the garret gt20 turbo? I put this at 1,3 bar.. Original is 1.18...
turbi
08-18-2014, 11:37 AM #20
hy there , did u measured 1.3 BAR ? or did u told the ECU to cut fuel at 1.3 BAR? as emergency cut of?
by the way how´s the power after that remap?
turbi
08-21-2014, 02:31 PM #21
Hi, in the turbo map i change the value of 1.18 for 1.3 and in the "n75" map i change the values... I dont know because i dont have an dinamometer in my city... But i need to know if is safe for that turbo a 1.5 or 1.6 bar.. If not, i need to change it for another, because the car is a little smooky...
turbi
08-22-2014, 07:11 AM #22
hy there ,
boost pressure depends a lot on the compressor capacity, and then ofcourse there is load charge, exaust gas through the turbine, i can´t squeze more than 1.2 , 1.3 BAR out of my GT 20 , but i´m not smoking black yet , next month i will load it a bit more to see if i succed to get 1.5 BAR.
Thats why is important to measure boost press, usually ECU controls max boost as a limitation on the system instead of alow the sytem to go to a desired max boost Wink
anyhow don´t u have a boost gauge? u should fix one in the car.
regards
hy there ,
regards
turbi
11-02-2014, 05:03 PM #23
Hi, thaks for the response... I have a gauge to see the boost but, dont instaled in the car... If i put the wastegate directly to vacuum the presure mount up to 1.6 bar...now i need to remap the n75 map another time.. I'm thinking in put a gt2359. Turbo in my car and a bigger ic...
turbi
11-08-2014, 03:04 PM #24
(11-02-2014, 05:03 PM)turbi Hi, thaks for the response... I have a gauge to see the boost but, dont instaled in the car... If i put the wastegate directly to vacuum the presure mount up to 1.6 bar...now i need to remap the n75 map another time.. I'm thinking in put a gt2359. Turbo in my car and a bigger ic...
hy there!!!
good news , i have a IP at 90cc, and a 2359v, it works well. very well pressure goes easily to 2.0BAR. still have a leak at intake stage. what i have found was high EGT , well above 600ºC , i dont want to see where it will go Wink
my engine is a 605 with mech IP.
hy there!!!
bruno_pinho
11-09-2014, 05:54 AM #25
(11-08-2014, 03:04 PM)barrote
hy there!!!
Boas
90cc? 6mm elements?
I was to also use a 2359v but I ended up using a 2559v but have not used more than 1.5bar still gets a lot of black smoke backwards, I have to use very close to 2bar.
This post was last modified: 11-09-2014, 06:05 AM by bruno_pinho.
bruno_pinho
hy there!!!
Boas
90cc? 6mm elements?
starynovy
11-09-2014, 06:32 AM #26
Do you guys use proper vane control? Boasting about pressure on VNT turbo makes me smile, unless you talk about fully open vanes. Also take a good look at garrett pages, since compressor maps are available you can see what pressure it can take. Ive been using 2256V and its good for some 1.6Bar then IAT rose greatly as it left eficient area of map, exactly according to garretts graph.
starynovy
bruno_pinho
11-09-2014, 06:57 AM #27
(11-09-2014, 06:32 AM)starynovy Do you guys use proper vane control? Boasting about pressure on VNT turbo makes me smile, unless you talk about fully open vanes. Also take a good look at garrett pages, since compressor maps are available you can see what pressure it can take. Ive been using 2256V and its good for some 1.6Bar then IAT rose greatly as it left eficient area of map, exactly according to garretts graph.
Shut the solenoid vacuum the car and I changed the turbo actuator vacuum
by a pressure actuator,so I can control the pressure I want manually...
bruno_pinho
starynovy
11-10-2014, 10:20 AM #28
And thats incorrect way to do it which causes pressure drop on partial load and higher fuel consumption at all times.
starynovy
anjay
1998 E300 Turbodiesel
57
11-10-2014, 01:42 PM #29
(11-10-2014, 10:20 AM)starynovy And thats incorrect way to do it which causes pressure drop on partial load and higher fuel consumption at all times.
It is many ways to controll VNT. Some are more successful than others. How are you doing it?
Anjay
1987 300TD - tinker toy
1989 300TE - parts
1991 300TE - backyards decor
1991 300TD - Barrote’s 7.5
1998 ML320 - snow ride
anjay
Anjay
1989 300TE - parts
tuikku
11-10-2014, 02:54 PM #30
270cdi vacuum controlled vnt, 2256 is good upgrade for that.
Gives enough air to other orig parts, CR-pump and injectors.
Very tiny turbo lag.
Made many.
Little mods needed to to make it work.
Conrolling is easy, just put the orig vacuum line into "new" turbo, and let the softw tuner do the job.
If everyting is in suberb condition, ~450nm/200hp.
Autom is better than man (clutch).
tuikku
Made many.
bruno_pinho
11-10-2014, 04:26 PM #31
(11-10-2014, 02:54 PM)tuikku .
Made many.
I think the ecu the W202 2.5td can not control turbo vnt, even though the original controlled vacuum...
bruno_pinho
Made many.
tuikku
11-10-2014, 10:52 PM #32
The orig thread was from 220cdi ...
But with 250 works too, need only a bit bigger vnt-turbo, like 2359 (320cdi).
Easy sw-mod.
220cdi => read/write with cable
250 => soldering job
tuikku
Easy sw-mod.
11-11-2014, 08:11 AM #33
hy fellows,
crap crap , who the hell want to have control over the vanes control (maybe those wich dont understand a &$# how the control is made on the VNT) , i want 3 BAR and i get it with the vanes locked at certain position which is at max speed of the flowing gas. thats what maters to me. The same goes for the 90cc IP, does not idle correctly who cares is not for idle.
VNT turbos are just the same as the others, depending on the soft your car has to control it, u can play on the maintnance of a good relationship Exaust Gas pressure / Boost produced. on the other hand (P*V/T) when ever the pressure raises temperature will raise too , hapens for boost and for EGP, line production veicles almost never have a chart of the software dedicated to control EGP/EGT relationship, so u have to write one, or fit a gauge and do it yourself lifting the foot. For the boost control modern cars have soft charts for boost control, and not only. many cars have electrically actuated Vanes and as many pressure controled vanes or vacum controled vanes, matters litle if a car does not have soft charts for it.
i belive for STD issues wich is what this fórum is about, we want boost pressure and power so , i did fabricate a device with a screw wich fixes the vanes in the best position for my aplication, i have no soft charts to change . my engine runs as a 70thies diesel engine. let me tell u , very few black smoke and i have seen many BMW over the rearview mirror.
well, i can control it with vacum and pressure, to maintain it inside specs(graph), but the thing is: does it woth the trouble? i can´t see any gain in controling the vanes other that keeping the turbo inside specs. my goal is using sucesfully ouside specs, it is what u are about too right?
hy fellows,
starynovy
11-15-2014, 05:49 AM #34
Fix vanes in some position? What is that? Big Grin VNT turbos were created so big turbo which is capable of delivering enough air will not have 5s lag, and thats exactly what you did by fixing vanes.. whats the point of VNT then? Go with wastegated version and you are happy.
I control vanes so desired pressure is available ONLY when its needed thus reducing fuel consumption, and its quickly for use. Thanks to not fixed geometry I build pressure instantly, floor the pedal and tires burn, not waiting 5s with black smoke behind my ass like an idiot. Make your research on how true VNT equipped engine controls its turbo-not so straight forward as it would seem.
This post was last modified: 11-15-2014, 05:55 AM by starynovy.
starynovy
tuikku
11-15-2014, 11:54 AM #35
Yes
Thanks
With turbo vanes and revs ecu conrolls the whole boost system.
If you want good working, it must be controlled.
And in to W202 ecus, edc15c5 (cdi) and msa15 (250), controlling is very easy to build.
I have done many cdi´s.
tuikku
Yes
Thanks
11-16-2014, 04:21 PM #36
[quote='starynovy' pid='67760' dateline='1416048598']
hurggg, yes boss!!!
please would u explain "us" "idiots with the vanes fixed" how would we use a VNT device in a 1970 car?
ps: idiot is a person with ideas Wink
hurggg, yes boss!!!
turbi
01-31-2015, 05:47 PM #37
Hi!!!! Finaly i have build and mounted my gt2359v from a 320cdi like tuikku said on her post in other forun. Now the problem is the lag and control the presure...i think i have my vnt map localized, but i can't do the right modifies on the map to control the turbo...tuikku for this turbo what are the right iq for 1.4, 1.5 bar presure in this turbo? Now i drive with 83of iq... Can you see my file and tell me if my vnt map is the right map or not? I try some changes and i think it is but i'm not an expert in this things lol
turbi
