STD Tuning Engine CRI2-20 injektors
CRI2-20 injektors
CRI2-20 injektors
Turbo
02-19-2014, 05:16 PM #1
Does any one here knows where to get hold of Bosch solenoid valve type injectors CRI2-20 injectors that has size like Part number is A6120700287 Bosch 0445110 151 or ...152 Mercedes c30 AMG, this ones is only good for 1800bar and I want to use cp3/cp4 pump to use 2000bar rail pressure for tuning om648
Tried for some time search for Bosch HADI (Hydraulically Amplified Diesel Injector) injectors information after 2005 but I guess it is easer to find penguin on the north pole. I spoke with Bosch in Sweden but did not want to say more then some mercedes trucks start to use that system...
I am buying a Mercedes 320 cdi upcoming weekend so want to start collecting for upcoming project
tips is highly appreciated
Turbo
Duncansport
02-19-2014, 05:54 PM #2
(02-19-2014, 05:16 PM)Turbo Does any one here knows where to get hold of Bosch solenoid valve type injectors CRI2-20 injectors that has size like Part number is A6120700287 Bosch 0445110 151 or ...152 Mercedes c30 AMG, this ones is only good for 1800bar and I want to use cp3/cp4 pump to use 2000bar rail pressure for tuning om648
I seem to remember Dieselmeken showing a video of him changing/modifying some MB injectors to AMG spec. I would contact him
http://www.youtube.com/watch?v=CTxTdvCjl-0
Duncansport
Turbo
02-20-2014, 05:25 PM #3
I have contacted him but I am not sure of the outcome yet, these things is not that easy even with all that knowledge göran has
finding some basic information that you think should be quite common...
(02-19-2014, 05:54 PM)Duncansport
This post was last modified: 02-20-2014, 05:27 PM by Turbo.
Turbo
majesty78
02-21-2014, 08:21 AM #4
These where my injectors, still runnning perfectly :-)
majesty78
Turbo
02-23-2014, 04:56 PM #5
As I understud it you never run the injectors at 1800bars with cp3 pump, or was I misstaken?
(02-21-2014, 08:21 AM)majesty78 These where my injectors, still runnning perfectly :-)
Turbo
 5 Guest(s)
 5 Guest(s)
