STD Tuning Engine Om605 200-300 bhp
Om605 200-300 bhp
Om605 200-300 bhp
Stevo-trendy
03-08-2014, 11:10 AM #1
Hello posted a while back about wanting to put a om662 la in a w201 190 after doing some more research it seems not many have done this so I've thought about the om605 engine & a w202 manual as there easier to get hold of in the uk . As 190 manual diesels are very sought after & are getting a lot harder to find .
So in a stock w202 manual if I wanted to make around 200-250 bhp what would I need for the following
1) injector pump om602 ? Turbo or non turbo ?
2) what size pump elements & does anyone in the uk do good pump work ?
3 what make & size turbo charger ?
4 ) where can I source a manifold for the 605 engine ?
Many thanks Steve
Stevo-trendy
Many thanks Steve
Alcaid
03-08-2014, 05:20 PM #2
Holset HX30W 44mm inducer (ported shroud housing) = 33-34lbs/min ~230-240bhp on an OM605
Holset HE221W = 37.8lbs/min, ~260bhp on an OM605
Holset HX30W Super 46mm inducer = 38-39lbs/min, 260-270bhp
HX30W turbos are T3 flanged, HE221W has a T25 flange
Alcaid
F.R.A.S
03-08-2014, 06:01 PM #3
The w202 came in a 5cyl version. The C270CDI, find one of those manual and you have the strongest gearbox in a Mercedes ever. And a stroker crank for your 605 to be used with om604 pistons to make an IDI 2.7-liter 5cyl SuperTurboDiesel.
Ask the pump builder, he will guide you in the right direction. But as hig RS.number as possible is the way to go.
2) what size pump elements & does anyone in the uk do good pump work?
8mm and Dieselmeken in Sweden is the go to guy.
Precision 5554 is a nice one.
Ask me Tongue
(03-08-2014, 11:10 AM)Stevo-trendy Hello posted a while back about wanting to put a om662 la in a w201 190 after doing some more research it seems not many have done this so I've thought about the om605 engine & a w202 manual as there easier to get hold of in the uk . As 190 manual diesels are very sought after & are getting a lot harder to find .
Many thanks Steve
This post was last modified: 03-08-2014, 06:02 PM by F.R.A.S.
F.R.A.S
Ask me Tongue
Many thanks Steve
erling66
SuperDieselVan
294
03-09-2014, 02:40 AM #4
(03-08-2014, 06:01 PM)F.R.A.S The w202 came in a 5cyl version. The C270CDI, find one of those manual and you have the strongest gearbox in a Mercedes ever.
Do you know the number on those boxes? did they come with 6 speed?
HuhCoolTongue
erling66
HuhCoolTongue
Stevo-trendy
03-09-2014, 05:00 AM #5
Thank you for all the replies this has given me something to go off now & start sourcing parts & priceing bits up for the later in the project .
F.r.a.s when you mention changing over the rods , are stock 605 engine internals not good for 200-300 bhp ?
8mm pump sounds good would I get a lot of smoke tho ? As I wanted this to be a daily driver
Transmission I was Hopeing to get away with stock w202 maunal 5 speed trans
Alcaid thanks for the list of turbos will start having a look on eBay & do a bit more reading up
Stevo-trendy
F.R.A.S
03-09-2014, 04:43 PM #6
It's 6spd. Will search for the number, have it someplace Tongue Actually reinstalled my computer and lost my saved links Sad But it's the 6spd that ends on 66 I believe.
(03-09-2014, 02:40 AM)erling66 Do you know the number on those boxes? did they come with 6 speed?
605 internals are super tough (the turbo version), but my post was just a quick 2.7-liter fix that requires less work than buying a other w202 than the 270cdi.
You set the smoke on the outside ALDA the IP-builder will fit on your IP. So smoke is no problem.
(03-09-2014, 05:00 AM)Stevo-trendy Thank you for all the replies this has given me something to go off now & start sourcing parts & priceing bits up for the later in the project .
F.R.A.S
Jambo
03-10-2014, 01:20 AM #7
Could the transmission be a 716.654?
I'm also interestred to fin out and if someone has the gear ratios that would be first prize. Thanks
Alan
Jambo
Alan
F.R.A.S
03-10-2014, 02:53 AM #8
Here is a transmission list.
http://www.rodionenkin.de/de/pages/mb-su...-daten.php
F.R.A.S
muuris
OM605
318
03-10-2014, 03:17 AM #9
8mm elements for 200-300hp? Considering the rude part-throttle behaviour compared to stock 6mm or 7mm Mynä-pump...
If you want 250hp, change the turbo and go for reprogramming. If you want 300hp (or 400), then a built pump is needed, as well as bigger IC (although it wouldn't hurt in 250hp case either).
This post was last modified: 03-10-2014, 03:18 AM by muuris.
muuris
Stevo-trendy
03-10-2014, 03:37 AM #10
What size elements for 250-300 bhp then ? Would prefer to have a pump built rather than mapping
After speaking with alcaid turbo may be something like a HE221w or hx30 w
Would it be possible to well stock exhaust manifold with new flange to fit different turbo ?
Car will be daily driver !
Stevo-trendy
muuris
OM605
318
03-10-2014, 05:16 AM #11
As I mentioned, 250hp is possible with turbo OM605 stock 6mm elements, but 7mm is preferable as injection duration becomes shorter --> less smoke and heat, better economy. If you're upping the power above 350hp level in the future, then you should consider 8mm.
Stock exhaust manifold is for sure good for 350hp, but you'd get better spoolup with a proper manifold. Adapter flange + stock manifold will be a tight fit as W202 engine bay isn't what one would call roomy.
muuris
Stevo-trendy
03-10-2014, 01:39 PM #12
I think 7mm pump may be the best route as I don't intend to run over 250 bhp really I have been out & had a good look at the engine bay tonight & you are right it does look rather snugg in there even with stock turbo & manifold so I think the best way to go will be aftermarket exhaust manifold
Stevo-trendy
Stevo-trendy
03-12-2014, 11:40 AM #13
Would anyone recommend a garret turbo for this set up there not many holset turbochargers avaible secondhand in the uk , a few garret T34s come up & a few for spares or repairs mainly from rs cosworths
This post was last modified: 03-12-2014, 11:49 AM by Stevo-trendy.
Stevo-trendy
Alcaid
03-12-2014, 01:32 PM #14
(03-12-2014, 11:40 AM)Stevo-trendy Would anyone recommend a garret turbo for this set up there not many holset turbochargers avaible secondhand in the uk , a few garret T34s come up & a few for spares or repairs mainly from rs cosworths
What's your budget?
Alcaid
What's your budget?
03-23-2014, 06:44 PM #15
There are lots of HX35's on ebay, they usually sell for £3-400.
For the power you are aiming for don't buy a manifold get an adapter made up like in Mantaheads thread 'C250 200hp 6mm elements', This moves the turbo in and forwards to fit in the w202 engine bay, then only the stock DP needs to be lengthened to mate to it.
This is what I am doing right now
