STD Tuning Engine the Dieselmeken M-Pump arrived ;-)
300SD_KY
super turbo diesel
121
03-19-2014, 09:55 PM #1
and a very nice Diesel T-shirt.
Appointment pending with indie mechanic for installation.
Goran Thank You ... looking forward to before - after.
Just filled up with B100 (100% Biodiesel) ... anyone with before-after in their 617, especially with vids, post 'em if you got 'em.
Cheers, CT
Work so far: Monark injectors? Check. Rebuilt turbo? Check. HD Bilsteins all around? Check. H&R Lowering Springs? Check. AMG Penta Wheels? Check. Z-Rated Tires all around? Check. And a whole lot more.
This post was last modified: 03-19-2014, 10:08 PM by 300SD_KY.
300SD_KY
Cheers, CT
dieselmeken
03-20-2014, 01:33 AM #2
Set timing to around 15-19 BTDC start up an listen so it dont rattles alot. Custom pumps require custom settings.
Take it easy when you bend the high pressure pipes also and check so that the throttle linkage works OK.
dieselmeken
300SD_KY
super turbo diesel
121
03-20-2014, 05:08 PM #3
Goran, any special tools & information you recommend? My mechanic Will has the W116 300SD service manual for the MW-Pump.
Anticipation building ;-)
300SD_KY
lgreeley83
Mr. Rumbles
03-20-2014, 11:35 PM #4
(03-20-2014, 01:33 AM)dieselmeken Set timing to around 15-19 BTDC start up an listen so it dont rattles alot. Custom pumps require custom settings.
Damn mine is timed at 24 BTDC. I should have asked you huh goran. I still haven't put the external alda on. Seems really tight with the motor mounts.
Also 300SD, what turbo you running?
This post was last modified: 03-20-2014, 11:40 PM by lgreeley83.
lgreeley83
dieselmeken
03-21-2014, 01:32 AM #5
(03-20-2014, 11:35 PM)lgreeley83
Yes its a bit tight, in some cases the motor mounts needs to be grinded off a Little bit.
dieselmeken
300SD_KY
super turbo diesel
121
03-22-2014, 02:44 PM #6
Dieselmeken, that is good to know. Two questions as I plan the switch from MW to M Super Pump:
1. You mentioned in another post that the M pump has lubrication thru camshaft on 617 original, when you swap pumps like this you must have lubrication from outside by a hose, as the MW has ...
2. You also mentioned in another post that you need other high pressure pipes, the MW pipes dont fit on M pump ...
... Any tips from Super Pump Man?
Christian in Kentucky
300SD_KY
lgreeley83
Mr. Rumbles
03-22-2014, 03:10 PM #7
Cal me bro,I did the same swap last summer. 708-289-9318
But wait 10 minutes igottaplug my phone Iin.
Maybe 20 I gotta walk the dog.
This post was last modified: 03-22-2014, 03:12 PM by lgreeley83.
lgreeley83
