STD Tuning Engine OM617 MW pump experiment
  • 3 Vote(s) - 5 Average
Pages (3): Previous 1 2 3
dieselmeken
07-25-2014, 07:43 AM #101
Later on this summer/ autum I will make some progress with this experiment. I have been so busy this seson with alot of superpumps and you that follow me on facebook have probably noticed that Im a bit into Black Smoke Racing helping them with their fuel system.
dieselmeken
Evenglass
07-25-2014, 11:10 PM #102
(07-25-2014, 07:43 AM)dieselmeken Later on this summer/ autum I will make some progress with this experiment. I have been so busy this seson with alot of superpumps and you that follow me on facebook have probably noticed that Im a bit into Black Smoke Racing helping them with their fuel system.
I'm not too proud to beg! please don't dump this project, I'm counting on you! I can wait until Autumn/Winter just don't forget us and terminate the project please.
Evenglass
Riverstick
07-25-2014, 11:38 PM #103
Are we going to see an episode about Dieselmeken with the Blacksmoke boys on Youtube like they did with Pekka Herlevi?
Riverstick
dieselmeken
07-26-2014, 07:08 AM #104
(07-25-2014, 11:38 PM)Riverstick
That is something I dont know anything about but if they want it as usually Im game on. A video about how To do this MW 8mm is To be done and also a video about the superstroker M pump same as BSR have. I have made new contacts regarding the grinding of the camshaft.
dieselmeken
rcmarti
08-08-2014, 08:10 AM #105
Goran
One last question, did you modify the helix groove on the new plungers or used them as they came?
Thanks,
rcmarti
Goran
Thanks,
dieselmeken
08-08-2014, 11:21 AM #106
I use them as they are. Max 16 mm rack and it works ok. I now have all parts To go ahed and build up a few of these 8 mm mw pumps.
dieselmeken
dieselmeken
08-14-2014, 12:51 AM #107
I am now at pump #2, Have done some changes to the better I think, Pump will go up in testbench in 1 or 2 weeks, remember, this is a side project.
This post was last modified: 08-14-2014, 12:51 AM by dieselmeken.
dieselmeken
08-14-2014, 08:34 AM #108
Mmmmmmmmmmmmmm
Mmmmmmmmmmmmmm
SurfRodder
Jackass Extraordinaire
611
08-14-2014, 11:26 AM #109
it's been a (long) while since I've been on here...glad to see you are finally modding these pumps, Göran. I look forward to the progress, even though I already have an MW modified by Diesel Power Systems (or whatever their new name is now...a subsidiary of someone else now). Anyway, I appreciate all the work your doing for this community! keep it up.
OBK# 62
SurfRodder
OBK# 62
Evenglass
08-14-2014, 07:54 PM #110
That thing looks sexy.
Evenglass
yankneck696
395
08-15-2014, 08:09 AM #111
And, they say that size doesn't matter.....
Ed
yankneck696
Ed
08-19-2014, 01:48 AM #112
Mmmmmmmmmmmmmm pretty
atypicalguy
09-14-2014, 08:04 AM #113
(08-14-2014, 12:51 AM)dieselmeken I am now at pump #2, Have done some changes to the better I think, Pump will go up in testbench in 1 or 2 weeks, remember, this is a side project.
This is exactly what I am looking for. Not sure my freshly rebuilt transmission will handle it but only one way to find out.
Are all MW pumps identical? I have an 85 TDt that I drive daily, and an older model parts car. Just wondering if I could send the pump from the old car and bolt it on to the new one after rebuild.
Thanks
atypicalguy
Thanks
09-14-2014, 02:18 PM #114
I think later model pumps might have some sort electric rack position sensor or something but I'm not entirely sure
09-14-2014, 04:28 PM #115
(09-14-2014, 02:18 PM)sassparilla_kid I think later model pumps might have some sort electric rack position sensor or something but I'm not entirely sure
The newer 617MW pumps have a rack position sensor-it just reads out. Nothing to do with actual fuel delivery
09-14-2014, 04:46 PM #116
The '85 pumps have a hole for the timing checker tools. You're not stuck with the drip method.
123 pump list
http://www.startekinfo.com/StarTek/outsi..._1-001.pdf
This post was last modified: 09-14-2014, 04:49 PM by raysorenson.
123 pump list
atypicalguy
09-16-2014, 05:18 AM #117
Ok so do I rebuild the 85 one or send the old one to sweden and keep the 85 just in case? I dont know much about setting one up so i dpnt know if im going to be using "timing checker tools".
Wonder what the car is doing with that rack sensor info...
atypicalguy
09-16-2014, 05:27 AM #118
Rack sensor is used as an input for the egr computer.
When you install a pump, you have to time it. The '85 pump will be easier to time.
atypicalguy
09-16-2014, 05:31 PM #119
(09-16-2014, 05:27 AM)raysorenson Rack sensor is used as an input for the egr computer.
Ok thanks. I guess I can use that sensor as an input for a VGT turbo.
atypicalguy
09-16-2014, 06:02 PM #120
It's not that easy. The sensor isn't a potentiometer. I don't how it works and I haven't found any descriptive documentation about it. This has been discussed in past threads.
atypicalguy
09-16-2014, 10:34 PM #121
Ok Ill search for it. But the controller yankneck696 is working on will take just about any kind of signal- pwm or whatever. (If its the same guy from 4btswaps(
atypicalguy
yankneck696
395
09-17-2014, 08:14 AM #122
I do not think what I am working on will help with the rack sensor. Check out Ole Fejer's controller (Not sure of the spelling). If I remember right, the rack sensor is not at all a resiistive element. You will see his controller on this forum. It also controls some of the transmissions.
And, yes, I use the same screenname on all forums....
Ed
http://www.superturbodiesel.com/std/Thre...NT-HE351VE
Ed
Ed
This post was last modified: 09-17-2014, 08:16 AM by yankneck696.
yankneck696
Ed
Ed
Ed
baldur
Fast
506
09-17-2014, 08:31 AM #123
I made a controller to drive an electronic M pump. There the rack position sensor is a variable inductance deal with a pair of coils. My experiments showed that one coil is fixed inductance and I believe it is just a reference for temperature compensation while the other coil has a shunt on its core that varies the inductance.
I built a circuit to feed a square wave to the coils and measure the phase shift to get position feedback. I'm using a microcontroller but it could easily be done with op-amps to produce a PWM or frequency signal.
Baldur Gislason
baldur
Baldur Gislason
atypicalguy
09-18-2014, 07:42 AM #124
(09-17-2014, 08:31 AM)baldur I made a controller to drive an electronic M pump. There the rack position sensor is a variable inductance deal with a pair of coils. My experiments showed that one coil is fixed inductance and I believe it is just a reference for temperature compensation while the other coil has a shunt on its core that varies the inductance.
This is very interesting. I could use it for throttle position but it may be simpler to just fit a potentiometer, as dieselmeken says he uses the earlier MW pump for 8mm element rebuild so far. Does anyone have a part number for a stock mercedes TPS that would work on a w123 diesel? Thanks.
PS Baldur - Ole Fejer wants to contact you about that circuit. It is his name with no spaces at g mail
This post was last modified: 09-18-2014, 07:48 AM by atypicalguy.
atypicalguy
Bondobay
12-31-2014, 04:03 PM #125
I've been keeping one eye in this thread but it's been pretty inactive for a couple months.
What, if anything has come of this?
Bondobay
atypicalguy
01-01-2015, 02:06 AM #126
Prob easier to just use a tps and forget the pump signal, as pump needs mods anyway
atypicalguy
kestreltom
01-02-2015, 10:10 AM #127
(09-18-2014, 07:42 AM)atypicalguy ...Does anyone have a part number for a stock mercedes TPS that would work on a w123 diesel? Thanks.
I have a tps part number for you "atypicalguy"... try A 011 542 87 17 - from a w210 gas car. Here are a few photos:
https://lh6.googleusercontent.com/-PXSyE...075954.jpg
https://lh5.googleusercontent.com/-8cfny...075942.jpg
good luck!
1984 300D with Monark nozzles, GT2256V w/ Synkooppi/Arduino controller, W123 n/a intake, air/water intercooler, precup holes reamed, IP & valve timing = fac + 2 degrees, upgraded leather interior, 140A alternator, electric lift pump, 3" aluminum radiator w/ electric fan, HID headlight conversion, bilsteins, stock MW IP turned up 3 turns on tq module per OM616, 2.65 rear end, ventilated front rotors, dual rear swaybar mod + W116 springs  -  https://www.youtube.com/watch?v=4zPSyCMkkk0
kestreltom
good luck!
atypicalguy
01-02-2015, 12:01 PM #128
Thanks. Still have not sourced the cummins he200vg. They only sell them in china. I have a friend who travels there so it might still happen.
atypicalguy
atypicalguy
01-02-2015, 05:42 PM #129
(01-02-2015, 10:10 AM)kestreltom
good luck!
Thanks for that info.
atypicalguy
good luck!
atypicalguy
01-28-2015, 06:04 AM #130
Alas no MW news from abroad!
atypicalguy
Evenglass
03-16-2015, 12:40 PM #131
Any word on this Goran?
Evenglass
atypicalguy
03-16-2015, 01:48 PM #132
He is taking mw cores last I checked.
atypicalguy
turbojeep
Off roading luxury sedans
81
03-16-2015, 02:56 PM #133
Cores for testing purposes? Or cores for resale?
turbojeep
atypicalguy
03-16-2015, 03:18 PM #134
Cores to rebuild into superpumps for customers
atypicalguy
mike-81-240d
more like mike-84-300d now
427
03-16-2015, 03:46 PM #135
I talked with him on Facebook the other day, he's ready. Send your pumps his way. I'm about a month until I can get mine done. (Money is tighter than usual currently)
mike-81-240d
dieselmeken
03-19-2015, 11:35 AM #136
Its up and running, currently I have pumps works OK, Im shipping 1 to Canada soon and 1 to USA. However there is alot moore work with those MW than the M-serie pumps.
dieselmeken
turbojeep
81
03-19-2015, 09:46 PM #137
This is great news! Does the extra work translate into more $$, or are they priced about the same as the M Pumps?
turbojeep
dieselmeken
03-20-2015, 02:29 AM #138
I try and keep it at the same price as M-pumps, 1000 euro incl tax, For US customers -20% tax + shipping & corepump
Corepump is around 100 euro
Shipping, around 120-140 euro to USA
dieselmeken
dieselmeken
03-20-2015, 02:49 AM #139
dieselmeken
MTUPower
287
03-21-2015, 07:02 PM #140
who has one of his pumps and what are the results? what other mods are done to that engine in addition? thx!
MTUPower
mytmousemalibu
03-22-2015, 03:58 AM #141
(03-20-2015, 02:49 AM)dieselmeken I try and keep it at the same price as M-pumps, 1000 euro incl tax, For US customers -20% tax + shipping & corepump
Göran, when you get a free minute, I sent you an Email from your email link on this site with some pump questions for you.
Your PM box is full  Wink
I unfortunately don't have a facebook account Undecided so that was my best option!
mytmousemalibu
atypicalguy
04-02-2015, 05:01 PM #142
I am getting a quote of $400 USD from South Dakota to Sweden on an MW pump. It sounds a bit high. Anyone else done this? What company and what did you pay?
Thanks,
Karl
atypicalguy
Thanks,
Karl
Duncansport
04-03-2015, 12:42 PM #143
(04-02-2015, 05:01 PM)atypicalguy
Thanks,
Karl
Too much. i shipped with usps and it was $90 from Boston
Duncansport
Thanks,
Karl
atypicalguy
04-03-2015, 11:31 PM #144
(04-03-2015, 12:42 PM)Duncansport
Thanks,
Karl
Thanks; that's what I thought. led-panzer shipped his for $90 from Ohio also, so that's the ticket apparently.
This post was last modified: 04-03-2015, 11:31 PM by atypicalguy.
atypicalguy
Thanks,
Karl
rcmarti
04-10-2015, 12:08 PM #145
(03-19-2015, 11:35 AM)dieselmeken Its up and running, currently I have pumps works OK, Im shipping 1 to Canada soon and 1 to USA. However there is alot moore work with those MW than the M-serie pumps.
Goran, did you end up doing much more than what you posted before? What was the issue with the
engine shutting off when hot?
thanks
rcmarti
thanks
