STD Tuning Engine OM606 front timing cover removal ...headgasket?
vica153
05-04-2014, 12:11 AM #1
I broke one of the timing chain guides on my OM606, so now I need to remove the timing cover to replace it. Angry Does the the head need to be removed to do this?
vica153
Duncansport
05-04-2014, 10:59 AM #2
(05-04-2014, 12:11 AM)vica153 I broke one of the timing chain guides on my OM606, so now I need to remove the timing cover to replace it. Angry Does the the head need to be removed to do this?
No, just the rails. It would make your life much easier to remove the oil pan or the cylinder head however
Duncansport
vica153
05-04-2014, 05:22 PM #3
(05-04-2014, 10:59 AM)Duncansport
The oil pan is off already. I don't want to pull the head if I don't need to. Pulling the timing cover is one thing, but pulling the head gets me into a whole new can of worms that I'd rather avoid.
vica153
vica153
05-05-2014, 01:51 PM #4
What are the 'rails'?
vica153
Duncansport
05-06-2014, 09:38 AM #5
The timing guide rails that are up in the head and timing cover
Duncansport
vica153
05-07-2014, 01:08 AM #6
Easy with the oil pan off. Now how the heck do you check the timing while i'm at this with the cover off? I can't any marks.
This post was last modified: 05-07-2014, 01:10 AM by vica153.
vica153
Duncansport
05-07-2014, 06:10 AM #7
You can't really...the keyway roughly at 12 o'clock is tdc
Duncansport
vica153
05-07-2014, 12:04 PM #8
I can look at the #1 piston position and guess at TDC, but is there really no way to tell if the cam timing is set correctly in relation to the crank?
vica153
Duncansport
05-07-2014, 04:02 PM #9
(05-07-2014, 12:04 PM)vica153 I can look at the #1 piston position and guess at TDC, but is there really no way to tell if the cam timing is set correctly in relation to the crank?
Not until you have the front cover back on and have the valve cover off. Its not to hard, take the tensioner out, take the gear off and zip tie the chain to the gear. Do the work you need to do with the front off and reassemble the front cover and set the timing. Double check your pump timing and install the valve cover and off you go.
Duncansport
