STD Other Projects C250TD OM605 300HP+ Street Project
  • 1 Vote(s) - 5 Average
Pages (3): 1 2 3 Next
ViSoR
05-23-2014, 02:04 AM #1
Hello guys! I am building a poor man's AMG Big Grin
Goal is: 301HP without smoke, pulling from basement to attic
Engine: OM605 1997
Turbo: GT2260V (BMW 330d) with bigger compressor wheel = GT2264V
Exhaust: -open-
Pump: serie
Chip: modified to pumps maximum ~ 93ccm
1.8 bar boost pressure, no smoke
[Image: attach-398054.jpg]
It goes like this now, 100-200km/h=19 sec http://www.youtube.com/watch?v=_od3Bt9k4vw
I was thinking of modifing the delivery valves, to get more from the serie pump.
This is where I would need your kind help... Where should we start?
This post was last modified: 05-23-2014, 02:26 AM by ViSoR.
ViSoR
C250TD "Wannabe 300+"
Golf Mk2 PDTDi "The Legend" http://www.youtube.com/watch?v=KaUF4_aXxhE
Ibiza TDI "Free Energy Device" (Runs on used motoroil)
ViSoR
Engine: OM605 1997
Exhaust: -open-
Pump: serie
ViSoR
maxypriest
05-23-2014, 07:05 AM #2
Blast - that 250 goes really well!
maxypriest
Duncansport
05-23-2014, 07:14 AM #3
(05-23-2014, 02:04 AM)ViSoR Hello guys! I am building a poor man's AMG Big Grin
Engine: OM605 1997
Exhaust: -open-
Pump: serie
Contact Dieselmeken about elements, might be a bit of a project if you running the edc pump.
Duncansport
Engine: OM605 1997
Exhaust: -open-
Pump: serie
ViSoR
05-23-2014, 09:20 AM #4
(05-23-2014, 07:14 AM)Duncansport Contact Dieselmeken about elements, might be a bit of a project if you running the edc pump.
Yes, thanks for the advice, but I would like to keep the factory 6mm elements, like he did in this video. This 150cc would be far enough to reach 300HP+. http://www.youtube.com/watch?v=SrXY6fYnmBU
And obviously he is not going to tell what to change and how to achive this quantity Confused
ViSoR
ViSoR
ViSoR
Petar
7.5mm M pump
459
05-23-2014, 03:14 PM #5
I recommend swapping the elements for bigger ones it's much better way.BTW very good result with 6mm elements,I thought they were good for only ~45hp per cylinder. Whats your EGTs ?
Petar
ViSoR
05-23-2014, 06:44 PM #6
(05-23-2014, 03:14 PM)Petar I recommend swapping the elements for bigger ones it's much better way.BTW very good result with 6mm elements,I thought they were good for only ~45hp per cylinder. Whats your EGTs ?
EGT has not been measured yet. Actually the 6mm elements could do more, my car was 280HP+ at one stage of the programming, but it was too close to the 5 Volt limit of the HDK and sometimes the overvoltage shut the engine down. Only in 1st gear if I accelerated from rolling idle, but still... It was so brutal I nearly flew thru the windshield when the engine cut off Shy
Okey, we'll put 7mm elements in for a test. We bought them here: http://www.dieselkontor.de/product_info....ts_id=3271
Does anybody have experience with these? My friend tried them, but they weren't enought for his Quattro OM606 HX50 + Eaton M90 beast Big Grin
https://www.youtube.com/watch?v=loqjkLgMh6Q
https://www.youtube.com/watch?v=NRiqkGPglMg
This post was last modified: 05-23-2014, 06:46 PM by ViSoR.
ViSoR
ViSoR
ViSoR
Duncansport
05-24-2014, 02:39 PM #7
Diesekmeken sells his 7.5mm and 8mm by elements themselves i believe? Im sure you know the benefits of a larger element other then more fuel...
Good work by the way! That 606 is pretty great.
Duncansport
ViSoR
05-24-2014, 05:18 PM #8
(05-24-2014, 02:39 PM)Duncansport Diesekmeken sells his 7.5mm and 8mm by elements themselves i believe? Im sure you know the benefits of a larger element other then more fuel...
I'm not really sure about the other benefits. Blush I tuned VW TDI engines for the last few years - bigger element meant more problems (more heat, noise, larger load on the timing belt, higher consumption, extra fuel pressure need before the pump etc). I mean reaching 300PS by a VW pump was not this civilized as is my Merc now, that's why I'm a bit afraid of the 7mm elements Smile https://www.youtube.com/watch?v=9qsE8wdlub0
This post was last modified: 05-24-2014, 05:40 PM by ViSoR.
ViSoR
ViSoR
ViSoR
Duncansport
05-24-2014, 07:13 PM #9
I have 7.5mm elements in my 602 pump and it drives the same around town, highway and starting is the same as factory 5.5mm's. But there is much much more fuel when called upon.
Running larger elements means that the injection duration is shorter. This allows you to run a bit more timing on the pump and helps to reduce EGT's...all leading to more power.
Duncansport
ViSoR
05-25-2014, 04:22 AM #10
(05-24-2014, 07:13 PM)Duncansport Running larger elements means that the injection duration is shorter. This allows you to run a bit more timing on the pump and helps to reduce EGT's...all leading to more power.
Thank you, I am convinced. Let's 7mm! Shy
ViSoR
ViSoR
ViSoR
Petar
7.5mm M pump
459
05-25-2014, 09:26 AM #11
Get an EGT gauge or you can melt your engine.Go bigger elements,you won't be dissapointed i am sure. TDIs are whole different beasts compared to these engines indirect injection and timing chain not a belt for instance.Those elements from dieselkontor.de are i think old ford transit elements, they will be louder at idle, but other than that no difference in driveability.
Petar
Tito
05-25-2014, 03:53 PM #12
VE pumps are way different than inline Bosch pump. Dieselmeken modified pumps are easy to adjust. I thought 8mm's ran a bit rough on idle.
Tito
07-10-2014, 07:24 AM #13
|Following this build as I am collecting parts to do the same, bigger elements and retain EDC pump, Win!
bruno_pinho
07-15-2014, 05:24 AM #14
News?
bruno_pinho
News?
mbz123
07-16-2014, 05:12 AM #15
(05-23-2014, 02:04 AM)ViSoR Goal is: 301HP
Comedy!
Was there any involved process used to arrive at such an "arbitrary" rating for your goal? Or could it be prime perhaps?
I'm thinking if that guy out front is not a born leader, he might get a bit lonely at times. 8-D
Updates, updates... where are the udpates???
MBZ123
mbz123
Comedy!
MBZ123
08-14-2014, 06:41 AM #16
Well you should start with gettting full rack travel from your IP, this is the tutorial I saved from the mentioned thread, and the associated pictorial, my version will have in series, an arming switch in the cockpit, a (max) accelerator switch, and a manifold pressure switch. This way the circuit is only armed when you arm it by hand, and you are in a full load situation, to keep street driveability. Enjoy.
[Image: 606IPmaxloadfuellingmodSchematic.jpg]
[Image: ipfullfuelresistormodecuendofwiringharness.png]
From tomnik OP thread.. http://www.superturbodiesel.com/std/show...hp?tid=731
full load increase electronic governor
Hi,
found an information where a guy increased the full load on his 250 Turbodiesel with electronic governor. He installed a resistor 4 kOhm and a switch as a bridge between pin 6 (blue/yellow) and pin 7 (grey/black).
Additionally he added a temperatur switch to activate the increase only at a certain temperature.
Maybe the procedure is the same for the 606 engine.
The complete thread is http://fmso.de/forum/messages/802344.htm
in German.
Update:
Confirmed this morning relating to the rack position sensor:
Pin 1 - Red
Pin 6 - Green
Pin 7 - Black
The colors cited correspond with the pump's internal wiring harness. Here's a little more detailed description:
1 - Red - Rack position (Side 1) ECU pin 21
6 - Green - Rack position (Common) ECU pin 14
7 - Black - Rack position (Side 2) ECU pin 39
2 - Tan - Solenoid ECU pin 1 and 2
3 - Tan - Solenoid ECU pin 17 and 16
This post was last modified: 08-14-2014, 06:43 AM by Hario'.
Hi,
in German.
Update:
Pin 1 - Red
Pin 6 - Green
Pin 7 - Black
09-25-2014, 06:58 AM #17
News?
News?
ViSoR
10-12-2014, 12:27 PM #18
Sorry for the summer break, but the GT2264 BMW turbo returned to God Angel
On very hot day I was measuring 0-100 km/h runs, and after the 8th attempt, everything overheated. Only 2 mm pieces left of the turbine in the AMG tailpipe Big Grin After 10 minutes (!) of cooling down, there was still burning oil smoke coming from what's left of the turbo. My bad... But I don't build a a car to rot in my garage. What is weak will break and be replaced with harder parts. (EGT gauge bought Dodgy )
So! Now I am looking for a WG turbo that can handle 300HP and can spool under 2500 rpm. I have a stronger GTB22 with 64mm GTX compressor wheel, but now I assume it would only be good for 270-280HP so and I am willing to give up my VTG dreams.
Good news is with the very unsporty 5 speed manual, I managed to run 6.x second constantly before everything went to flames Shy
This post was last modified: 10-12-2014, 12:33 PM by ViSoR.
ViSoR
ViSoR
ViSoR
10-24-2014, 09:59 AM #19
Aha! BEst way to learn is by doing things wrong and breaking parts.. Or be really conservative because of lack of funds like me.
Any engine build pictures??
ViSoR
01-04-2015, 07:59 AM #20
Happy new year everyone! Smile
For 2015 I decided to stop fooling around with wedding ring sized turbos, be a man like Hario' ... so we put a HX35 on the device and installed some cheap 7mm elements too. Big Grin
Originally I would have liked a GTX3076 or something like that, but that I found a bit overkill in price for my project, so I bought a new Holset HX35 for €200 and hoped for the best...
And kinda fell on my face. Dont get me wrong, this is the first time that the car actually feels fast, 100-200kmh in 13sec (same as BMW E39 M5 400HP), but the lag!!! In 1st gear it doesnt spool at all! In second gear it starts to spool from 4500rpm. In 3rd gear it spools from 4000 rpm and spins the wheels instantly to the revlimit. So at this point she is a 100% dynoqueen, way more than 300HP but absolutely good for nothing Undecided
I hope that this is not the real characteristic of the HX35 on this engine, this is only because of the ECU has not been adjusted yet. She doesnt even smoke till 4000rpm. I assume that the ECU doesnt see turbo pressure until 4000rpm, so it wont give more fuel, so the turbo cant spool.... Catch 22.
We will remap it next week, and try to set the revlimit over 6000rpm a bit.
Test VIDEO 100-200km/h
Stock OM605 7mm element + HX35 1.6bar
Hario'! Can you tell me something promising about your spool?
This post was last modified: 01-04-2015, 08:45 AM by ViSoR.
ViSoR
ViSoR
ViSoR
mantahead
01-04-2015, 09:53 AM #21
good luck with the rev limit
what size is exhaust housing on that hx35(12cm)?
This post was last modified: 01-04-2015, 10:03 AM by mantahead.
mantahead
ViSoR
01-04-2015, 10:37 AM #22
12cm I think.
Another interesting thing, we cant get the HX35 over 1.8bar. Maybe the 60mm exhaust chokes it, but I'm afraid if I upgrade it to 76mm it will be even more laggier.
(01-04-2015, 09:53 AM)mantahead good luck with the rev limit
This post was last modified: 01-04-2015, 10:42 AM by ViSoR.
ViSoR
ViSoR
12cm I think.
ViSoR
Petar
7.5mm M pump
459
01-04-2015, 10:59 AM #23
(01-04-2015, 10:37 AM)ViSoR 12cm I think.
Why do you think bigger exhaust would make it laggier ? Turbines work based on pressure difference so reducing backpressure would make it spool faster.
Yeah you should definatly remap the ECU. And make sure it overfuells slightly off boost. What exhaust manifold are you using ? It can make quite a difference in spool time.
But don't expect expect it to spool much below 2700-3000 rpm... Wink
This post was last modified: 01-04-2015, 11:10 AM by Petar.
Petar
ViSoR
01-04-2015, 11:32 AM #24
Yes, we will try to overfuel it. I'm using the OM manifold, not the best, the turbo much further away now unfortunately from the cyl head.
ViSoR
ViSoR
ViSoR
mantahead
01-04-2015, 01:23 PM #25
hi, hx35 and 7.5mm elements (green graph is electronic pump)
[img][Image: utf-8BSU1HMDA1NDUtMjAxMTEwMTUtMTYzNS5qcGc.jpg][/img]
that was large 18.5cm exhaust housing, i always had rev limit problems,
This post was last modified: 01-04-2015, 01:25 PM by mantahead.
mantahead
bruno_pinho
01-04-2015, 02:14 PM #26
Hi
Dieselkontor elements?
bruno_pinho
Hi
ViSoR
01-04-2015, 03:38 PM #27
(01-04-2015, 01:23 PM)mantahead hi, hx35 and 7.5mm elements (green graph is electronic pump)
Now that looks much better than what I feel now. Altough on dyno under full load in fifth gear, everything spools faster than on the street if you try to overtake.
Will try with 76mm exhaust instead of 60mm. But in my experience that helps top end only.
bruno_pinho - Yes dieselkontor type 7mm elements.
This post was last modified: 01-04-2015, 03:57 PM by ViSoR.
ViSoR
ViSoR
ViSoR
bruno_pinho
01-04-2015, 03:57 PM #28
(01-04-2015, 03:38 PM)ViSoR
Will try with 76mm exhaust instead of 60mm. But in my experience that helps topend only.
I also have the same elements in an electric pump ...
a question, notes well more noisy pump? my was enough after applying the elements ..
bruno_pinho
ViSoR
01-05-2015, 03:09 AM #29
(01-04-2015, 03:57 PM)bruno_pinho I also have the same elements in an electric pump ...
It is a bit louder and shakier on idle, feels like one cylinder is missing out sometimes. If I start to rev it, there is no difference than before.
ViSoR
ViSoR
ViSoR
bruno_pinho
01-11-2015, 08:37 AM #30
Updates?
bruno_pinho
Updates?
01-12-2015, 11:16 AM #31
HX35 will be too laggy on my EDC pumped W202 C250. So I have nearly finished by quick spool valve to try and bring back some bottom end.
If not I will have to scrap the idea for the medium-term as by W202 has a 722.6 so I will need a controller before I can go mechanical pump.. Sad
In the UK it seems to be ecu remapping is nothing more than a myth!!??
Compounding with a HX35 over the OEM KKK might be the only way to go...
bruno_pinho
01-12-2015, 01:10 PM #32
But you arrive to tune the electronics?
bruno_pinho
01-13-2015, 04:52 AM #33
Can't find anyone in UK! I'll be using the 'resistor/potentiometer mod to add off-boost fuel to spool the turbo, that is the main issue.
ViSoR you need to measure EGP to find out whats going on with your boost issue!
yorkshire1
s202 2.5TD manual high speed diff
18
01-14-2015, 12:49 PM #34
(01-13-2015, 04:52 AM)Hario Can't find anyone in UK! I'll be using the 'resistor/potentiometer mod to add off-boost fuel to spool the turbo, that is the main issue.
Give this chap a ring he remapped my 605, Simon on 07957 240822 worth a call, nice chap
yorkshire1
01-14-2015, 02:58 PM #35
Thanks!
Do you have any more info? Email, company name etc? Its a post ECU desolder chip job isn't it?
Also how is your s202 different to my w202?
Beers, H.
(01-04-2015, 10:59 AM)Petar
It would be laggier because the scroll has a bigger exit area where the exhaust gas impinges on the turbine wheel requiring more exhaust flow to achieve turbine speed to produce boost, ie more revs, ie more lag.
Your mention of needing an increase in offboost fuelling opened my eyes to the no fuel from ECU = no boost = no fuel added by ECU paradox of the stock ECU where it waits for boost before it increases fueling. Therefore: would the crude 'resistor mod' in the edc wiring loom to give more rack travel give me the extra fuel off boost to spool the big turbo? (Without a remap).
If you guys aren't confused my what I just said I think I am..
This post was last modified: 01-14-2015, 03:12 PM by Hario'.
Thanks!
Beers, H.
bruno_pinho
01-14-2015, 03:48 PM #36
I see that many problems will reprogram the ECU, I so far not had any problems, I have the tuning I want ....
But for the week I will ask to put the rotation ace 6000rpm because apparently still no one did, I think it will be fine ...
I leave a video of my car, I think this is not bad for a pump with elements of dieselkontor and the turbo I have ..
https://www.youtube.com/watch?v=RJi9fIloFFo
bruno_pinho
yorkshire1
18
01-15-2015, 04:21 AM #37
(01-14-2015, 02:58 PM)Hario Thanks!
Beers, H.
yeah thats right involves soldering I had mine done about 21/2 years ago now and at the moment I cant for the life of me remember the company name, I just put his number in my phone , Ill do a bit of searching see if I can track anything down, Ive put a few people on to him like you say there arent many that do it
my car,s just a daily driver atm does about 30,000/yr so I got about another 25/30HP and put a 2.8 diff in it for economy its a manual
yorkshire1
Beers, H.
yorkshire1
18
01-15-2015, 05:57 AM #38
Found him, Simon Coe
http://www.ccctech.co.uk/
yorkshire1
ViSoR
01-24-2015, 04:32 PM #39
Update:
We have remapped the ECU, the vehicle is a beast! Smile Revlimit is at 6000 rpm now.
Unfortunately I was right about the exhaust. Upgrading from 60mm to 76mm, didn't do anything! No boost pressure change, no power gain, no faster spool, no nothing. A bit quieter I guess... I give you my word, an open 60mm exhaust is far enough till ~350HP!
Next week I will make you new a video, I couldn't get the car from the mechanic yet because it starts badly. The fuel flows back from the pump to the tank, because some fuelvalve fault since the element change. Fix that, and than I will go to dyno again.
This post was last modified: 01-25-2015, 05:08 AM by ViSoR.
ViSoR
ViSoR
Update:
ViSoR
bruno_pinho
01-25-2015, 06:10 AM #40
Do not understand why do not more pressure
As these to control the pressure, with a tap or by the ecu?
bruno_pinho
ViSoR
01-25-2015, 01:23 PM #41
(01-25-2015, 06:10 AM)bruno_pinho Do not understand why do not more pressure
Pressure is controlled by the own actuator of the HX35, only with bigger springs to keep is closed longer.
ViSoR
ViSoR
ViSoR
bruno_pinho
01-26-2015, 06:47 AM #42
I will also make 76mm exhaust line because everybody says it's better but I think it was not necessary
bruno_pinho
seanyt
is300d He351ve
279
01-26-2015, 11:39 AM #43
Just got an edc 8mm pump. For my compound turbo conversion.
Has your tuner been able to get your ecu limits up to 6k rpm?
My tuner hasn't looked at it yet. But I've socketed my ecu and he has the files dumped
Loving all these edc tuning lately . Mine is in a Lexus is200.
seanyt
Ksteen2
01-27-2015, 07:51 PM #44
when you want over 2 bar in pressure, you see the differense with the exhaust, its not hust about the boost, its also about low back pressure and a god egt Wink
and you'r original manifold is a BIG brake, I cant get over 1,7 bar with my 606 with a k27 with 12cm house, and dieselkontor 7mm
I had 2,7 with a hx52 and a home made tubilar manifold, both 3,5" exhaust and 4" DP
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
01-28-2015, 11:19 AM #45
Regarding rev limit increase, I found out 605 has 5 tags on flywheel for rpm pickup, and 606 has 6, so I have an idea:
To raise rpms on 606, you fit 605 flywheel.
To raise rpms on 605, you fit 604 flywheel - (if it has 4 tags, NOT CHECKED).
Or - move the crank pickup to the pickup bracket at the front of the engine (looks like crank position sensor bracket on petrol car) and fit however many tags to crank pulley as you need to make sensor under read, probably drill in radially and locktite in bolts as hall effect pickup tags?
In all cases need to adjust idle speed in map to correct as it will try to overspeed (thinking engine is turning slower than it is).
This post was last modified: 01-28-2015, 11:20 AM by Hario'.
Ksteen2
01-28-2015, 01:32 PM #46
you'r tackometer will not work proporly then :o
1#
Originaly a d24tic
6speed cdi box
Ksteen2
1#
Originaly a d24tic
6speed cdi box
01-28-2015, 02:08 PM #47
Oh my gaaad....
Oh my gaaad....
erx
w202 om606
323
01-28-2015, 03:45 PM #48
Does 605 have one or two sensors near starter motor? My 1994 604 has two, upper is for ecu and lower in oil pan is for tacho, it reads starter motor teeth on flywheel. I swapped to 606 and put that tacho sensor back and tacho is working, I use mechanic pump.
This post was last modified: 01-28-2015, 03:46 PM by erx.
erx
bruno_pinho
01-28-2015, 04:03 PM #49
(01-28-2015, 03:45 PM)erx Does 605 have one or two sensors near starter motor? My 1994 604 has two, upper is for ecu and lower in oil pan is for tacho, it reads starter motor teeth on flywheel. I swapped to 606 and put that tacho sensor back and tacho is working, I use mechanic pump.
But that flywheel you used?
bruno_pinho
erx
w202 om606
323
01-28-2015, 04:43 PM #50
I have automatic, flywheel is from 606.
erx
