STD Tuning Engine OM606 rear sump oil pan?
  • 1 Vote(s) - 1 Average
Pages (3): Previous 1 2 3
zeeman
10-14-2016, 03:33 PM #101
(10-14-2016, 02:04 PM)MrHope
(10-10-2016, 10:59 AM)P50harleyrider Can't speak for the 605 but the 606.962 main bolts are already threaded for the CDI pickup tube support. I can verify you are correct, Ross. I recently put the rear sump on my F150 conversion so it's still fresh in my head. Zeeman should move to the east coast.
Did you use the drive chain from the 606 or the 320cdi? Are they the same length?
Use the 606 chain, they are the same.
zeeman
50harleyrider
GTA2359VK
397
10-14-2016, 04:09 PM #102
Ditto same chain. Also I never found an onboard dipstick for my 648 pan. I'll just use the red plastic plug when operating and carry the measuring stick behind the seat. It just shows the correct level when it's inserted into the pan tube until it hits bottom. Must be a universal one. Can't figure out MBs' logic here. I got tired of searching and Pelican parts informed me of this silly system. If there is an onboard or full time dipstick available for the om648 pan that I'm not aware of, would love to have the part #.
This post was last modified: 10-14-2016, 04:17 PM by 50harleyrider.
50harleyrider
ross
10-15-2016, 05:42 AM #103
I bought the whole donor engine, which came with dipstick and tube, I'll have a look for a part number next time I'm in the workshop.
ross
zeeman
10-15-2016, 10:55 AM #104
(10-14-2016, 04:09 PM)50harleyrider Ditto same chain. Also I never found an onboard dipstick for my 648 pan. I'll just use the red plastic plug when operating and carry the measuring stick behind the seat. It just shows the correct level when it's inserted into the pan tube until it hits bottom. Must be a universal one. Can't figure out MBs' logic here. I got tired of searching and Pelican parts informed me of this silly system. If there is an onboard or full time dipstick available for the om648 pan that I'm not aware of, would love to have the part #.
There is no dipstick for the OM 648 in the USA. The dealer has a gismo to check the oil level. The electronic sensor in the pan tells you if the oil level is to low. I agree it is a crazy system, but they must have some reason for it. It is like the OM 606 has no oil pressure sender in the block.
zeeman
50harleyrider
GTA2359VK
397
10-16-2016, 08:39 AM #105
I guess we'll just have to carry the measuring stick like I said. What numbers do you use on it for the OM606, Zeeman?
50harleyrider
zeeman
10-16-2016, 11:23 AM #106
(10-16-2016, 08:39 AM)50harleyrider I guess we'll just have to carry the measuring stick like I said. What numbers do you use on it for the OM606, Zeeman?
There is a guy on E-bay that sells a calibrated measuring dip stick for the 648 in MM. I think it was $25.00. it is used on different engines but he gives the measurement for each engine. I believe the OM 648 was 133 MM. to 135mm. from the bottom of the pan. But I need to double check that.
This post was last modified: 10-16-2016, 11:29 AM by zeeman.
zeeman
50harleyrider
GTA2359VK
397
10-16-2016, 03:06 PM #107
That's the stick I got. The OM648 holds 8 quarts. The 98 606.962 calls for 7.5 quarts and the 99 606.962 calls for 8 or vice versa.We should be able to put 7.75 quarts in a dry 606 engine, start it, run for 30 seconds, shut off and then check with this tool-(https://automotivetools.com/products/669...pstick-oil) inserted to bottom of sump and use the number you get as full reference. We still have to remove it and store it during operation. Ah. those wonderful Germans.
This post was last modified: 10-16-2016, 03:38 PM by 50harleyrider.
50harleyrider
benjy_b
10-20-2016, 01:08 PM #108
I'm looking to fit a rear sump on my OM605 (for BMW E36 application), are these the correct part numbers?
Sump
6470140302
Oil pump
6471800201
Additionally, I've come across the part number A6121810201, which seems to be another 5 cylinder rear sump oil pump. Does anyone know if this will work?
benjy_b
Sump
6470140302
Oil pump
6471800201
svengali0
04-10-2017, 10:28 PM #109
You could try OM662 Ssanyong Musso sump and pickup. I'll have one of these (rear bowl) in a few months as I need front G specific sump & pickup for the application.
svengali0
Mr.Emo
Nissan Patrol -> 606 conversion.
69
03-21-2018, 03:16 PM #110
What conclusions did we come to in regards to the baffle plates on the 606 -> 648 oil sump conversion?
I'm doing mine now and I was thinking of modifying the original one to fit in the back of the engine.
Mr.Emo
 3 Guest(s)
 3 Guest(s)
