STD Tuning Engine electronic pump 7.5mm elements
97e300
(its a 98 now)
109
07-01-2014, 10:19 AM #1
Considering getting 7.5mm elements for an electronic pump. I know the governor is electronic, but is there any reason the job would not be DIY?
This post was last modified: 07-01-2014, 10:19 AM by 97e300.
97e300
07-01-2014, 10:50 AM #2
same as with other pumps. rack position and injection amount need to be calibrated, but go for it.
u can calibrate them the same way the old timers use to do on trucks.
assemble the pump, measure fuel injection at injectors (one minute each) remove the access port on the side , increase or decrease the position on the plunger holder against the rack.
all this with the engine running. they usually had success Smile
regards
regards
97e300
(its a 98 now)
109
07-01-2014, 03:37 PM #3
Any link to where I could find a write up to this process?
This post was last modified: 07-01-2014, 03:38 PM by 97e300.
97e300
07-02-2014, 12:11 PM #4
u can´t was a old timer that explained to me the process.
a bush mechanic.
regards
a bush mechanic.
regards
mantahead
07-06-2014, 09:26 AM #5
hi,
here is results from diy element swap, you can see calibration is out.
that is mechanical pump, i had elements in electronic pump before that.
This post was last modified: 07-06-2014, 09:27 AM by mantahead.
mantahead
hi,
07-07-2014, 02:29 AM #6
For super budget, the engine would work.
But really, the c£500 for fit and balance should be invested.
