STD Tuning Suspension Anyone know what the differences are on Dodge multilink rear?
07-02-2014, 09:45 AM #1
I believe it's the same geometry as the 201/124/202/210?
97e300
(its a 98 now)
109
07-02-2014, 10:41 AM #2
If I'm correct, they use the same tooling as mercedes did, making them very similar. Not sure, however, how they bolt up. Would a chrysler 300 subframe bolt into a 210?
97e300
07-02-2014, 10:41 AM #3
Chrysler 300, Dodge Magnum ('05-) and Charger ('06-) are based on the LX-platform which is basically a W210 E-Class. I don't know how similar they are, I guess it's been modified to fit and is not a plug&play to a MB.
edit: http://www.ebay.com/itm/11-Dodge-Charger...0336526344
This post was last modified: 07-02-2014, 10:46 AM by DiseaselWeasel.
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
07-02-2014, 12:16 PM #4
Ya I dunno, it sure looks close!
07-02-2014, 04:33 PM #5
I always wanted to know if this Energy Suspension polyurethane bushing kit could be adapted to the 124 or 210.
http://www.fasthemis.com/prothane-total-...-2010.aspx
http://www.moparmusclemagazine.com/techa...ederated=1
Austincarnut
07-02-2014, 08:12 PM #6
sliding rear calipers?, very 211
(07-02-2014, 10:41 AM)DiseaselWeasel Chrysler 300, Dodge Magnum ('05-) and Charger ('06-) are based on the LX-platform which is basically a W210 E-Class. I don't know how similar they are, I guess it's been modified to fit and is not a plug&play to a MB.
Austincarnut
07-03-2014, 08:30 AM #7
(07-02-2014, 04:33 PM)DeliveryValve I always wanted to know if this Energy Suspension polyurethane bushing kit could be adapted to the 124 or 210.
The rear link bushings on the merc need to be bonded inside a metal sleeve to press into the links. It would be a motherbitch to get that rubber out of those things. Hedgehog motorsports/AKE at 190 rev sells this stuff for the 201/124/129. I recommend them along with the poly subframe bushings.
97e300
(its a 98 now)
109
07-04-2014, 06:26 PM #8
I wonder if you could swap the aftermarket suspension links from the gm cars
97e300
07-05-2014, 04:54 AM #9
It's all been made specifically for our cars allready: http://www.hedgehog-motorsport.com/2012/...-benz.html
DiseaselWeasel
97e300
(its a 98 now)
109
07-05-2014, 02:27 PM #10
wait, where do you buy them?
97e300
07-07-2014, 09:07 AM #11
You can hit ake up on FB, or PM him on 190rev. Here's the group buy thread, http://forum.190rev.net/showthread.php?3...thane-bush it's got pricing in there somewhere. You'll need to verify which parts will fit a 210.
This post was last modified: 07-07-2014, 09:07 AM by raysorenson.
