STD Tuning Drivetrain Mercedes ml 4x4 6 speed manual gearbox any good???
diesel dave
08-13-2014, 05:21 PM #1
Hello I've just acquired a landrover 90 with bad engine. Thinking on changing it to a 606 with a few upgrades. Has anyone on here any experience with the 6 speed gearbox fitted to the Mercedes ml270cdi? Any ideas on how much hp/ torque they can hold? Thanks
diesel dave
CRD4x4
CompoundSuperTurboDiesel4x4!
399
08-13-2014, 09:59 PM #2
Yes! More 4x4 STD!
The ML270 CDI was available with a NSG-370 except in the USA.
Here we have that transmission in Chrysler/Jeep/Dodge applications.
Its rated at 370nm (273lbft) thus the "370" in its name.
I don't know how far they can be pushed before breaking but I personally wouldn't use one behind a 606 or even my 2.8L CRD.
I posted a link to a BMW GS6-53 6-speed in the FS section. It doesn't bolt up to a 606 or have a married transfer case option but is rated at 530nm. The guy wants $500 obo.
(08-13-2014, 05:21 PM)diesel dave Hello I've just acquired a landrover 90 with bad engine. Thinking on changing it to a 606 with a few upgrades. Has anyone on here any experience with the 6 speed gearbox fitted to the Mercedes ml270cdi? Any ideas on how much hp/ torque they can hold? Thanks
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Yes! More 4x4 STD!
08-14-2014, 02:58 AM #3
Engine is limited to 370nm with manual trans... Probably for a reason.
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
08-14-2014, 06:45 AM #4
Surely use an R380 gearbox and chain drive transfer box from an early rangerover?
'Just' make a belhousing adapter plate!
mario
08-14-2014, 08:52 AM #5
Have you looked at Ashcroft for drivetrain upgrades but keep the landie gearbox
mario
08-15-2014, 08:09 AM #6
The 606 bell pattern is listed here, pull the LR transmission and have it measured. Fiarly easy for a machine shop to make an adapter (probably)
Use 606 FW/pressure plate
use LR clutch disk
good to go
You will spend hte most time measuring everything
use LR clutch disk
good to go
