STD Other Projects W202 Wagon build thread - *NOW OM606*
  • 2 Vote(s) - 4.5 Average
Pages (3): 1 2 3 Next
08-14-2014, 08:59 AM #1
Hello all,
I have been a long time lurker building ideas and designs, nothing physical until now.  Bought a 99' W202 Wagon C250TD, because well it looks bad ass! (18" 2004 CLS AMG wheels).
[Image: photo7.jpg]
originally wanted to swap a 606 in for instant more power and beans, but alck of space has stopped this happening, next plan was HX35 on ported factory manifold with my adapter, and quick spool valve which is still in developmemt:
[Image: photo.jpg]
Trial fitting on a friends 606 here.
[Image: photo6.jpg]
Note v-band is to allow fine tuning of turbo position to clear cam cover and inner wing / elec. heating pump..
I will probably fit a wastegate to the EGR port after opening it up a bit because compounding is the way forward and stock turbo w/external wastegate HP compounded by a LP HX35 will be lovely.
[Image: photo4.jpg]
I've shown my cutdown 606 manifold before but here it is in context, being welded this weekend by Hugh_F, I've bought another 606 manifold to make another OM605 converstion one to sell if anyones interested, (allows boost hose to enter from below as per W210.
I have also deleted AC condensor to fit an Evo 6 IC this weekend which I will doccument and share (easy fit), also I have deleted the AC compressor for easy piping from IC to my hybrid manifold - If you do this you will need a shorter belt model 6PK2080 from http://www.camskill.co.uk/ to do this was about £15! Pics of that to follow..
[url=http://s1250.photobucket.com/user/Mercedes_Power/media/image6.jpeg.html][/url]
This post was last modified: 05-17-2017, 04:52 PM by Hario'.
Hello all,
[Image: photo7.jpg]
[Image: photo.jpg]
[Image: photo6.jpg]
[Image: photo4.jpg]
mario
08-14-2014, 09:05 AM #2
I like the manifold as would it be possible to just remove the very last two cylinders off it and weld up the plenum chamber after
mario
08-15-2014, 05:26 AM #3
No, the central runner (Cyl.4) has to be removed to keep the last runner to keep the manifold profile for oil filter clearance/removal, I'll add an installed pic this weekend if the rain holds off!
Stevo-trendy
08-15-2014, 09:08 AM #4
Good work so far mate & nice clean lookin w202 estate !!
Stevo-trendy
sorin_cel
71
08-24-2014, 08:48 AM #5
why you want it to look like OEM? any problems at the MOT station?Undecided
sorin_cel
08-24-2014, 09:11 AM #6
Or maybe he just wants a nice looking engine bay Smile I too get wrinckled toe nails if I see blue or red silcone hoses and colored wires all over the place...
Make it look nice! Smile I like this! It's much more work, but it certainly pleases the eye.
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
08-26-2014, 07:04 AM #7
I like performance tuning where it can almost pass for stock, OEM+1 is the expression over here in the UK..
Tell a lie actually, I needed to remove the crossover boost pipework and EGR equipment to allow clearance for a bigger turbo, and a 606 manifold cut and shit was the easiest and most elagent way of doing it, and because I can and it looks bad ass of course!
This post was last modified: 08-28-2014, 02:46 PM by Hario'.
09-22-2014, 09:08 AM #8
For those that don't know, the lower radiator support on a W202 is like sheetmetal origami and the hard plastic charge hoses ninja snake around the supports, so to allow big intercooler fitment I had to cut it all abck and fabricate a lower rad support from sheet stainless, see below. Its clude but strong and will never decay.
I basically cut out the support but remounted / positioned the lower face of it which houses the rad / IC mounting lugs, with my stainless origami.
[Image: photo9.jpg]
[Image: photo-1.jpg]
Evo.6 IC install to follow.
This post was last modified: 09-22-2014, 09:09 AM by Hario'.
[Image: photo9.jpg]
hooblah
09-22-2014, 02:48 PM #9
Nice! You must take me for a spin at some point!
hooblah
09-26-2014, 10:23 AM #10
FOUnd a few more random build pics.. For OEM exhaust manifold flow I will die grind the aperture out to the 2" ID of the weld-els, its no KKD but it was cheap and easy!
[Image: photo5.jpg]
[Image: photo3.jpg]
THe v-band obviously won't support the tubo on it's own so before installation i'll fabricate a turbo brace / suppert something that looks like this F1 turbo era one because RACE...
[Image: turbobrace.jpg]
[Image: photo5.jpg]
[Image: photo3.jpg]
10-20-2014, 10:59 AM #11
Made a start on Mk.2 OM605 manifold cut from OM606 for MAX on this forum, I think painted / powder coated black will give it best OEM as the weld is a big give-away.. lol
[Image: OM605ManifoldMk2.jpeg]
Edit: Hmm I'm getting good at that!
This post was last modified: 10-20-2014, 10:59 AM by Hario'.
Max
Turbinaaa
87
10-20-2014, 02:13 PM #12
(10-20-2014, 10:59 AM)Hario I'm getting good at that!
Big Grin Wink
______________________________________________________________
93´ W124 300TDT -> OM606.962 / RS 203 Dieselmeken 7,5mm 210cc / KKK K14 / Stock Transmission / 2,65 ASD
89´ 190D 2.5 Turbo -> OM605.960 / Dieselmeken 7,5mm 180cc / Holset HX30 Super / 716. 654 6-Speed / 2,87 Rear Axle
Max
Big Grin Wink
11-18-2014, 08:22 AM #13
I designed an ALDA for a friends 603 pumped OM606 build, saw this on the Googles and improved upon it:
[Image: ALDA6.jpg]
Used a signle-acting (spring return) pheumatic cylinder I had lying about:
[Image: ALDA5.jpg]
Had to make a slotty-thing for the actuating rod because the cylinder would rotate with the (good) vibrations
[Image: ALDA2.jpg]
As installed, has locking nut adjustment for bottom and top travel, the return spring only holds about 5 psi so will have to add one with a tension adjuster to adjust fuelling increase point to match the holset boost curve..
[Image: ALDA4.jpg]
[Image: ALDA3.jpg]
Hopefully somone gets some inspiration from it.
This post was last modified: 11-18-2014, 08:23 AM by Hario'.
[Image: ALDA6.jpg]
[Image: ALDA5.jpg]
[Image: ALDA2.jpg]
[Image: ALDA4.jpg]
[Image: ALDA3.jpg]
11-25-2014, 06:48 AM #14
Attempt 2 at OM606 manifold cut down for OM605..
[Image: photo10.jpg]
[Image: photo3-1.jpg]
[Image: photo2-1.jpg]
Bead blasting makes a big diffence, black paint or powdercoat will be the finishing touch though.
[Image: photo1.jpg]
[Image: photo1.jpg]
12-08-2014, 10:04 AM #15
More progress..
Mitsubishi Evo 6 nearly installed, just working out how best to design some non-shit bracketry..
[Image: photo12.jpg]
[Image: photo22.jpg]
[Image: photo32.jpg]
Cremé leather interior as the OEM fabric ones were fucked because previous owner owned/was a dog..
(Shopping for cremé door cards...)
[Image: photo13.jpg]
[Image: photo23.jpg]
More progress..
MrHope
01-08-2015, 06:59 AM #16
Do you now have the adapter on the om605?
W124 300D 1985 (daily driver)
MrHope
01-09-2015, 06:39 AM #17
Nope I am straight-through-ing the exhaust at the moment..
[Image: exhaust3.jpeg]
[Image: exhaust2.jpeg]
[Image: exhaust1.jpeg]
NB. I think it will be laggy so I am looking for a 9cm2 turbine HX35. But as per your g-waggen build thread, without 7.5mm elemens it will be a bit pointless. Lots of lag then only 30-40hp more than normal.. So I will probably start shopping for elements.
This post was last modified: 01-09-2015, 06:54 AM by Hario'.
MrHope
01-09-2015, 04:49 PM #18
Ok, i have sent my pump to dieselmeken and we talked about hp and the 6mm will work fine for 200+hp i will not need more it will only cause more trouble for my clutch, the car is heavy.. I think i will start out with the 606 turbocharger..
MrHope
02-05-2015, 11:02 AM #19
Decided to fit OM606 as it is (mostly) a direct swap onto UK spec C250TD, as I have the 722.6 and the EDC part of the pump is the same, hope it should just plug and play.
Got OM606 from Polish man, he said 'it run till the end', IDK if that means it ran until he took it out or it ran until it exploded.
Anyway it looks nice. Has genuine MB fuel pipe replacement kit fitted, few filter pipes are broke but that looks like all.
[Image: 606%20front.jpg]
[Image: 606%20top.jpg]
[Image: 606%20fuel%20filter%20top.jpg]
The water pump pulley should not be rubbing the crank pulley.. (crashed?)
[Image: water%20pump%20interference.jpg]
Got mocal oil cooler from my old Mini because 605 come with water/oil exchanger.
[Image: Mocal%20oil%20cooler.jpg]
I will use the OM605 loom and just jump the #6 glow plug lead onto the #5 wire until I get a 606 glow relay.
Also as discussed elsewhere 605 has 5 flywheel tags and 606 has 6 so flywheels have to be swapped to keep OEM C250 tach happy, otherwise it would under read by 16% (ish), more importantly ECU would make EDC idle at 550 rpms (also ish).
Garage space booked for swap end of Feb, woo!
This post was last modified: 02-05-2015, 11:06 AM by Hario'.
03-03-2015, 10:29 AM #20
The rest of the build and pictorial 'instructions' are here for those who are interested in doing the swap themselves.
http://retrorides.proboards.com/thread/1...To=2051432
Looks good though!
[Image: 2_5.jpg]
[Image: 1_6.jpg]
Looks good though!
[Image: 2_5.jpg]
[Image: 1_6.jpg]
03-04-2015, 01:49 PM #21
http://youtu.be/NUgUJ2jkB_M
03-04-2015, 03:26 PM #22
Probably just a pumped up lifter.
Ksteen2
03-05-2015, 03:46 AM #23
it's a lifter, i hade the same problem with my engine..
it's comon when the engine stand still for long.
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
03-10-2015, 10:42 AM #24
[Image: 2_7.jpg]
This is my favourite
[Image: 2_7.jpg]
03-10-2015, 11:11 AM #25
Wrapped the steering box hard pipes with that NASA looking thermal wrap stuff, only cost £10/meter from internets.
[Image: photo%201.jpg]
Fitted E300 turbo outlet pipe to C250 DP..
[Image: photo%201%202.jpg]
Not too much cutting needed.
[Image: photo%203.jpg]
[Image: photo%202.jpg]
Ksteen2
03-10-2015, 07:20 PM #26
exhaust brake?
hehe, just kidding, is it that limited space on those RHD cars? :o
now I'm happy I have LHD car :p
1#
Originaly a d24tic
6speed cdi box
Ksteen2
exhaust brake?
1#
Originaly a d24tic
6speed cdi box
Kalti
03-15-2015, 02:15 PM #27
nice projekt!
and do you want to sell the intake manifold from the om605?
Kalti
nice projekt!
03-16-2015, 07:58 AM #28
Haa! Exhaust has silencers and catalytic converter removed so not too much restriction, and it is factory 2.5" 63mm anyway. As these are the last to come with a steering box it is quite tight. Plenty space to go upto 3.5" DP but no point on that manifold and microturbo. But the car is much faster now.
dcm
03-18-2015, 02:07 PM #29
Nice job, looks factory fitted. I always hoped my 605 would blow up to justify fitting a 606 as a replacement. How much space is there between the engine and radiator?
dcm
03-19-2015, 08:27 AM #30
Thanks! That was always the goal, the HX35 will make it a bit less OEM so I will paint is black I think.
Well I bought this 606 for £150 with the £150 that I sold my 605 for..
I made a bracket to hold the original lower radiator bracket more forward so the radiator sits under the slam panel just like on the C32 AMG. Then you can use the original viscous fan and coupling or a slim electric fan. But if you want a bigger intercooler you will have to relieve the inside of the front crossmember for clearance like I did, by drilling the spot welds and hacksawing down the inside face like I did here, took 50 minutes:
[Image: 1_5.jpg]
You will also have to make some shoddy ARB mount drop brackets like mine for sump clearance, these lower by 30mm, 50mm would be better IMHO.
[Image: 3_4.jpg]
[Image: 1_5.jpg]
[Image: 3_4.jpg]
Ksteen2
03-20-2015, 05:00 AM #31
looks nice Smile
yeah, i get that :p
with a new manifold you will get the space you want so Wink
1#
Originaly a d24tic
6speed cdi box
Ksteen2
looks nice Smile
yeah, i get that :p
1#
Originaly a d24tic
6speed cdi box
04-13-2015, 07:26 AM #32
(03-18-2015, 02:07 PM)dcm Nice job, looks factory fitted. I always hoped my 605 would blow up to justify fitting a 606 as a replacement. How much space is there between the engine and radiator?
There is about 5mm too little room to fit the OEM viscous fan, so I think I will do more cutting and modifying and move the radiator and intercooler forwards more.
It had a mysterious running problem where it would cut out as if the key was turned off after about 20 minutes of driving or idling.. Puzzled for ages, I thought it might be the RPM sensor as the EDC is unlikely to be faulty and there are no other engine sensors which would affect running.
Cured the problem straight away! WIll make a driving vid next weekend.
Also cut out the bumper for IC flow, should make a duct really, shame the red/blue pipes make it look chav.. Pressed aluminium Euro plates looks good tho, last mod to do it 3k ohm resisitor mod Smile
[Image: 7AA519F9-38FD-4E38-A6AA-5D5C4686E171.jpg]
[Image: 1C9861A8-C222-46F8-80AF-3F632B37AFAA.jpg]
dcm
05-07-2015, 03:02 PM #33
I've painted boost pipes black before which has worked ok. Any updates or video?
dcm
07-24-2015, 07:44 AM #34
Just the vid of the first start
https://youtu.be/NUgUJ2jkB_M
it's actually in my parents barn in Bordeaux at the moment as my previous company provided a mandatory company car and I have limited parking space. Fortunately that has now changed and I'll be driving it back to London relatively soon then the 606 can get the STD treatment..
08-13-2015, 07:58 AM #35
[Image: 5D3C3FF5-05A2-4066-891D-E679C2B04DCE.jpg]
[Image: EA5F3A54-945D-4C14-9580-45A34902BA2D.jpg]
Nice.
Nice.
dcm
08-16-2015, 10:51 AM #36
Looks good, always like the wagon shape. What's your plan for the gearbox?
dcm
08-28-2015, 05:32 AM #37
I'm going to buy an Ole controller as soon as I'm not poor from my house move and job change..
I thought for once I should do a car project in the right order so I am doing some light 'restoration' works, in as far as new (un cracked) tail lights, a rust free tailgate, Frenched (yellowed) side lights like the guy with the white w123 on here somewhere.
Also the radiator n3eeds to move forward another inch to allow me to refit the factory visco fan, as it currently has none. Unfortunately the tranncy cooler in the radiator header tank causes the rad to not fit between the headlights so I have got myself a manual C250TD rad which obviously doesn't have the cooler. So I'm now collecting parts to install an air/oil tranny cooler above the intercooler to allow the rad swap to happen. If that makes sense..?
08-29-2015, 02:23 AM #38
http://www.mymbonline.com/forum/1917848-post1.html - some inspiration Smile On my coupé I painted the refelctors with yellow light bulb paint. It's been holding up well for 3 years now Smile (see sig)
DiseaselWeasel
12-02-2015, 11:30 AM #39
I started work on my new exhaust manifold because some peoples on here says my turbo is tiny and my downpipe is shit.
[Image: 1_8.jpg]
[Image: 2_8.jpg]
[Image: 3_7.jpg]
[Image: 5_3.jpg]
[Image: 4_6.jpg]
[Image: 6.jpg]
Just proof of concept ovalising 2" x 1.5" reducers with hammer and anvil, I will have to cut down the reducer and bends for cylinders 5 & 6 to clear the down pipe but that is ok.
Will start tacking soon, got to pay for my HY35 also. Got a Tial 38mm wastegate for the HP turbine bypass. I hope it, along with the HY35's internal gate will be enough bypass, I should measure HP turbine differential pressure to establish if that is the case (eventually).
[Image: tial%20wastegate.jpg]
It is more in focus in real life.
[Image: 1_8.jpg]
[Image: 2_8.jpg]
[Image: 3_7.jpg]
[Image: 5_3.jpg]
[Image: 4_6.jpg]
[Image: 6.jpg]
01-04-2016, 08:22 AM #40
Bought a big Mocal cooler to cool the ATF, and will be mounted under driver side wing, behind bumper, opposite where it goes on W124 & W210.
[Image: oil%20and%20atf%20cooler.jpg]
[Image: atf%20cooler_1.jpg]
The long thin oil cooler is made by Radtec and should squeeze in the space above the IC, because on UK spec W202's there are horns, wiring and pipes on the other under wing/bumper area (where oil cooler is normally fitted on W210)
[Image: oil%20cooler%20fitment.jpg]
The oil cooler has nice and big -12AN fittings which will marry up nicely to the 606's 19mm 3/4" oil cooler hose.
[Image: oil%20cooler%20AN12%20fitting.jpg]
This post was last modified: 01-04-2016, 09:08 AM by Hario'.
01-04-2016, 09:01 AM #41
Rumble from NSF wheel bearing so I found a complete low mileage front knuckle for under £20, then had to spend the same again on a BJ splitter set as there is 3 different sizes on the knuckle.
[Image: bj%20swap_1.jpg]
[Image: bj%20splitters.jpg]
01-04-2016, 09:16 AM #42
Bought a W220 S500 front caliper to make a start on my big brake upgrade, I can confirm they fit the W202 knuckle and clear the dust shield (only bented it from me splitting BJ's).. They will need 3 or 4mm bolt spacers between the caliper and the knuckles, I'm going to get some machined because mild washers aren't good enough.
That's the stock disc obviously, I need W203 AMG (330mm) discs for a bolt on swap (I think-hope).
Got to make up brake hoses 100mm longer and M10 banjo on the outer.
Does anybody know the thread & fitting type on the inboard bulkhead fitting for the flex onto the hard pipe under the wing?
[Image: w202%20w220%20caliper%201_1.jpg]
[Image: w202%20w220%20caliper%202.jpg]
Beers.
Beers.
02-01-2016, 11:34 AM #43
Moderate levels of progress
[Image: 0931FBB4-B67C-4403-A979-D214103C0878.jpg]
[Image: E5022A5D-3B97-4332-892A-6E734B60F0F9.jpg]
sorin_cel
71
02-01-2016, 02:56 PM #44
Nice start on the manifold Smile
i'm curious if the w220 brakes will fit spot on.
sorin_cel
02-02-2016, 05:21 AM #45
(02-01-2016, 02:56 PM)sorin_cel Nice start on the manifold Smile
Thanks, did too many beers to make real progress.
The w220 caliper fitted the knuckle fine, even the dust shield cleared. Just needs custom hoses and euro spec W203 AMG cdi discs (330mm).
02-02-2016, 07:02 AM #46
sorin_cel
71
02-08-2016, 04:56 PM #47
i've got w220 4 pot calipers now, but i need discs. apparently the w210 E430 330mm discs should be a straight fit. Try it. Let me know, cheers  Undecided
sorin_cel
02-09-2016, 11:25 AM #48
(02-08-2016, 04:56 PM)sorin_cel i've got w220 4 pot calipers now, but i need discs.  apparently the w210 E430 330mm discs should be a straight fit. Try it. Let me know, cheers  Undecided
It is all about the disc offset.
I know C270-320 CDI 2000-2007 have the correct disc offset for w220 calipers onto W202. I am not sure about any others.
Also note the W220 calipers will need a hardened washer between the caliper mount and the steering knuckle to make the caliper sit centred on the disk.
The run out was 4mm I think, so 2mm hardened washers need to be bought or made, let me know if you find some!
MartinB
OM605 Power
154
02-09-2016, 05:23 PM #49
I bought W220 S600 Calipers for my W210. These are for 345mm discs Wink
W210 E200CDI 185kW Manual, W203 C30 CDI AMG 210kW Manual
MartinB
02-10-2016, 07:51 AM #50
(02-09-2016, 05:23 PM)MartinB I bought W220 S600 Calipers for my W210. These are for 345mm discs Wink
Yep, the S500 ones are 330mm but and loads cheaper here in UK anyway
