STD Tuning Drivetrain 722.6 vs 190 (W201)
722.6 vs 190 (W201)
722.6 vs 190 (W201)
Benjamin
STD Beginner
23
08-17-2014, 06:59 AM #1
Hello
I'm just wondering if the 722.6 transmission fits a 190?
I now it fits the engine the question is if it fits in the gearbox tunnel.
Maybe someone now.
I would like to mount This gearbox.
Benjamin
Hello
Maybe someone now.
08-18-2014, 02:25 AM #2
Yes, clearance is tight and mount fits.
Benjamin
STD Beginner
23
08-18-2014, 09:03 AM #3
(08-18-2014, 02:25 AM)Hario Yes, clearance is tight and mount fits.
I can imagine that the clearance is tight. The 5 speed dogleg that I have now is also tight.
The mount ist the same (bolt on) or is a re-welding necessary?
What driveshaft fits? Maybe a OEM one from a 4 speed auto gearbox?
Benjamin
08-19-2014, 07:35 AM #4
We measured and believe the gearbox mounting cradle from the donor (W210 E300TD) will bolt to the 190 shell.
Don't think the 190 gearbox cradle will fit the 722..
Not sure, think the flex joints are different size, we are going to check the splines to see if the original 722 half pros shaft fits the 190 rear prop shaft and join them in the middle, will need length altering from thelooks of it.
Punchi
07-25-2017, 02:54 AM #5
Any more info on this??. Did you manage to mount it??
Punchi
