STD Tuning Engine Who can inform me on the 2.9td om602 in the sprinters?
Ekstra
08-20-2014, 01:59 AM #1
Would it be possible to put my current inline 5 mech. pump on a om602 2.9 from a sprinter? Im hearing it uses a rotary pump and direct injection and common rail.. Huh i have been thinking of replacing my 2.5td with a rebuilt 2.9td with a modded IP
Ekstra
Gforce
08-20-2014, 12:27 PM #2
It's not common rail, its direct injection with an electronic VE pump but you can make this pump mechanical
Gforce
speedynige
08-23-2014, 10:55 AM #3
(08-20-2014, 12:27 PM)Gforce It's not common rail, its direct injection with an electronic VE pump but you can make this pump mechanical
Is it an expensive / complicated conversion ie a diesel specialist or are the parts available for diy
speedynige
Stevo-trendy
08-23-2014, 01:06 PM #4
Buy a om662la engine there same just without the common rail & electronic injector pump , the 662's run a a inline mechanical injector pump as well
Stevo-trendy
speedynige
08-28-2014, 02:46 AM #5
(08-23-2014, 01:06 PM)Stevo-trendy Buy a om662la engine there same just without the common rail & electronic injector pump , the 662's run a a inline mechanical injector pump as well
What vehicle runs that engine please
speedynige
Stevo-trendy
08-28-2014, 07:25 AM #6
Daewoo/ssyanong musso
Stevo-trendy
