STD Tuning Engine is it possible to make idi OM662 =>> direct injection???
pmj4147
T04R + TD06
42
08-27-2014, 12:43 PM #1
So the question is,
Is m-pump can be working on direct injected OM602 from sprinter??
thanks for reading.
This post was last modified: 08-27-2014, 12:43 PM by pmj4147.
2002. 09 Ssangyong Musso SUT
2002. 12 Ssangyong Korando
pmj4147
So the question is,
thanks for reading.
Stevo-trendy
08-28-2014, 10:13 AM #2
Wouldent fuel delivery time be to slow if running inline mechanical pump on a direct injection engine ?
Stevo-trendy
uli124125
08-28-2014, 03:31 PM #3
oh whom is this incorrect statement?
uli124125
Stevo-trendy
08-29-2014, 06:25 AM #4
I stand corrected then I thought bosch Ve pumps flowed higher amounts of fuel then inline injector pumps
Stevo-trendy
08-29-2014, 03:41 PM #5
hello there,
it is possible go from IDI to DI, lot of changes have to be done.
at cylinder head, new holes for glow plugs, direct injector holder.
in engine, pistons with combustion chanbers, or DI pistons from other engine.
injection pump, has to be a didicated DI pump, wich a Bosch M it is not, so a Bosch VE is the solution, most bosch VE are electrical so ECU is needed as well and along with all the hardware necessary.
i intend to do something like that, with the remains of a 612 and a 605.
so why not to share some infoWink
hello there,
uli124125
08-29-2014, 05:27 PM #6
yes and no MWM oder MAN or such motor or even IHC which are often tuned extremly drive with Inline pump^^
uli124125
08-30-2014, 10:04 AM #7
(08-29-2014, 05:27 PM)uli124125 yes and no MWM oder MAN or such motor or even IHC which are often tuned extremly drive with Inline pump^^
I bet it can be extremely dificult to have a bosch M working with a DI system, it can be done but it wont work as desired.
and if it was posible and feasible MB didn´t had to change to VE in some DI engines Big Grin.
Petar
7.5mm M pump
459
08-30-2014, 04:19 PM #8
It might just work with bigger elements ? Blacksmokeracing uses a 8mm M pump for Om606 DI and the old 7mm ford transit elements are made for DI.
Petar
08-31-2014, 09:37 AM #9
There all lots of DI engines with inline pumps. Mostly what is changed is pop pressure in the injectors, but that doesn't change the pump. The same pump for an IDI should work the same for a DI in my thinking.
08-31-2014, 11:17 AM #10
If not - there are plenty of mechanical VE pumps for 4, 5 and 6 cylinders from VW engines. IMO DI requires rather short injection time (not timing), at least that's what Dieselmeken wrote somewhere. On the other hand, most commercial DI engines use inline pumps. The'r far of being high reving, high output engines though. There will be a solid reason 290 engine got a VE pump...
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
Petar
7.5mm M pump
459
08-31-2014, 11:38 AM #11
According to bosch books the M pump is not suitable for direct injection.Why ? I have no idea.
I still think that old ford transit 7mm elements would work well for a DI application.
But that same books says that the MW pump is not suitable for IDI and max engine speed of an engine with the MW pump is 2600 rpm Huh and we know it is used on 5000 rpm IDI OM617
[Image: h8DrVHB.png]
Petar
08-31-2014, 12:17 PM #12
That chart doesn't make much sense to me. It says the MW is only suitable for DI engines.
Interesting chart
Interesting chart
09-01-2014, 08:04 AM #13
yep , i know of a few DI engines with inline pumps, every DI engine in Komatsu heavi equipment has a diesel kiki pump wich is a copy of a P series from bosch, some ford DI aplications in agricultural tractors, use diesel international pumps. jonh deere, Scania, volvo and so on.
do u guys know as well, that DI engines require injection advance during engine RPM range , is it the same as a IDI, it is not and i dont know the diff, !
u guys do know that rotary style pump has the advance inside !
Injector pressure for DI usually is around 400BAR and above, is possible for a m pump produce a injection of that pressure during the amount of time needed for a good operation, i dont know!
those are the considerations that goes in mr Dieselmeken head , or any other person dealing with IP rebuilding and tunning,
one of this days i will try it, i bet it wont work, and i will have to go search for a VE.
regards.
regards.
