STD Tuning Engine diesel pump
diesel pump
diesel pump
gary andrews
4x4 builder
48
08-29-2014, 01:20 PM #1
hi im putting a c250 diesel 605 into a discovery was just wondering if I put a SsangYong diesel pump off a 2.9 turbo what power it would give before I had the elements done
discovery 2 fitted om605 m pump 7.5 elements 300 turbo at mo
c250 std at mo
off road buggy fitting om 606 turbo ? supercharger ? to follow
www.gaz-fab.co.uk www.facebook.com/gazfab
gary andrews
c250 std at mo
09-01-2014, 07:05 AM #2
No idea, good shout though
Petar
7.5mm M pump
459
09-01-2014, 09:14 AM #3
If you don't adjust the pump it will have exactly the same power as the ssangyong engine.
Maybe a couple hp more (no more than 10) due to improved efficiency
This post was last modified: 09-01-2014, 09:20 AM by Petar.
Petar
baldur
Fast
506
09-07-2014, 10:12 AM #4
The SsangYong pump has 5.5mm elements and will max out somewhere around 140-150hp when properly adjusted.
Baldur Gislason
baldur
Baldur Gislason
