STD Tuning Engine turbo oil feed
turbo oil feed
turbo oil feed
bjarni97
09-07-2014, 11:15 AM #1
When you guys turbo a non turbo om 603. Where do you get a clean oil feed.
Is the oil at the oil pressure sensor pre filter or post filter.
bjarni97
baldur
Fast
506
09-07-2014, 04:51 PM #2
There's a port on the back of the cylinder head that takes a banjo bolt, 18x1.5mm if I recall correctly.
You can also fit a tee inline with the oil pressure switch on the oil filter housing.
Baldur Gislason
baldur
Baldur Gislason
Max
Turbinaaa
87
09-07-2014, 05:59 PM #3
Om60- 1/ 2 / 3 have a Port at the back of the Cylinderhead.
Size is M10 x 1
I use it for Oiltemperature at my Turbo-OM602 Wink
______________________________________________________________
93´ W124 300TDT -> OM606.962 / RS 203 Dieselmeken 7,5mm 210cc / KKK K14 / Stock Transmission / 2,65 ASD
89´ 190D 2.5 Turbo -> OM605.960 / Dieselmeken 7,5mm 180cc / Holset HX30 Super / 716. 654 6-Speed / 2,87 Rear Axle
Max
Size is M10 x 1
bjarni97
09-09-2014, 04:45 AM #4
Thank you.Big Grin
bjarni97
Thank you.Big Grin
