STD Tuning Engine my G300TD project
my G300TD project
my G300TD project
kotka
09-21-2014, 01:07 PM #1
Started last autumn when original KKK died Smile)))
All-in: many changes implemented, started with 10mm fuel lines installation and ending up with EGT sensors set up on every runner (still adopting). its a "daily-driver" and offroader.
I'd like to share the first dyno test results. I would appreciate your comments on the curves.
PS dont look onto the boost - the stock map limits boost at 1.4 bar level. this is my next action on my to-do list. i.e the results below are at 1.4bar boost.
[Image: 1f8652cs-480.jpg]
[Image: 8d0152cs-480.jpg]
This post was last modified: 09-21-2014, 01:18 PM by kotka.
kotka
Whizbang
09-21-2014, 10:28 PM #2
i want it!
Whizbang
i want it!
kotka
09-24-2014, 12:48 AM #3
Hey, no comments on the curves? Smile)))
I keep optimizing my set up so yr comments are appreciated
kotka
AlanMcR
mind - blown
400
09-24-2014, 03:32 PM #4
So, what are the changes you have done?
What is your 0-100kmh time now?
I have the same G. The only changes I've made are:
Eliminate the EGR (electronically) including hollowing out the mixer.
Right side exhaust w/ straight through muffler.
AlanMcR
kotka
09-24-2014, 10:33 PM #5
Both manifolds; 3 inch exhaust; efr turbo; Egr, elab, transducers removed; fuel maps recalibrated; visco removed - electric fan installed; new front a/a intercooler; 10mm fuel lines; 7 mm plungers; all O-rings removed; snorkel; k&not filter (copy).
Acceleration is roughly 8 sec
Fuel consumption dropped to 11-13.5l/100 level (mind 2inch lift and 33inch bfg)
kotka
