STD Tuning Engine CDI OM648 chips for more power
MTUPower
287
09-26-2014, 01:11 PM #1
There's many chips listed on USA ebay which claim to be for the 2005 CDI to increase power and mpg. Who has a recommendation and what experience have you had with that chip ?
This post was last modified: 09-26-2014, 01:17 PM by MTUPower.
MTUPower
Duncansport
09-26-2014, 01:22 PM #2
(09-26-2014, 01:11 PM)MTUPower There's many chips listed on USA ebay which claim to be for the 2005 CDI to increase power and mpg. Who has a recommendation and what experience have you had with that chip ?
We do Autologic performance flashes here. They work VERY well 35HP and 88TQ gain
There are a lot of shops in NY that own and use Autologic's.
Not sure about a "chip from ebay" Dodgy
Duncansport
MTUPower
287
09-27-2014, 01:18 PM #3
Here's a couple
http://www.ebay.com/itm/261574939707?_tr...EBIDX%3AIT
http://www.ebay.com/itm/220640200378?_tr...EBIDX%3AIT
http://www.ebay.com/itm/Diesel-Chip-Tuni...0378&rt=nc
MTUPower
Here's a couple
F.R.A.S
09-28-2014, 03:01 AM #4
Not even one of the listed eBay auctions are chip. Chip is a name for a software flash of the cars ECU. Please stay away from "boxes" they will cause you problems.
F.R.A.S
MTUPower
287
09-28-2014, 07:34 AM #5
could you elaborate? Tell us why? If it's removable and you can change back to stock why would it cause problems?
Thanks!
MTUPower
Thanks!
Petar
7.5mm M pump
459
09-28-2014, 08:45 AM #6
Long story short tuning boxes make the ECU overfuel the engine. This makes more power but also causes high EGTs and can damage the engine and the turbo.
Petar
Duncansport
09-28-2014, 12:45 PM #7
Do it correctly, AL tunes usually run 500-700 depending on the shop.
Duncansport
MTUPower
287
09-28-2014, 03:51 PM #8
(09-28-2014, 08:45 AM)Petar Long story short tuning boxes make the ECU overfuel the engine. This makes more power but also causes high EGTs and can damage the engine and the turbo.
High EGT's take a bit of time to develop with your right foot buried, and it has to stay there over a longer time to cause damage. What is done with the $500-$700 which mitigates that?
BTW folks I'm not trying to make anyone mad or being flippant, and nor am I a noob. My day job is captaining a sportfish with a set of DD's 16V92's rated at 1450HP. I've owned many many diesels and maintained them all myself. It is my first CDI however.
This post was last modified: 09-28-2014, 03:57 PM by MTUPower.
MTUPower
Petar
7.5mm M pump
459
09-28-2014, 04:03 PM #9
A remap will also increase the available air to burn the fuel by increasing the boost. Tuning boxes only increase the fuel.Remaps can also damage the engine with excessive EGTs but you really have to have your foot to the floor for a long period of time.
Also important is that a tuning box increases the fuel by increasing the rail pressure and that can be stressful on the fuel pump and the injectors.
A good remap will keep the EGTs relatively low.
A tuning box is the equivalent of turning up the full load without touching anything else on mechanically injected diesels.
An EGT gauge is in my opinion a must have on any modified diesel.
Petar
MTUPower
287
10-02-2014, 08:23 PM #10
Helpful- thank you.
I guess the real question is how harmful does the forum know that a tuner box is on the fuel pump and injectors? I won't be planting my right foot deeply often or for long time periods. Used lightly I can't imagine that a tuner box would be very harmful to the engine- and used lightly I won't need a EGT, although having one is always a good idea.
Still looking for experience of those who have a tuner box installed.
MTUPower
Helpful- thank you.
diesel2fast4u
10-03-2014, 02:35 AM #11
(10-02-2014, 08:23 PM)MTUPower ^^^^^^^^^^^^^^
Helpful- thank you.
Stay away from tuning boxes, get a good tune and you will be happy
Grand cherokee WK (OM642)
diesel2fast4u
Helpful- thank you.
MTUPower
287
10-03-2014, 09:46 PM #12
(10-03-2014, 02:35 AM)diesel2fast4u Stay away from tuning boxes, get a good tune and you will be happy
This advice does not recognize what I said previously. It's generic advice without the reasoning and support needed. No one had said convincingly why a $800 tune is better than a $80 tuner box for light use.
Nearly everything in life takes three things- time, knowledge or money. If you have more of one you need less of the other two. I have less of the third and more of the second- but I'm seeking higher levels of it and if members here have direct experience of using a tuner box and WHY it caused damage I'd love to hear of it. Generic advice is not as much worth as people think it is.
MTUPower
diesel2fast4u
10-04-2014, 05:40 AM #13
Bad day I guess.
First of all a good tune doesn't cost 800, and a tuning box doesn't cost 80.
A tuningbox is nothing more then a fooler, for example raises the fuel rail pressure and let the ECM think it's lower.
I tried a fueling box years ago on my OM642 (320cdi), paid 350, And I had the car going into limp al the time.
(10-03-2014, 09:46 PM)MTUPower
diesel2fast4u
Bad day I guess.
MTUPower
287
10-04-2014, 07:36 AM #14
Thank you for the response. One of the tuning boxes I listed is $89- and one of the "flashes" listed by a member is $700- add tax and you are closer to $750. It was a rounding off of simple figures- sorry if it made you angry. I appreciate your understanding of how a box works- "fooler". Long story short it adds fuel; um.... wow, really? You mean adding more fuel means more power? Who that understands anything about diesels does NOT know that? Of course it adds fuel.
Now your direct experience of going into limp mode- that is the advice and experience which is important. This is the only direct experience relayed on this thread so far which tells of actual detrimental actions of adding a tuning box; everything else is anecdotal. Thanks for the direct experience. Petar noted some good points but nothing which anyone who has worked on or modded diesels does not know already. Now who else has had the same results with regards to adding a box and going into limp home mode?
This post was last modified: 10-04-2014, 07:43 AM by MTUPower.
MTUPower
F.R.A.S
10-05-2014, 03:09 PM #15
The "box" is shit for a couple of reasons. Two already stated. They only raise rail pressure and they are common to throw error codes due to this...
A real tune or a chip or what ever you call it will modify not only the quantity of fuel delivered to the engine but also the timing and the boost pressure. EGT or not, a more aggressive timing will give you the same power alone as the tuning box does. Ad some fuel to that and a software that is made for the changes and you'll get a smooth running engine with plenty of power and that does what it's supposed to and will therefore not throw DTCs.
You can run a box if you like but please don't call it a chip, chiptune or tune. It's just a magic trick that makes you look at one hand when the other is making the "magic".
F.R.A.S
10-07-2014, 01:32 PM #16
CDI engines hum, hum, Wink ECU reprogram? have u heard about it in there? for a 200€ bill u can have a full reprogram without any problem and with garantie at least in my small country Wink
usually people choose from 2/3 standard types or ask them to write your own, in the end car will behave like 20HP increase.
http://www.pke.pt/index.php?option=com_w...&Itemid=77
http://www.turbotec.pt/mais-potencia/mercedes-benz
it is in portuguese but u can understand the point.
regards
regards
MTUPower
287
12-26-2014, 10:16 PM #17
Looking over TDI forums there are quite a few order by mail install yourself tuning boxes which are used successfully for greater power and better MPG and have been used by many with no long term issues. I went to Renntech and they quoted me $900+ for a reflash with seemed to me minor improvements of less than 25HP. Install time was less than two hours.
MTUPower
tuikku
12-27-2014, 02:11 AM #18
~600nm/250hp possible to get with orig. parts.
Cooler is tiny and dirty, with bigger cooler and 2bar map ~650/270.
Only diffult thing is to find desent softw. tuner.
If not - it is quite same thing to put that tuning-box in there.
tuikku
12-27-2014, 06:12 AM #19
(10-04-2014, 07:36 AM)MTUPower Long story short it adds fuel; um.... wow, really? You mean adding more fuel means more power? Who that understands anything about diesels does NOT know that? Of course it adds fuel.
And what does that fuel do if there's not enough air to burn it? *Puff!* - black smoke... Of course these engines run with excess air and to an extend just adding fuel works... Adding air (boost) AND fuel however will just net the better result in the end.
$89 is far from expensive - why not just try it?? You got advice - against - you know the possible outcomes. What's holding you back? Smile Try it! If it works - all good. If it doesn't - there's still another route to take...
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
MTUPower
287
12-27-2014, 09:09 AM #20
I have no plans to buy a $89 tuner box/chip. Green diesel engineering sells these for a variety of diesels with what appears to be proven success if the forum members of TDI sites are to be believed. They are $700. It's self installed if I understand correctly. Of course there are many companies which sell these.
MTUPower
12-27-2014, 09:17 AM #21
So what is the point of this thread then!? I don't understand... Undecided
DiseaselWeasel
MTUPower
287
12-27-2014, 12:57 PM #22
https://www.gmpperformance.com/index.cfm...PID=142338
I could buy this from Ebay or from Kleemann, same with a used Renntech if someone listed it on ebay. What plug and play systems (chips/boxes/tuners- whatever name you'd like to use) have folks used or heard of and what are your recommendations? That's the question. Thanks for your thoughts- and thanks for asking for the clarification.
This post was last modified: 12-27-2014, 02:18 PM by MTUPower.
MTUPower
MTUPower
287
12-27-2014, 09:59 PM #23
After reading 50+ pages on other sites I've found plenty of information and other cdi owners who have good recommendations. I appreciate all the advice and information listed here, and I don't think I'll need more info. Thanks!
MTUPower
hooblah
12-29-2014, 03:36 PM #24
So are you going to tell us about all this info you found?
hooblah
MTUPower
287
12-29-2014, 08:29 PM #25
(12-29-2014, 03:36 PM)hooblah So are you going to tell us about all this info you found?
Brabus flash/chip/box is good but more people are happy with the Kleemann- both were about the same price. Kleemann was easier to find. Renntech had no user experience and by their salesman's info alone it's less HP gain and more expensive; I went in to their HQ here in Florida and inquired. Green Diesel Engineering was favored by all who installed it over any other flash/chip/tuner box, and it can be programed to always close the EGR which effectively shuts it down and takes it out of the loop. This stops it from clogging and does so with no codes to trip. That's what I read/observed. Some folks removed the cat and replaced it with a straight pipe; the exhaust otherwise was sufficiently large and rear muffler removal or replacement yielded little tangible results. I larger IC would give results as well but it strictly custom fabrication by individuals- no plug and play units. Higher flowing AMG injectors would yield more HP but they are very expensive and you must buy the whole injector not just the nozzle. Despite the recommendations here no one had experience with autologic's tune/flash.
This post was last modified: 12-29-2014, 08:36 PM by MTUPower.
MTUPower
Duncansport
12-30-2014, 12:07 PM #26
We've done multiple Autologic flashes with great results. The one down side is that they do not support the Blutec cars or the BMW diesel line, at least for performance tunes.
Duncansport
MrHope
01-04-2015, 04:45 PM #27
If anyone is interessted i have a 648 engine layin around.
was taken out of car due to making pressure in water.
was fully drivable so maby bad headgasket or worst case crack i head.
i bought it because i needed oilpump and sump.
W124 300D 1985 (daily driver)
MrHope
Turbo
01-05-2015, 03:33 PM #28
You need to offer better price then when I spoke to you last Wink
(01-04-2015, 04:45 PM)MrHope If anyone is interessted i have a 648 engine layin around.
Turbo
MrHope
01-05-2015, 06:19 PM #29
call me again and we could make some kind of deal.
MrHope
