STD Tuning Engine OM617 Blind timing advance
Evenglass
11-09-2014, 02:39 PM #1
So my 617 has always been on the quiet side even with straight exhaust it really doesn't have that diesel sound. So while maintenance some stuff I noticed that the hash marks on the Injection pump don't line up. It appears the pump is set timing retarded.
[Image: 1609619_397517377080462_1708773673255250...576944.jpg]
Before
I adjusted to line up marks.
[Image: 10409028_397517363747130_316162586176121...3b9acd.jpg]
After
Was this a bad idea to do blindly without drip timing? Why didn't the marks line up before? Should I try to run this? thoughts? And for the life of me I can't get the bolt back on at the back of the pump, any harm in leaving it off?
Valves adjusted 5500 miles ago. Chain stretch within spec at 3*
This post was last modified: 11-09-2014, 03:04 PM by Evenglass.
Evenglass
Before
After
Volker407
naturally aspirated
157
11-09-2014, 06:03 PM #2
(11-09-2014, 02:39 PM)Evenglass So my 617 has always been on the quiet side even with straight exhaust it really doesn't have that diesel sound. So while maintenance some stuff I noticed that the hash marks on the Injection pump don't line up. It appears the pump is set timing retarded.
No problem running the pump in that position. But it is a problem if the bolt is missing, you should put all bolts in.
Adjust valves again after that mileage.
You can even turn the pump more early, so that the pump marker is 1 mm above the engine block marker.
Gruß
Volker
Volker407
Gruß
Volker
Keino
11-10-2014, 08:37 AM #3
If you mean the bolt back of the pump (not the 3 in front) you can skip that one. been driving xxxxx km's without it. No probs Rolleyes
Keino
11-10-2014, 08:48 AM #4
(11-09-2014, 06:03 PM)Volker407
Gruß
Volker
I agree on all counts. If you advance it too far, it will knock. So, you can adjust until it starts knocking, then retard a little bit. That will put you pretty darn close to perfect timing.
From what I've seen on my old 617, you can advance beyond the factory recommended timing by a few degrees and get a little more torque.
Gruß
Volker
Evenglass
11-10-2014, 09:38 AM #5
(11-10-2014, 08:37 AM)Keino If you mean the bolt back of the pump (not the 3 in front) you can skip that one. been driving xxxxx km's without it. No probs Rolleyes
That's the one! I did manage to get it back in.
(11-10-2014, 08:48 AM)Simpler=Better
Gruß
Volker
So it's not mandatory to drip time? I can adjust by sound a little at a time until it starts to knock then turn it back a bit? I like option 2
This post was last modified: 11-10-2014, 09:43 AM by Evenglass.
Evenglass
Gruß
Volker
11-10-2014, 10:40 AM #6
The drip lets you get a concrete number but it isn't necessary if you don't mind playing with a bit.
11-10-2014, 01:19 PM #7
I've never drip times anything in my life. I just use my ears and how it runs and starts Smile
Evenglass
11-12-2014, 08:35 AM #8
Thank you for the responses everyone.
Evenglass
