STD Other Projects W463 G-class OM606 + HE351W
  • 1 Vote(s) - 5 Average
Pages (2): 1 2 Next
hents99
11-29-2014, 06:04 AM #1
I have OM606.962 engine and 722.608 tranny.
Plan is to use Holset HE351VE turbocharger and Ole Fejers tranny controller.
I`m more familiar with petrol engines so I would like to ask your opinions.
This engine and tranny will go for W463 G350TD. Goal would be around 350-400hp.
What do you guys think of this turbo. Suitable for it? Or too big for low rpm torque?
I would like to have VGT turbo and HE351VE is quite reasonable priced as well.
I will rebuild the engine and transmission.
Custom exhaust manifold and modified intake manifold, custom cooler.
Pump should have 7.5 or 8.0 mm elements?
Thanks!
This post was last modified: 04-24-2015, 09:24 AM by hents99.
hents99
Thanks!
Petar
7.5mm M pump
459
11-29-2014, 08:02 AM #2
Quoting olefejer himself:
Here is some information on
Turbo: HE341VE
Motor: OM606
I have just changed my HE351VE to the smaller
HE341VE. it spools faster and gives more boost
at lover RPM.
Here are some numbers in high gear, meaning
motor RPM rise slow. giving the turbo more time
to build boost.
The engine feels fantastic pulling from 2500 -
5000 RPM
Now width the HE341VE
0.5 bar at 2000 RPM (EGP 0,8)
1.0 bar at 2500 RPM (EGP 1,3)
1.5 bar at 2700 RPM (EGP 1,8)
1.8 bar at 3000 RPM (EGP 2,1)
holding 1.8 bar all the way to 5000 RPM
(120,000 Turbo RPM)
Before width the HE351VE
0.5 bar at 2500 RPM (EGP 0,8)
1.0 bar at 3000 RPM (EGP 1,3)
1.5 bar at 3500 RPM (EGP 1,8)
1.8 bar at 3700 RPM (EGP 2,1)
1.8 bar at 5000 RPM (EGP 2,1) (95,000 Turbo
RPM)
Petar
Turbo: HE341VE
Motor: OM606
at lover RPM.
to build boost.
5000 RPM
(120,000 Turbo RPM)
RPM)
hents99
11-29-2014, 08:36 AM #3
Very good information.
Where I could find HE341VE ? From Cummins engines?
hents99
Petar
7.5mm M pump
459
11-29-2014, 04:17 PM #4
Googled a bit and found out that the HE341VE was used on cummins ISB and ISL engines, i'm not sure in which vehicles though.
Petar
muuris
OM605
318
11-29-2014, 05:42 PM #5
I had 606 + He351VE and wouldn't do it again, one can achieve similar results with modern conventional turbo. You cannot only look at boost readings at specific rpm because on spoolup you'll be making more backpressure than you would on normal turbo, hence it doesn't pull as strong. Imo it's just not worth all the extra work.
This doesn't mean that no vnt turbo works on 606, but I'd bet my money next time on compounding. If not that, BW vnt.
muuris
hents99
02-16-2015, 04:38 PM #6
I bought HE351VE turbocharger.
I have also Eaton M112 supercharger and I had no idea what to do with it until now.
Is it bad idea to run with supercharger and turbo? Is m112 too big for this engine?
hents99
NZScott
HX30W 73/44mm
398
02-16-2015, 11:41 PM #7
(02-16-2015, 04:38 PM)hents99 I bought HE351VE turbocharger.
I plan on using virtually the same setup. Supercharger feeding turbo.
I'm only going to use a basic VGT controller which uses the vanes for engine braking (so far)
I think the blower would compliment the lack of bottom end quite nicely, and help spool the turbo up of course .Then you could have a diverter open once the VGT has enough exhaust flow to work with.
(Naturally you're better off with an electronic controller and proper sized turbo, and get rid of the blower)
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
hents99
02-17-2015, 02:53 AM #8
My biggest concern is size of M112. Maybe I should find smaller one for good bottom end.
hents99
NZScott
HX30W 73/44mm
398
02-18-2015, 11:17 PM #9
They are quite big, but bigger is better - doesn't have to spin as fast to flow as much as a M90 and the air coming out would be cooler. I think
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
hents99
04-24-2015, 09:32 AM #10
I got new turbocharger yesterday. It`s Holset HE351W with 12# turbine housing.   I hope it`s not too big.
I use OM606 N/A intake and weld 2 laminova water to air cooler cores into manifold. There is just no space to mount intercooler to G-class without cutting anything.
I going to offer bolt-on kit like this. Turbo, manifold, intake manifold with cooler, aux water pump, piping from turbo to intake. Oil feed and return.
[Image: 57782-WP_20150424_14_48_45_Pro.jpg]
[Image: 77962-WP_20150424_14_48_56_Pro.jpg]
[Image: 65985-WP_20150421_15_02_40_Pro.jpg]
This post was last modified: 04-24-2015, 10:02 AM by hents99.
hents99
04-25-2015, 01:12 PM #11
That's badass. This is the first Laminova DIY I've seen on the web. Can't wait to see how it works out.
hents99
05-01-2015, 09:30 AM #12
How much power 7mm elements can supply?
hents99
hents99
05-16-2015, 11:44 AM #13
[Image: 48279-WP_20150516_12_56_59_Pro.jpg]
[Image: 35674-WP_20150516_15_12_39_Pro.jpg]
[Image: 94723-WP_20150516_15_43_39_Pro.jpg]
I like this intake pipe more:
[Image: 39596-WP_20150516_19_16_29_Pro.jpg]
Turbo compressor housing is still too hot.....
Edit: here it is:
[Image: 39894-WP_20150516_19_50_12_Pro.jpg]
Can`t wait when I get my g-wagen from paint shop.....it`s going to be "Sepang Bronze" (A32 BMW paint code).....like my another project:
[Image: 89958-DSC_3958.JPG]
Laminova cooler intake test version will be ready soon.
This post was last modified: 05-16-2015, 11:52 AM by hents99.
hents99
Edit: here it is:
Turbo
05-16-2015, 01:06 PM #14
That is a really nice looking car, great build
Turbo
muuris
OM605
318
05-18-2015, 12:50 AM #15
(05-01-2015, 09:30 AM)hents99 How much power 7mm elements can supply?
More than 500, but that turbo limits power to around 400. Should spool relatively good though with that small turbine housing.
muuris
hents99
05-18-2015, 04:36 AM #16
That`s good to know. Won`t need more power. I hope it spools fast enough.  G500 with 218kW / 456Nm is quite lazy at low rpms.
Anyway turbo piping fits. Welding laminova cooler cores into manifold is basically final step with engine. Pump is in diesel shop for adjusting quantities and hope to get it back soon.
[Image: 87937-WP_20150518_10_17_22_Pro.jpg]
hents99
Turbo
05-18-2015, 02:22 PM #17
would be interesting to see what that laminova cooler can do!
This post was last modified: 05-22-2015, 04:54 PM by Turbo.
Turbo
DanielK
Big Plans, No Clue
98
05-22-2015, 06:30 AM #18
God, I want to build my 2.3-16 so badly, but it's probably 0% salvageable.
[Image: FalkonSig.png]
DanielK
hents99
05-22-2015, 07:00 AM #19
Intake then...
[Image: 94949-WP_20150522_14_20_59_Pro.jpg]
[Image: 96995-WP_20150522_14_19_52_Pro.jpg]
[Image: 73426-WP_20150522_14_20_49_Pro.jpg]
[Image: 58986-WP_20150520_17_30_12_Pro.jpg]
Upgrading 2.3-16 is so simple....Diesel world is different. It`s my first diesel project.
Tuning process is what I´m afraid of. It`s easy with petrol engines. Mapping with computer and you always get correct air fuel mixture.
With mechanical pump I can`t do basically anything. Just hope it`s not smoking too much.....I really hate when car smokes. Like something is broken.
hents99
Intake then...
hents99
05-22-2015, 01:46 PM #20
[Image: 59238-WP_20150522_21_24_07_Pro.jpg]
[Image: 26629-WP_20150522_21_23_26_Pro.jpg]
[Image: 55372-WP_20150522_21_31_02_Pro.jpg]
hents99
Turbo
05-22-2015, 04:59 PM #21
there are eletrical EDC pump that can go to 600HP that can be tuned like a petrol car
Have you calculated the plenum volume by intake tube, exhasut manifold to determine plenum volume?
little bit curious how flow of air works on the laminova cooler
Turbo
hents99
05-23-2015, 04:04 AM #22
Flow is not a problem and this engine won`t see high rpms like petrol engines. Manifold design is not perfect at all but enough for my needs and for this engine.
Intake runners are long anyway.
Well, we`ll see what`s happening....
hents99
atypicalguy
05-23-2015, 11:43 AM #23
That is some nice welding on the plenum. I have always been a bit hesitant to weld on aluminum castings, so I have two questions:
1. Do you preheat cast aluminum before welding it to prevent it from cracking? If so, what temperature?
2. Did you CNC cut the mounting plates for the laminova cores?
-ok, one more-
3. What settings did you use when welding the manifold and turbo? Amps, balance, Hz, rod type and thickness. If you do not mind. Please and thank you.
atypicalguy
-ok, one more-
hents99
05-23-2015, 12:25 PM #24
I didn`t preheat the cast aluminum but it`s better of course.
I made drawings and send them to water cut/jet. Pipes are milled with manual mill.
Settings.....my TIG welder is analog type and display is not showing correct numbers. Trial-error works Smile
Most important is that material should be as clean as possible. It`s not nice welding to be honest. Not at all. But it`s not leaking and it`s strong and solid.
Before this work I welded 2-3 months ago. So I don`t weld too often anymore.
hents99
atypicalguy
06-13-2015, 11:05 PM #25
How is the lamina intake working?
atypicalguy
06-14-2015, 03:18 AM #26
I still don't fully comprehend those laminova things. Will you be taking measurements of charge air temperature pre- and post-charge cooler? This would be very interesting! Smile
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
hents99
06-14-2015, 10:44 AM #27
I haven`t installed the engine into car because body is still in paint shop. I think I install 2 air temp sensors to see the effect.
hents99
hents99
07-07-2015, 03:56 PM #28
[Image: 85547-WP_20150707_15_12_21_Pro.jpg]
[Image: 74539-WP_20150707_15_12_13_Pro.jpg]
[Image: 76584-WP_20150707_15_12_34_Pro.jpg]
[Image: 76649-WP_20150707_15_12_59_Pro.jpg]
hents99
atypicalguy
07-12-2015, 10:22 PM #29
This looks really good.
atypicalguy
Jambo
07-13-2015, 05:09 AM #30
That looks awesome, in fact the best solution I have seen. Will be watching this thread closely as my OM606 is on standby for my 463 300GD. Hope the intercooler is as effective as it looks.
What is that crossover pipe from?
What did you do with the Aircleaner?
ReGards from SA
Alan
Jambo
ReGards from SA
Alan
hents99
07-13-2015, 07:25 AM #31
Intake manifold and crossover pipe both from 606 non-turbo engine.
hents99
Jambo
07-13-2015, 07:57 AM #32
Tx, what have you done for the air intake?
Jambo
hents99
07-13-2015, 12:28 PM #33
Here`s my original intake manifold which going to another Estonian member "erx" engine. Today I made some modifications for him.  3" inlet.
[Image: 68978-WP_20150713_15_52_59_Pro.jpg]
[Image: 38832-WP_20150713_15_53_08_Pro.jpg]
hents99
hents99
07-13-2015, 05:15 PM #34
Meanwhile in workshop....hillclimb motorcycle. KTM LC8 with standalone and turbo.
[Image: 44444-WP_20150703_16_57_18_Pro.jpg]
[Image: 57236-WP_20150703_16_57_23_Pro.jpg]
[Image: 69725-WP_20150703_16_57_33_Pro.jpg]
Finding engine TDC. It`s 75-degree V2 engine. Way different from regular "180-degree" engines.
[Image: 84895-WP_20150710_16_55_42_Pro.jpg]
hents99
CRD4x4
CompoundSuperTurboDiesel4x4!
399
07-14-2015, 08:57 AM #35
Lol!
Your shop has tile floors, glass walls and display cases?!
Are you a Bond villain?!
Ignore me. I'm just jealous...
'05 Jeep Liberty CRD - 160k
'06.5 VW Jetta TDI - 230k
CRD4x4
Lol!
hents99
07-15-2015, 05:09 AM #36
I don`t have cars in this building Smile
Garage has dirty concrete floor unfortunately.
hents99
07-15-2015, 08:10 PM #37
Pretty sweet. I just visiting a injection pump specialist yesterday, and his son had a Harley Davidson victory with a little Garrett mounted on it. Put down 140hp at the back wheel with the clutch slipping Big Grin
hents99
07-20-2015, 12:19 PM #38
Some stainless steel work. These are W126 560 (300hp version) downpipes.
[Image: 93694-WP_20150719_20_26_59_Pro.jpg]
[Image: 49848-WP_20150719_20_23_39_Pro.jpg]
Motorcycle going to have new intake manifold.
[Image: 83896-WP_20150719_20_40_03_Pro.jpg]
G-wagen will be painted in few days and I can start OM606 conversion.
Question about fuel pressure between fuel pump and diesel injection pump. Walbro 255 LPH pump should be enough for up to 400hp.
hents99
Jambo
08-12-2015, 12:46 AM #39
Any progress on this project?
Jambo
hents99
08-12-2015, 01:23 AM #40
[Image: 62798-WP_20150806_14_35_51_Pro.jpg]
hents99
Jambo
08-13-2015, 05:22 AM #41
A am beginning to like this colour more and more.
Jambo
minim
08-13-2015, 06:27 AM #42
Nice color Smile
I guess you are starting on the engine soon then? Could you please take som pictures if your rear engine/tranny mount and measure length of you axle/show how you modify it?
minim
Nice color Smile
hents99
08-13-2015, 08:27 AM #43
I hope to get this information from you Smile
I start swapping engine next week I hope.
hents99
Jambo
08-17-2015, 05:49 AM #44
Hi Guys,
I also started my conversion and for now am only doing the 6 speed box. 716.654
It seems to be a tight fit but it does go in. I still nedd to fabricate the rear flange to fit G 8 hole flange. I also need to fabricate the shifter still to be to my liking. So far I can shift but am not happy yet. It does need the stabilizing frame for better shifting.
The cross member is also not yet done and I am considering using a flat bar and fitting the original rear gearbox mount . Suggestions?
PS. I do not want to cut the original crossmember, hence the flat bar, plus it will fit better.
Jambo
Hi Guys,
hents99
08-17-2015, 12:07 PM #45
Lucky that you don`t have 3 shifter rods like old boxes. Real PITA.
What have you done with engine? Is it stock?
I was searching pictures of transmission mounting plate I made to my previous G-wagen project. It was W460 230GE and I installed 5.0 M117 engine:
[Image: 83257-Foto0179.jpg]
Here is custom made transmission mounting plate:
[Image: 47563-Foto0436.jpg]
[Image: 54952-Foto0410.jpg]
[Image: 59627-Foto0411.jpg]
[Image: 48578-Foto0447.jpg]
[Image: 76833-Foto0464.jpg]
[Image: 96356-Foto0470.jpg]
[Image: 34693-Foto0503.jpg]
[Image: 99493-Foto0502.jpg]
hents99
Jambo
08-17-2015, 11:22 PM #46
(08-17-2015, 12:07 PM)hents99 I found an old cross member from a conversion I did more than 10 years ago. It is the cross member from my 230GE and seems it will fit. I might have to cut it down a little bit but it will look original and do the job well.
Jambo
minim
08-18-2015, 01:59 AM #47
(08-13-2015, 08:27 AM)hents99 I hope to get this information from you Smile
I have found a source for axle lenghts but I see that you are going with another tranny than me. I'm going to use the 722.6 transmission. If you want the lengths of the various axles from g-wagon I have most of them in a document I found searching for mine. I need to shorten mine 2.5cm to get it in. I bought the stock flange from G-wagon with 606.964 engine off ebay and replaced the triangle flange I see you have on your transmission.
btw, are you selling those laser cut things for the laminova coolers? I could use those Big Grin
This post was last modified: 08-18-2015, 02:00 AM by minim.
minim
hents99
08-18-2015, 02:18 AM #48
I use 722.6 tranny. Same conversion as you do. Jambo has manual 6spd gearbox.
Laminova intake will be bolt on product as soon as i test it. Then i can offer bolt on om606 turbo kit too.
This post was last modified: 08-18-2015, 02:19 AM by hents99.
hents99
Jambo
08-18-2015, 03:16 AM #49
The 606 Turbo Intake manifold is different !
Will you be making an IC for this as well?
Jambo
hents99
08-18-2015, 06:34 AM #50
Yes. 606 turbo manifold is different. I`m using 606 non-turbo intake manifold because I can`t find a place where to mount intercooler and piping. I don`t want to cut original details. That`s why.
hents99
Pages (2): 1 2 Next
