STD Tuning Engine Swapping OM606 into my SDL at this moment...
  • 1 Vote(s) - 5 Average
TurboTim
12-13-2014, 08:05 PM #1
So I am in the process of swapping an OM606 into my 87 SDL. I am also swapping an 722.633 also but realized that I would have to get an inline motor bellhousing so I got one of those this morning. I swapped the bellhousings today and pulled the motor just now. I am planning on getting this running by tomorrow so quick responses would be great. It looks like I can swap my oil filter housing so I can keep my oil cooler lines. I see that I have to swap mounts. Should I swap oil pans or not? The OM606 pan looks bigger. I still have to swap my built pump so I will check back in a hour. Thanks for the help.
76 300TD custom lots of stuff
TurboTim
TurboTim
12-15-2014, 09:44 AM #2
Done!
If anyone has any questions they can ask me while its fresh in my mind.
This post was last modified: 12-15-2014, 09:44 AM by TurboTim.
TurboTim
Done!
racerxoffl
12-15-2014, 12:59 PM #3
http://www.benzworld.org/forums/w124-e-c...-s124.html
The Internet is your friend?
I am not swapping the pan, my 606 was low enough miles I didn't want to change the oil pump so I could reuse the 603 pan. I opted for a 500E bar.
racerxoffl
TurboTim
12-15-2014, 02:39 PM #4
Yeah I kept my 603 pan and also the filter housing. I modded the cruise to work and welded a bracket for the throttle. I didnt have to change the oil pump when I swapped my pan just for you information.
TurboTim
racerxoffl
12-15-2014, 03:48 PM #5
Were you able to find the motor nearby this is the fastest I have ever seen someone tackle one of these. Mine took about 2 weeks to be drivable, but not finished.
racerxoffl
TurboTim
12-15-2014, 09:23 PM #6
Motor I ordered online ahead of time. Trans for S500 I had. I had to get an in line bellhousing locally but found one and got one Saturday. I took the exhaust flange off my 603 motor and welded it to my om606 motor to fit my HX40/35. I still have to finish wiring my trans controller as I got the wrong shifter.
(12-15-2014, 03:48 PM)racerxoffl Were you able to find the motor nearby this is the fastest I have ever seen someone tackle one of these. Mine took about 2 weeks to be drivable, but not finished.
BTW your car looks nice!
This post was last modified: 12-15-2014, 09:26 PM by TurboTim.
TurboTim
TurboTim
12-20-2014, 02:59 AM #7
I just want to update my post so there is no misinformation out there.....After running my car for a bit I figured out you can not run the OM606 pickup with the OM603 pan. I ended up having low oil pressure and so I took off the little side wing and luckily I was able to swap back over to the OM603 pickup. Talk about needed tiny hands though. Low oil pressure solved!
TurboTim
