STD Other Projects G-wagen , om605 , 6mm , holset
Pages (2): Previous 1 2
hents99
05-12-2015, 11:27 AM #51
(05-12-2015, 05:41 AM)MrHope biggest problem is that the w460 g-wagen biggest engine is the 300D 88hp and 280E with 154hp and mercedes dont allow any bigger engine than that.
or you can increse tq with 10% and hp with 20% from the cars original engine.
if you register the car as Modified you can get more hp and unlimited tq , as thay just have a limit hp/kg and in that case the gwagen has no problem as its quite heavy! but to do that you have to change the braking system to. and bolt on stuff is not allowed, must be custom made, even if it means put smaller brakes on its ok!! really stupid rule that only proves that someone behind a desk just wanted to make a rule!
I had W460 with M117 5.0 V8 installed and tried to make it legal.....impossible....
A friend of mine (Robert) has R107 SLC with M117 5.6 twin turbo in Sweden and it`s legal....dyno result without boost Smile Turbos pushed charge air to atmosphere Smile
hents99
bruno_pinho
08-03-2015, 10:15 AM #52
(12-31-2014, 01:15 PM)MrHope Santa came by!
[Image: hx35fender.jpg]
It´s a Holset HX35 specialbulit with a smaller garrett turbine.
And pretreaded 1/8" hole for tempsensor.
[Image: hx35.jpg]
But i will start with the original turbo and when its registered with the engine swap i will start fitting the holset.
The turbo took a small exhaust housing, or also took a smaller garrett turbine?
bruno_pinho
[Image: hx35.jpg]
MrHope
10-19-2015, 03:59 PM #53
Muuris: if i get it it trough inspection with a turbo it just says "om605 with turbo" so what turbo i do mount later wouldnt be a problem.
W124 300D 1985 (daily driver)
MrHope
MrHope
10-19-2015, 04:48 PM #54
MrHope
MrHope
12-12-2015, 11:49 AM #55
Finaly !
Customized gearbox mount!
Customized shift linkages!
fitted the c250 turbo radiator!
Test run! Seems to work wery good! probably little more than 200hk
But i has a high sound when full trottle! (no exhaust system)
So i made a exhaustsystem with 2,5" pipe and one damper, and exhaust output just before the right rear tire.
tested again, and it didnt get so much quieter....? .. maby better airfilter would make it quiet?
MrHope
Finaly !
MrHope
12-13-2015, 04:55 PM #56
Made a 2,5" Exhaust from scrap i had layin around, sounds really nice! (had missed to weld a big gap after the turbo when last testdrive! much more quiet now!)
[Image: exhaust.jpg]
And looks okay! its stainless pipe 3"
[Image: exhaustpipe.jpg]
Made the gearbox mount spacer/adapter , the new gearbox has the mount off center.
[Image: gearboxbracket.jpg]
Installation almost looks like original, besides missing the fan scroud.
[Image: finished605turbo.jpg]
This post was last modified: 12-13-2015, 04:57 PM by MrHope.
MrHope
MrHope
12-29-2015, 04:27 PM #57
Did pass the registration today!
The car is now legal with the om605 turbo, 150hp and 280nm! (Mine maby has a few more horses)  Angel
Standard om617 300 had 88hp/172nm Wink
Did even get it registrated with the rear seat so now ok with driver and 4 passengers!
And the new oris tow hitch registrated with 3000kg towing capacity!
Big Grin
This post was last modified: 12-29-2015, 04:44 PM by MrHope.
MrHope
Big Grin
MrHope
10-03-2016, 02:05 AM #58
Car runs great and feels wery light! (it dindnt feel light before i can promise u that!)
But i felt the stock turbo was to small (constantly 0,4 bar when driving, and high egt when pulling a trailer or uphill)
 i did have another turbo that i was going to try!
Someone else here built a c-class with this kind of adapter so i gave it i try! triangular to T3 adapter and lifted it up so i would clear the shockmount.
[Image: t3adapterblack.jpg]
MrHope
MrHope
10-03-2016, 02:14 AM #59
And the turbo is fitted!
Its a T3 turbo from china, i has A/R 0.63 exhaust and A/R 0.50 Compressor
had to make a new
Oil feed line
Return line
New downpipe 2,5"
Boost pipe to intake 2,5"
[Image: nyturbon.jpg]
MrHope
had to make a new
Oil feed line
Return line
New downpipe 2,5"
MrHope
10-03-2016, 02:17 AM #60
Painted the boost pipe black!
and fitted a cheap air filter that i had from another car... would like a better filter later on.
[Image: nyaturbon.jpg]
MrHope
MrHope
10-03-2016, 02:29 AM #61
Its fires up nicely!
But i feel the boost comes to slow.... and maximum boost is 1,5bar.... i would want to reach minimum 2bars...  Dodgy
[Image: nyaturbonute.jpg]
MrHope
muuris
OM605
318
10-03-2016, 06:11 AM #62
(10-03-2016, 02:29 AM)MrHope But i feel the boost comes to slow.... and maximum boost is 1,5bar.... i would want to reach minimum 2bars...  Dodgy
A post from the past
(10-03-2016, 02:14 AM)MrHope Its a T3 turbo from china, i has A/R 0.63 exhaust and A/R 0.50 Compressor
You get what you pay for. Even a genuine T3 is 30 years old tech, don't expect it to be quick spooling or to be capable of high pressure ratios. If you plot calculated points to compressor map, I'm quite sure you'll find that your safe max boost is less than 1,5 bars (I'd say close to 1 bar). Besides, with 6mm elements there's no reason for that high boost anyway.
muuris
MrHope
10-04-2016, 02:52 AM #63
Muuris:
i did some adjusting on the outside alda and now the car smokes a little black at first when full trottle before boost and blacksmoke stops before 1bar. and its not boosting more than 1bar now.
i have only adjusted alda and boost dropped from 1,5bar to 1,0bar.
no blacksmoke at 1.0bar with alda set on full. do you think its using all 95cc of fuel at 1,0bar?
the car is nice to drive and feels light and fast even tho it is 2200kg in actual weight.
i just wish the boost would come faster.
MrHope
Muuris:
MrHope
10-21-2016, 01:52 AM #64
Addi :
you have sent me PM but i cant answer, its says you have disabled private messages.
MrHope
Addi :
hents99
10-21-2016, 03:15 AM #65
Are you controlling boost pressure with solenoid valve?
Wastegate must be fully closed before desired boost level.
hents99
MrHope
10-21-2016, 05:09 AM #66
Hents:
Wastegate is mecanicly locked so its always closed now, boosts 1,3 bar at most.
MrHope
Hents:
hents99
10-21-2016, 06:30 AM #67
Ok Big Grin
Edit: We have similar setup.
[Image: 24463-Photo_21-10-2016_14_32_55.jpg]
[Image: 47759-Photo_21-10-2016_14_32_59.jpg]
This post was last modified: 10-21-2016, 06:46 AM by hents99.
hents99
Ok Big Grin
MrHope
10-21-2016, 07:59 AM #68
Nice build!
is it watercooled intake?
in my next w460 build i will go for the 6-cylinder!
MrHope
Nice build!
addi.bigg
OM605; 7,5mm elements
94
10-21-2016, 08:10 AM #69
(10-21-2016, 01:52 AM)MrHope Addi :
Hello my last Hope! Smile
I've switched it on. if you have time please reply for that!
addi.bigg
hents99
10-21-2016, 08:15 AM #70
Yes. Watercooled intake with Laminova cores.
hents99
addi.bigg
94
10-21-2016, 08:22 AM #71
(10-21-2016, 08:15 AM)hents99 Yes. Watercooled intake with Laminova cores.
What kind of transmission do you have? Automatic?
addi.bigg
hents99
10-21-2016, 08:24 AM #72
722.6
hents99
722.6
addi.bigg
94
10-21-2016, 08:40 AM #73
(10-21-2016, 08:24 AM)hents99 722.6
Could you take some pics of the throttle cable solution of yours?
addi.bigg
MrHope
10-23-2016, 05:02 AM #74
Addi: look at the pics in my first page, its all wire no linkages atall.
MrHope
addi.bigg
94
10-23-2016, 05:09 AM #75
(10-23-2016, 05:02 AM)MrHope Addi: look at the pics in my first page, its all wire no linkages atall.
How did you keep the connetion between the transmission the throttle pedal and the pump, without using the original linkage?
addi.bigg
