STD Tuning Engine om604 2-liter STD
om604 2-liter STD
om604 2-liter STD
F.R.A.S
01-03-2015, 05:23 PM #1
How to build a solid 4cyl diesel?
Take one awesome om604 engine. Put stronger rods and pistons in it, straighten and balance the crank, weigh all rods and pistons, get crazy camshafts to it and machine the pistons for clearance then send the pistons of for coating. Modify a BMW flywheel to fit the Mercedes crank and tadaaa you have a solid 4cyl 16v diesel.
Dieselmeken will build the IP.
F.R.A.S
01-03-2015, 05:43 PM #2
yep, seems easy , just a simple question, what will be the displacement?
F.R.A.S
01-03-2015, 06:32 PM #3
Look at the subject Smile 2-liter...
(01-03-2015, 05:43 PM)barrote yep, seems easy , just a simple question, what will be the displacement?
F.R.A.S
01-03-2015, 06:40 PM #4
Wink, like many things in the world , the hell is in the details.....
This post was last modified: 01-03-2015, 06:41 PM by barrote.
01-04-2015, 10:32 AM #5
Would you mind sharing the cam specs?
Petar
7.5mm M pump
459
01-04-2015, 11:00 AM #6
What bore and stroke ? My guess is OM601 84mm stroke crank and 87mm 606 turbo pistons.Did you resleeve the engine for the smaller bore ?
This post was last modified: 01-04-2015, 11:01 AM by Petar.
Petar
F.R.A.S
01-04-2015, 12:40 PM #7
Not at all.
Intake:
Centerline 112-degrees
Duration 280-degrees
Lift 10,6mm
TDC lift 1,7mm
Exhaust:
Lift 10,6mm
TDC lift 1,6mm
This is what we call Stg2 cams. So nothing special at all.
(01-04-2015, 10:32 AM)raysorenson Would you mind sharing the cam specs?
Yes normal turbo engine bore and stroke Cool
Yep new sleeves in the cylinders to achieve the smaller bore.
(01-04-2015, 11:00 AM)Petar What bore and stroke ? My guess is OM601 84mm stroke crank and 87mm 606 turbo pistons.Did you resleeve the engine for the smaller bore ?
F.R.A.S
Not at all.
Intake:
Lift 10,6mm
TDC lift 1,7mm
Exhaust:
Lift 10,6mm
TDC lift 1,6mm
01-07-2015, 10:59 AM #8
Thanks for the info. Doing research for a 603 cam.
Is that duration @1.0mm lift?
F.R.A.S
01-07-2015, 05:24 PM #9
You never learn enough Sad
I have no clue actually and that is a valid question. I'm NOT the camshaft guy really. I don't know anything of how that piece works. I just know from being in the flow bench that you need a little bit of lift to get good numbers.
The cam-guy we use calculate on stuff like this. Maybe it's time to learn Smile
(01-07-2015, 10:59 AM)raysorenson Thanks for the info. Doing research for a 603 cam.
F.R.A.S
erling66
SuperDieselVan
294
01-08-2015, 02:12 PM #10
Why do you want to reduce bore and stroke? Bore, I guess is because you want to use 605/6 turbo pistons. But stroke??? Normally more ccm means more hp.
HuhCoolTongue
erling66
HuhCoolTongue
Jetmugg
01-08-2015, 02:13 PM #11
This looks like a very interesting project. I can't wait to hear/see how well it runs.
Will you be using aftermarket connecting rods? I certainly hope so - with the fueling potential of the Dieselmeken pump and what I suppose may be 2.5 bar of boost or so, the upgraded rods would be a nice insurance policy.
Steve.
Jetmugg
Steve.
F.R.A.S
01-08-2015, 03:29 PM #12
The engine will race in a 2-liter class Big Grin AND it's pretty hard to find a tougher rod the same length as a 2.2-liter rod.
(01-08-2015, 02:12 PM)erling66 Why do you want to reduce bore and stroke? Bore, I guess is because you want to use 605/6 turbo pistons. But stroke??? Normally more ccm means more hp.
2.5bar will not do it quite frankly, 3-3,2bar maybe. And yea it's a cool project. Just have to make sure the guy with the wallet decides for some forged rods Smile
(01-08-2015, 02:13 PM)Jetmugg This looks like a very interesting project. I can't wait to hear/see how well it runs.
Steve.
F.R.A.S
Steve.
01-09-2015, 06:24 AM #13
I would suggest you'll need around 4 or 5 turbos to achieve your power goals.
F.R.A.S
01-09-2015, 08:55 AM #14
Ohhh no we're not aiming for 1550whp so we'll manage with one for now and two later on...
(01-09-2015, 06:24 AM)Hario I would suggest you'll need around 4 or 5 turbos to achieve your power goals.
F.R.A.S
01-09-2015, 09:01 AM #15
lol...
I will be following this build, I love small #'s with big #'s
This post was last modified: 01-09-2015, 09:02 AM by Hario'.
lol...
erling66
SuperDieselVan
294
01-09-2015, 02:12 PM #16
(01-08-2015, 03:29 PM)F.R.A.S The engine will race in a 2-liter class Big Grin AND it's pretty hard to find a tougher rod the same length as a 2.2-liter rod.
Now I see why you want 2LSmile but I am quite sure the 2.2L use the same rod length as the OM601 and the rare OM604 2L. Do you have a plan for when this engine should be running?
HuhCoolTongue
erling66
HuhCoolTongue
F.R.A.S
01-09-2015, 02:52 PM #17
Maybe you are correct regarding the rod length but still only a 26mm wrist pin Tongue We use the 606dt rods in this application (for now).
I have a set off each rods in the shop so will actually measure them Big Grin
I hope we can have this beauty up and running in the middle of february. Will break it in gently @ 6000rpm in the engine dyno hahahha...
(01-09-2015, 02:12 PM)erling66 Now I see why you want 2LSmile but I am quite sure the 2.2L use the same rod length as the OM601 and the rare OM604 2L. Do you have a plan for when this engine should be running?
F.R.A.S
Jetmugg
01-10-2015, 12:22 PM #18
After the engine is properly broken in, I suggest that we install it in something like this....
[Image: FtuneRampage_zps5e51abd6.jpg]
, remove the bicycle and tow bar, and then go chase a Land Speed Record.
Steve.
Jetmugg
Steve.
F.R.A.S
01-10-2015, 02:27 PM #19
I just love that picture!!! There will be NO competition on that bed off salt when Team Green Frog arrives.
(01-10-2015, 12:22 PM)Jetmugg After the engine is properly broken in, I suggest that we install it in something like this....
Steve.
Here's some pictures of the engine and the BMW flywheel.
This post was last modified: 01-10-2015, 02:58 PM by F.R.A.S.
F.R.A.S
Steve.
Riverstick
02-04-2015, 11:12 PM #20
Brilliant thread F.R.A.S,
What coating are you putting on the pistons...ceramic on top and Teflon on the sides?
Are you doing any modification to the pre chambers?
Riverstick
F.R.A.S
02-05-2015, 03:50 AM #21
Thanks mate. Yes you are correct Big Grin
(02-04-2015, 11:12 PM)Riverstick Brilliant thread F.R.A.S,
Pistons.
[Image: 10937269_10203371302591550_1488805200_n.jpg]
Block sleeved and bored, waiting for honing and top decking.
[Image: 10945517_10203405275400849_1175735518_n.jpg]
Flywheel done and Sachs 618 PP with Sachs 4-point sinter clutch.
[Image: 10957591_10203436415859341_1964069754_n.jpg]
F.R.A.S
Pistons.
Riverstick
02-07-2015, 12:44 PM #22
The coating looks good....I presume they were done in Sweden?
How much per piston?
Riverstick
F.R.A.S
02-07-2015, 01:57 PM #23
Thanks, the old om606.962 pistons looks like new Big Grin
Full coating (skirt and top) is 1000sek/piston. And yea, made in Sweden Cool
The pistons are also machined for more valve clearance before coating.
(02-07-2015, 12:44 PM)Riverstick The coating looks good....I presume they were done in Sweden?
F.R.A.S
Turbo
02-07-2015, 02:39 PM #24
Did you put in bigger vale or just want lower compression ratio?
(02-07-2015, 01:57 PM)F.R.A.S Thanks, the old om606.962 pistons looks like new Big Grin
Turbo
F.R.A.S
02-07-2015, 05:28 PM #25
More lift so only took some for clearance.
(02-07-2015, 02:39 PM)Turbo Did you put in bigger vale or just want lower compression ratio?
F.R.A.S
