STD Tuning Engine which electric fuel pump for 7,5mm pump?
uli124125
01-14-2015, 04:42 PM #1
hi
does anybody have a clear answer to my question?
Im driving a 7,5mm pump in my OM 602 and i want to have a full IP and not a half-full or should I say half-empty Pump and elements Big Grin
how much litres per minute pump are you driving?
for dailydriver not for high performance car Wink
thanks
uli
This post was last modified: 01-15-2015, 03:47 AM by uli124125.
uli124125
hi
thanks
uli
01-16-2015, 03:26 PM #2
lol,
use the normal lift pump. 7.5 elements are able of 150cc at least, something that your 2 valve engine will have trouble burning.
Big Grin
if u´re not happy buy one from a BMW. u´ll be fine with it.
lol,
Big Grin
uli124125
01-16-2015, 04:57 PM #3
i drive the originale at the moment Wink
and its bullshit
i have too little amount of fuel at high revs
so im asking for electric fuel gear pump because i drive plant oil
greets
uli
uli124125
and its bullshit
greets
uli
tgg416
01-18-2015, 02:13 PM #4
I use a bosch 044 copy, that delivers up to 5-6 bar and thats is way to much.
So now I have a regulator to get the preasure down. Before I got preasure regulator I was blowing fuel lines because I dident undrestand the hole picture.
Now I bought another electric fuel pump that delivers about 1,5 bar and I dont need a regulator makes all easyer and the fuel lines is not streesed, and thats enough for my 606 with 8mm170cc pump thats adjusted down. Probobly it can delivers enough fuel if I desire to turn the pump up max.
The fuel pump I bought at summit racing, think it was a carter type,,,
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
F.R.A.S
01-18-2015, 05:33 PM #5
You should have 3bar with a Dieselmeken 7.5mm IP. Use a Bosch 044 back by the tank and remove the restriction on the return off the IP and fit a normal banjo-bolt then put a FPR on the return line and adjust the pressure to 3bar.
Easy and works every time.
F.R.A.S
tgg416
01-20-2015, 03:44 PM #6
(01-18-2015, 05:33 PM)F.R.A.S You should have 3bar with a Dieselmeken 7.5mm IP. Use a Bosch 044 back by the tank and remove the restriction on the return off the IP and fit a normal banjo-bolt then put a FPR on the return line and adjust the pressure to 3bar.
But its not so many people that have enough air to burn all that diesel thats way I say 1,5 bar is enough.
Also in gørans (dieselmeken) test bench 1,5 bar was enough way up in rpm. But I agre with you FRED, no problem with 3 bar. Just small risk of blowing fuellines with the bosch 044 ( done that twice, diesel absolutly everywere on the car)
The person is asking for a 602 daily driver, not performance
This post was last modified: 01-20-2015, 03:46 PM by tgg416.
Gwagen 463, 270cdi
tgg416
Gwagen 463, 270cdi
MrHope
01-21-2015, 03:15 AM #7
What about the mecanical pump, huw much can it deliver?
W124 300D 1985 (daily driver)
MrHope
