STD Tuning Engine Oilpressure output 605/606
MrHope
01-19-2015, 02:27 PM #1
Changed the oilfilter today and was thinking of adding a oilpressure light but what hole should i use?
nr1 = cant see it from inside.
nr2 = its open right into to the same compartment as the filter.
any would probably work but whats the differense?
W124 300D 1985 (daily driver)
MrHope
Duncansport
01-19-2015, 03:02 PM #2
either.
1 is tapped for the normal MB oil pressure sending unit.
Duncansport
either.
EvoPeter
01-20-2015, 09:52 AM #3
I use nr1 for oilpressure and nr2 for oiltemp.
EvoPeter
